Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 04-08-2005, 11:09 AM   #1
Sharmin7
Member#: 59929
2002 2.5rs
Platinum Silver
Default headerback install CEL
I just installed my MRT header, highflow cat and brullen catback and after of driving for a day with no problems and no CEL, this morning on my way to work, my car started to bog and hesitate. It has an eratic idle. I scanned it and it pulled a P1137 for air/fuel monitoring. Could this be caused to my CEL with my front O2 Sensor. Any ideas or what can help me
Sharmin7 is offline   Reply With Quote
Old 04-08-2005, 11:56 AM   #2
Nicklbrso
Member#: 44887
00 GC6
Is the O2 sensor plugged into the cat?
Nicklbrso is offline   Reply With Quote
Old 04-08-2005, 12:22 PM   #3
Sharmin7
Member#: 59929
2002 2.5rs
Platinum Silver
the front one is in the header and the rear one is directly behind the cat
Old 04-08-2005, 01:22 PM   #4
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
Definitely is because of the placement and/or hi flow cat. moving the location of the sensors will change the flow they see, plus there is the change in flow because of new pieces. Probably no way around that CEL situation, unless you can maybe get one of the CEL fixes to work for you.
Jared
gtwagon941 is offline   Reply With Quote
Old 04-08-2005, 01:34 PM   #5
Sharmin7
Member#: 59929
2002 2.5rs
Platinum Silver
Okay i can live with a cel but why does by car bog and hesitate. that shouldnt happen
Old 04-08-2005, 02:31 PM   #6
Nicklbrso
Member#: 44887
00 GC6
could be a whole diff problem.
Old 04-08-2005, 02:57 PM   #7
Sharmin7
Member#: 59929
2002 2.5rs
Platinum Silver
i just got back from lunch and with the battery being disconnected for an hr and a half and after taking it for a drive and getting on it pretty good and taking it on the freeway it drove fine and no cel yet, but the cel didnt come on till 2 days later after the install, so im thinking it will just come back on in a few days and the problem is intermittent.
MRT Headerback Install whtlegacy Legacy Forum 6 12-25-2003 11:19 AM
Installed Cel fix but Check Engine still on GenMaster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 09-21-2003 11:18 PM
Blitz Power Meter Install = CEL!!! ProjectWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-24-2002 05:06 PM
Perrin Gen III Uppipe Install = CEL scoobyrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 07-22-2002 11:07 AM
ProECM + Install = CEL and constant cooling fans? obyone Normally Aspirated Powertrain 8 05-08-2002 03:28 AM
