Old 04-07-2005, 08:49 PM   #1
soundspeed
Member#: 84663
2002 WRX Sedan
WR Blue
Default Help, throttle doesn't drop between shifts.
Just picked up an 02 WRX, blue 60000km bone stock. Very mixed first inpressions. Biggest problem is the throttle takes a long time to drop down between shifts, the harder I drive the more annoying it becomes, is there a fix for this.
soundspeed is offline   Reply With Quote
Old 04-07-2005, 08:54 PM   #2
fastsubie
Member#: 21999
2012 Wrx
I'm not sure what your asking. Are you saying when you accelerate in 1st gear that you can not shift into second untill the rpms drop back down to idle or what?? There is no need to wait for anything other than the shifter to go into one gear to the next. Learn how to drive stick better, driving school, a friend, ect...
Fess
fastsubie is offline   Reply With Quote
Old 04-07-2005, 09:22 PM   #3
WRXdriver04
Member#: 72560
04 WRX (stg. II)
java black prl
u posted the same thing in two different sections?? as i said in the other one...what are you talking about??
WRXdriver04 is offline   Reply With Quote
Old 04-07-2005, 11:07 PM   #4
yergi
Member#: 65303
nope nope
"dooby specialist"
Yes that can be "fixed". although it's really not broken.
You could get a lightened flywheel, if it really bothers you that much.
-yergi
yergi is offline   Reply With Quote
Old 04-07-2005, 11:08 PM   #5
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
All you need to do is back off the throttle right before shifting, let the stress off the drivetrain and then push in the clutch, be totally off the gas before pushing in clutch, but not so slow as to engine brake, its a balance but the revs drop fast then. If this isnt enough a pulley/flywheel will do the trick.
Trunk_Monkey is offline   Reply With Quote
Old 04-08-2005, 12:53 AM   #6
seattle944t
Member#: 18308
2005 WRX STi
Search is your friend:
http://forums.nasioc.com/forums/show...light=RPM+hang
Blame the EPA...
seattle944t is offline   Reply With Quote
Old 04-08-2005, 10:16 AM   #7
WRX03
Member#: 20744
05 Baja Regal Blue
03 WRX Little Red Wagon
Give it a few days for above to start working.
WRX03 is offline   Reply With Quote
Old 04-08-2005, 01:59 PM   #8
949
Member#: 58906
i know what he is talking about. it can easily be changed on the older honda's or acura's. on those cars you just remove a vacuum tube. the tube is controled by a round peice which i dont know the name of it. it allows the throttle to be released at an even slower rate. dont know about your car tho so youll need to look for a vacuum tube and try.
949 is offline   Reply With Quote
Throttle/RPM issue between Shifts bulgarianfreak55 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 03-30-2011 02:56 PM
How to make your throttle close immediately between shifts bryan_johnson Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 110 11-27-2009 11:28 PM
Help Why powershifting bog between shift ????? SERGEREYES Commercial ECU Reflashes 12 12-03-2007 02:08 PM
RPMs doesn't drop on throttle lift hernan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-14-2004 09:42 AM
Question - Throttle Response Between Shifts SlideWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-15-2001 11:00 PM
