Old 04-07-2005, 02:28 AM   #1
Impretzle
Member#: 74900
1995 Impreza L
1.8 N/A (No acceleration)
Default Cheap fuel filter alternative?
Maybe I'm cheap but I don't feel like paying $31.36 plus tax for a fuel filter. Are there any alternatives? Like taking the canister apart and replacing the paper filter inside?
Impretzle is offline   Reply With Quote
Old 04-07-2005, 02:30 AM   #2
allsubaru83
Member#: 60122
2008 M5
Space Grey
man when you are messing with the fuel filter i think it is a wise investment just to go buy a new one... that is what i would do, much easier.
allsubaru83 is offline   Reply With Quote
Old 04-07-2005, 02:43 AM   #3
Impretzle
Member#: 74900
1995 Impreza L
Much easier indeed, but you don't learn anything by shelling out 35 bucks for a folded up piece of paper inside a tin can, except that the auto industry has you right where they want you.
Old 04-07-2005, 03:04 AM   #4
allsubaru83
Member#: 60122
2008 M5
Space Grey
Talking
i would agree with this, but this is one of those things that comes with the car... "Maintnence" yes it does cost some, but if you look at every variable here, one you have to find a new filter, which would cost gas money, and time...in my mind time is money and these days gas isnt cheep either, tow you ahve to spend more time rippen the thing apart, what if you dont do it right and the seal is wrong, well then you are screwed. i would just go get a replacement one form like auto zone or from the web, which i bet you can get one cheeper than 30$ it is all about what the man wants to put into it...
good luck
chris
Old 04-07-2005, 12:43 PM   #5
IMPREZA619
Member#: 24289
hope your speed over
the Rival.
$35 is not bad considering that if you make your own new problems could arise thus req more $$ to fix but this is only my opinior.
IMPREZA619 is offline   Reply With Quote
Old 04-07-2005, 02:11 PM   #6
Dr. Morbid
Member#: 24945
1994 Burnt In Fire
White Metal
Factor the price and humbling of going to a dealer/repair shop and saying the car doesn't run right after you "refreshed" the fuel filter in an effort to save $30... It's not like you're building a turbo here, or distilling your own gas; it's a cheap little part.
Dr. Morbid is offline   Reply With Quote
Old 04-07-2005, 02:25 PM   #7
ai42
Member#: 71348
1999 EJ207 RS.TI
VW Golf TDI 40mpg baby!
Hey if you want to save $30 who needs a fuel filter is just lowering your fuel pressure anyway just take a small pipe and bypass the filter completely and while your at it remove the brackets for the fuel filter to save you a couple ounces of weight. Not only that but that should increase your gas mileage 0.02% And the only inconvinenace is that you have to filter you gas before you put it in your tank, just whip out that notebook paper and fold it up whenever you fill up.
ai42 is offline   Reply With Quote
Old 04-07-2005, 03:38 PM   #8
bobby d
Member#: 77989
2005 Impreza RS
Crystal Grey Metallic
The time you spend rigging a home made job you could of made the $30 at work!
bobby d is offline   Reply With Quote
Old 04-07-2005, 04:05 PM   #9
Jejunum
Member#: 15773
2011 Impreza WRX
look for the generic purolator version (there probably is one..) should be half the cost
Jejunum is offline   Reply With Quote
Old 04-07-2005, 04:19 PM   #10
Impretzle
Member#: 74900
1995 Impreza L
I still think it's bull****. All my BMW filters were around ~$12...
Old 04-07-2005, 04:28 PM   #11
TRH_legacy2k
Member#: 66222
2000 Legacy
'68 Spitfire
I did this on saturday...it was 13 bucks or so and 15 minutes of hose prying.
purolator from advance autozone parts america whatever its called now.
TRH_legacy2k is offline   Reply With Quote
Old 04-07-2005, 04:30 PM   #12
bobby d
Member#: 77989
2005 Impreza RS
Well, where are you looking man? The dealer or something? Here are the prices from www.partsamerica.com
Purolator F54668 See image and details for this item
; 16 Valve
Find in a store
Ships in 1 day
Weight: 0.8 lbs.
$15.48
AC Delco GF663 See image and details for this item
Fuel Filter
Ships in 1 day
Weight: 0.1 lbs.
$18.88
Fram G6827 See image and details for this item
Fuel Filter:
Ships in 1 day
Weight: 0.8 lbs.
$20.99
Beck/Arnley 0430979 See image and details for this item
Fuel Filter:
Lifetime Limited Warranty
Ships in 1 day
Weight: 0.7 lbs.
$31.99
Fuel Filter: 1 Per Car
Ships in 1 day
Weight: 0.7 lbs.
$31.99
Old 04-07-2005, 04:57 PM   #13
gtwagon941
Member#: 16874
2008 Audi RS 4
01 Subaru LGT Sedan
I think you should just cut your current one open and put some cotton gauze in there. Hopefully while you are messing around with getting it open you don't create any sparks or anything, as it would seem to me that would be BAD!!!
I get mine at Napa for ~$23.
Jared
gtwagon941 is offline   Reply With Quote
Old 04-08-2005, 05:14 AM   #14
Impretzle
Member#: 74900
1995 Impreza L
Hmmmm thank you all for the jokes / links / inspiration
In tanke fuel filters? or boot fuel filters? HEKTIC Factory 2.5L Turbo Powertrain 3 04-30-2007 04:37 PM
WRX OEM fuel filter, oil filters, other stock parts Blue_Rexer Private 'For Sale' Classifieds 0 07-27-2004 10:44 PM
Tune Up parts, OEM oil filters, fuel filters air filters, spark plugs LangstonSubaru Accessories & Misc 14 05-05-2004 11:49 AM
OEM Oil Filters, OEM Turbo oil filters, fuel filters, spark plugs, air filters LangstonSubaru Vendor 'For Sale' Classifieds 125 03-29-2004 08:25 AM
WRX Part# - Air filter + Fuel filter InfamousDX Service & Maintenance 2 01-13-2004 04:16 AM
Message Board Statistics All times are GMT -4. The time now is 07:56 PM.
