View Poll Results: Do you want to see my car finished? | |||
Yes. Don't give up now! | 136 | 85.00% | |
Nah. It was doomed from the start. | 5 | 3.13% | |
I really don't care either way. | 4 | 2.50% | |
I'll give you $20 and some twizzlers for it. | 15 | 9.38% | |
Voters: 160. You may not vote on this poll |
04-07-2005, 10:28 PM | #1 |
Member#: 17548
It has begun: GC4 EJ22 to EZ30R swap.
Well, the engine was delivered this afternoon. Here are a few pics to wet your appetites:
Top shot (crappy, I know) Engine model stamp: Wiring harness connectors (all sensors are there and hooked up): Passenger side head shot (motor mount and oil filter, too) Driver side head: Mick
04-07-2005, 11:01 PM | #2 |
Member#: 60073
Vehicle:1996 Impreza LX Green |
Nice, aren't you afraid of ripping your tranny apart though? Or are there plans there too? I could just imagine a 6spd with it and some turbos.
04-07-2005, 11:15 PM | #3 |
Member#: 17548
In the next week (or two), I will be buying all the parts that I will need to finish the swap. We will most likely be using a stock ecu from an 05 H6 equipped vehicle. We will be trying to use the stock headers if: A) they fit and B) they aren't horribly expensive. We will be making a custom header-back exhaust with high flow cat(s) and resonators. We might even make it dual-exhaust with a x-over pipe. More details will be posted as we make progress.
Mick |
04-07-2005, 11:17 PM | #4 | |
Member#: 17548
Mick |
04-07-2005, 11:59 PM | #5 |
Member#: 17548
Oh n05!! ddddouble post!
04-08-2005, 12:37 AM | #6 |
Member#: 84547
NWIC
Vehicle:06, Lafawnduh Fender rolling king |
cooler
04-08-2005, 01:10 AM | #7 | |
Member#: 33782
Vehicle:96 3MI Racing search FIRST, then PM!!! |
04-08-2005, 02:16 PM | #8 | |
Member#: 37558
South East
Vehicle:2003 TS wagon JDM bukkake white |
I agree.... I am making over 300whp and have been using my stock tranny the whole time (over 1 year). It's all about the driver. |
04-08-2005, 03:53 PM | #9 |
Member#: 1366
VIC
Vehicle:2000 RS-T -> RSTi-8 Blue Ridge Pearl |
I wonder if anyone would try to turbo this sucker... it's going to be a really tight fit like the other GC with EZ30. Interesting project though
04-08-2005, 05:02 PM | #10 |
Member#: 2874
Vehicle:2005 CGM WRX WGN Jorge Tunned BattleWagon |
Good Luck with the swap dude.
04-08-2005, 05:11 PM | #11 |
Member#: 17548
I thought about putting a turbo on it, but it is a 10.7:1 compression engine and I wouldn't want to mess with it without changing out the pistons and lowering the compression first. This is a brand new engine, so I'm going to keep it stock for a while.
Mick |
04-08-2005, 05:12 PM | #12 | |
Member#: 17548
Mick |
04-08-2005, 05:44 PM | #13 |
Member#: 177
NWIC
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
this is the dohc right?
will beinterstnig to see how pissed off the ecu is that its not sohc i would at lest start with the oldest h-6 ecu i could find the 05 ecu is a bad choice lots of wacky stuff intagrated into the ecu .. like the seat belts, secuirty system, hvac, radio etc |
04-08-2005, 08:41 PM | #14 |
Member#: 17548
I don't see how a SOHC non-avcs/non-avls would be a good choice to run this engine.
Mick |
04-09-2005, 12:55 AM | #15 |
Member#: 33782
get the 05 ecu to run the engine...the rest of the crap should be able to be ignored like with my 02 wrx engine swap...and most of it is easy to wire up anyhow...and yes twrracing is twin turboing a eg33 engine right now
04-09-2005, 02:47 AM | #16 |
Member#: 17548
That is the plan. As long as it gets the engine running and I can eliminate any emissions CELs, then that's all I care about. I'll be running a couple of high-flow cats, so the spark plug anti-fouler trick should work.
Mick |
04-09-2005, 05:00 AM | #17 | |
Member#: 13617
Vehicle:2001 Legacy GT back to stock is a project too |
http://forums.nasioc.com/forums/showthread.php?t=748513 Also Slack, FYI I just talked to a parts guy, and he told me sourcing all those parts(Ecu, wiring harness and components) would not be cheap, you may have a hookup but he estimated over 3k. he said he had to check an 05 bulkhead harness for a customer recently and list was 1035.00 that he remembered He also told me there is no getting around the Immobilizer system, you have to have ALL components for the ecu to run the engine, he knows i am doing a swap and this was a friendly convo so he wasnt just feeding me what subaru wants me to hear/think. Ben |
04-09-2005, 07:40 AM | #18 |
Member#: 17548
This should be talked about in private.
Mick Last edited by Slack; 04-09-2005 at 08:16 AM. |
04-09-2005, 02:10 PM | #19 |
Member#: 13617
ok.
Ben |
04-09-2005, 06:31 PM | #20 | |
Member#: 177
NWIC
but a sohc w/o avcs with wacky things like imobilizer isn't either |
04-09-2005, 07:50 PM | #21 |
Member#: 2289
Vehicle:1998 11.87@112mph Subaru L Ver 6 STi Type R |
I see no reason to even attempt a factory ecu, standalone will be much easier for this swap.
04-09-2005, 08:15 PM | #22 |
Member#: 17548
I have to be able to pass obd-II emissions tests. A stand-alone would make that next to impossible.
Mick |
04-09-2005, 08:45 PM | #23 |
Member#: 7022
Vehicle:2001 Forester Arcadia green |
I wonder how Nitrous would do on it
good luck dude. |
04-09-2005, 09:46 PM | #24 |
Member#: 177
NWIC
passing obd-2 is not gonna happen with an 05 ecu way way to many emmissions devices
buy a differnt chassis -get a standalone |
04-09-2005, 11:22 PM | #25 |
Member#: 2289
Yup swaps and emissions dont go together. If you plan to use a 05 ecu you are in way over your head and budget. Like Jaxx said you need a pre OBDII chassis. Honestly I see no point in this swap unless you pump 35 psi into a built engine to make some crazy hp not easiler attained with 2.5l Although it will have some bling if you get it finished.
EJ22 to EJ25 Swap Questions. | TooManySubies | Subaru Conversions | 9 | 02-03-2007 02:50 PM |
It has begun: Rimmer SC in '95l | Matt Monson | Normally Aspirated with bolt-on Forced Induction Powertrain | 48 | 08-23-2006 03:37 PM |
OK, where's the GC4 EJ22 to EZ30R thread? | Patrick Olsen | Subaru Conversions | 6 | 07-14-2006 10:32 AM |
Ej22 to Ej20g swap, difficult? | d4d4d4d4 | Subaru Conversions | 3 | 03-28-2004 01:59 PM |
