Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 04-08-2005, 07:00 PM   #1
tsquare
Member#: 38228
2003 WRX WGN SNC YLW
W/// Edition
Default UTEC Stage 2 Issue
What should I do here...
I install my UTEC with stage 2 in my car and when the utec takes over my car builds boost but is extremely slow.. probably too much fuel.. But I don't have the ABC that comes with the UTEC anyone know how to fix this issue.. I have tried both closed and open loop boost modes and still no resolution... is there another setting that I have to change?
Thanks in advance!
tsquare
tsquare is offline   Reply With Quote
Old 04-08-2005, 08:08 PM   #2
Gethin
Member#: 2998
You need to follow the directions in the manual. It specifically states you need the ABC. You also need to tune your boost map as the basemaps just have 300 in each location.
Read the UTEC manual in detail, and also Mick's tuning guide (Mick the Ginge).
Gethin is offline   Reply With Quote
Old 04-08-2005, 08:23 PM   #3
hippy
Member#: 36528
2002 Impreza Wrx
Lots of people don't use abc's. What kinda boost are you getting with the basemap? If it's below 16.5psi, then raise the boost value(from 300 in every spot above 20%tps) maybe 25 at a time til you get the boost you want. Ya might also wanna try lowering the gain to 48 or something too.
peace
Old 04-08-2005, 08:49 PM   #4
tsquare
Member#: 38228
W/// Edition
I actually have a MBC on it right now.. you think I should run stock solenoid? until I get the ABC from the previous owner? My MBC is set at 16 psi.
Old 04-08-2005, 11:44 PM   #5
tsquare
Member#: 38228
W/// Edition
any more ideas?
Old 04-09-2005, 03:12 AM   #6
Gethin
Member#: 2998
IMHO the more variables you throw in, without knowing exactly what you are doing and what affect it has, the more chance you have of messing something up. That's my though process anyway, keep it simple, and keep to the TurboXS way of doing things with the stock maps and parameters. Once you get that nailed, then you can start tweaking and changing things around! I'd go with the stock solenoid and get the ABC in there (as Hippy says it's not needed in some cases as the car will reach the desired boost without it, but since they say that's it's required, might as well do it), then you can read the manual and Micks guide and it will make sense. Make sure you are using the constant parameters file with the new maps for 4.2c firmware as it changed when they brought out the 4.2c firware. Also the stock TurboXS basemaps I believe are tuned for 93 octane.
Old 04-09-2005, 10:32 AM   #7
hippy
Member#: 36528
2002 Impreza Wrx
If you're using an mbc alone and still have the problem, then it's obviously not boost related. What are your other mods?
Old 04-11-2005, 12:58 AM   #8
tsquare
Member#: 38228
W/// Edition
so I hooked up everything like factory.. except the ferrel that goes in the hose between the solenoid and the T. and I didn't build anymore than 7lbs of psi. so is my solenoid bad?
Old 04-11-2005, 08:43 AM   #9
hippy
Member#: 36528
2002 Impreza Wrx
No. "Brass restrictor".....
Old 04-11-2005, 04:52 PM   #10
tsquare
Member#: 38228
W/// Edition
actually just got done reading the UTEC quick guide and it says that I don't have to use the UTEC to control boost. So would I just change all the boost setting to ecu? I ordered all the vac hoses and connectors today. that should fix the stock problem!
Old 04-11-2005, 05:20 PM   #11
dosage0
Member#: 42323
2004 WRX
Silver - UTEC, Tuna, TBE
7psi is wastegate pressure.. bet you flip flopped a hose.
dosage0 is offline   Reply With Quote
Old 04-11-2005, 06:53 PM   #12
tsquare
Member#: 38228
W/// Edition
I ordered factory vac hoses today.. so... that should help solve the problem
EDIT:
Ordered hoses with all connectors.
Old 04-11-2005, 07:27 PM   #13
hippy
Member#: 36528
2002 Impreza Wrx
You could definately use an mbc if you want to. The problem isn't with the hoses, it's what's in them. There should be a little brass restrictor in the small hose going from the turbos compressor nipple to the T fitting. Dosage was trying to say that you might have put the hoses back the wrong way with the brass restrictor in the small hose on the wrong side of the t fitting. Do a search for "brass and restrictor" if you have any questions. This is all mute if you are just gonna use your mbc.
peace
Old 04-11-2005, 08:02 PM   #14
tsquare
Member#: 38228
W/// Edition
How do I hook it up with my MBC and not use the stock solenoid?
Do I have to disable boost settings on the UTEC and if so how do I do that?
Old 04-11-2005, 08:51 PM   #15
hippy
Member#: 36528
2002 Impreza Wrx
Just take the hoses off the turbo and roll them up(tie them) under the bcs cover. Use two new hoses, and put them from the turbo to mbc in the right order.......
peace
Old 04-11-2005, 09:20 PM   #16
tsquare
Member#: 38228
W/// Edition
I already have that... and my stage 2 map on my utec sputters.
Old 04-11-2005, 09:22 PM   #17
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
is this a base map?
or a map you have already editted?
do you have mods need to be stage 2?
Old 04-11-2005, 09:26 PM   #18
tsquare
Member#: 38228
W/// Edition
Base map.. my mods are HKS UP/ Helix DP/ Tanabe Hyper Medallion catback/ MBC 16.5 PSI( hooked up direct between wastegate and compressor nipple, not using stock BCS at all)
Old 04-11-2005, 09:33 PM   #19
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
the stage 2 cars, most recent with base maps
from txs were abit on the rich side 10.5 at redline
so if your base map is an earlier version it could
be even richer.
did you check all your hoses around manifold
and tmic?
Old 04-11-2005, 09:35 PM   #20
tsquare
Member#: 38228
W/// Edition
yup... it works find without the utec hooked up.. and I just downloaded the map from their site
Old 04-11-2005, 10:04 PM   #21
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
stumbling which rpm?
Old 04-11-2005, 10:14 PM   #22
tsquare
Member#: 38228
W/// Edition
basically as soon as UTEC takes over
Old 04-11-2005, 10:59 PM   #23
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
basically the timing..
after tuning enough customer cars.
the base maps need some timing adjustment in the 2k to 3k rpms
Old 04-11-2005, 11:01 PM   #24
tsquare
Member#: 38228
W/// Edition
hmmm the boost goes up but the car isn't going any faster. It goes much better with MBC and stock map
Old 04-12-2005, 09:12 AM   #25
hippy
Member#: 36528
2002 Impreza Wrx
Make sure you're using the right parameters and map........ The mbc has nothing to do with it, but you might wanna tie off the long hose going to your bcs in case it's letting air into the intake. Ya might also wanna look into a bad ground somewhere or a air leak between the turbo and throttle body(like a leaky bov).
peace
09 WRX Stage 2 issue blackmist27 Impreza Forum 7 10-27-2009 12:34 PM
09 WRX Stage 2 ISSUE!!! blackmist27 Bay Area Impreza Club Forum -- BAIC 3 10-26-2009 12:32 PM
More Stage 2 issues funkbuster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 02-20-2009 09:28 PM
06 WRX Stage 2 issues ExpO AccessPort 13 12-05-2006 02:56 PM
UTEC Stage 2 times? SleeperWRX Proven Power Bragging 40 03-27-2003 04:15 PM
