Old 04-09-2005, 01:33 AM   #1
rideboarderferg
Member#: 45108
2002 subaru WRX
Default utec knock I think?
I got my UTEC stage 3 tuned at curry's automotive in virginia last week and took my car out to the track tonight. I think im getting knock in 3rd and 4th gear but not sure if thats what it is. In third around 5500 rpms the CEL flickers and goes away and feels like the car doesnt want to pull for a second then goes to normal then same thing in 4th. What is this? Also do you think I should just take it back to the shop and they should fix it for no extra charge or should I expect another tuning charge?
rideboarderferg is offline   Reply With Quote
Old 04-09-2005, 03:58 AM   #2
feiron
Member#: 62327
2005 WRB STI
[S600BY]
you need to log a run on the 3rd and 4th to see what causes the knocks
it can be too much timing advance, high EGT, too lean, too much boost... etc etc
Have the shop check it if you dont have a laptop... but its always best if you have a laptop to work with the utec
feiron is offline   Reply With Quote
Old 04-09-2005, 09:48 AM   #3
rideboarderferg
Member#: 45108
2002 subaru WRX
I just went out for a quick drive at Wot on a new tank of gas and didnt get any knock whatsoever. Im going to datalog tonight and post the sheets but do you think bad gas can cause knock?
Old 04-09-2005, 11:23 AM   #4
AaronWRX
Member#: 7194
2011 997.2 Turbo
why you would take your car to currys for tunning is beyond me. Why didnt you ask the Mid-A forum where to go?
AaronWRX is offline   Reply With Quote
Old 04-09-2005, 03:15 PM   #5
dosage0
Member#: 42323
2004 WRX
Silver - UTEC, Tuna, TBE
knock can be caused by MANY things -- and yes, thats what was happening when the cel flashed. It could have been the gas, the weather was colder or warmer, or its just too aggressive.
The UTEC pulls timing for a few RPMS, that was the lag in power you felt. Its very sensitive and thats a good thing. It will usually pull timing faster than the stock ECU will. If it happens rarely, thats pretty much to be expected. If it happens often you need to tone it down in the areas you are having problems. Usually it just means dropping boost slightly, or taking out a point of timing.
Rob
dosage0 is offline   Reply With Quote
Old 04-09-2005, 05:52 PM   #6
AaronWRX
Member#: 7194
2011 997.2 Turbo
Wirelessly posted (blackberry: BlackBerry6280/3.7.1 UP.Link/1.1)
Post a log for us. Even if you are not knocking now we can still. See what timing you ecu wants to run vs. What the utec wants to run. That can give us an idae where your ecu has seen knock before.
Old 04-09-2005, 11:27 PM   #7
rideboarderferg
Member#: 45108
2002 subaru WRX
im going to try to hook up my laptop but i bought a cable on new egg but it doesnt connect to the utec. So im going to go to best buy and get a belkin one and see if that works then i will post a datalog and my maps
Old 04-09-2005, 11:28 PM   #8
rideboarderferg
Member#: 45108
2002 subaru WRX
o yea and I went to curry's because turboxs recommended them and they were excellent. Really an awesome group of guys.
Old 04-11-2005, 11:13 AM   #9
CurrysAuto
Member#: 44935
rideboarderferg,
If you have any questions at all, do NOT hesitate to call us and/or bring the car back in. You will not incur any additional expenses in this regard and I can promise you that whatever issues you do have will be resolved to your satisfaction. As a matter of fact, call me directly and I'll make the necessary arrangements.
Regards, Bill Shaw
Director of Customer Service
Curry's Auto Service.
571-215-1011
CurrysAuto is offline   Reply With Quote
Old 04-11-2005, 12:18 PM   #10
rideboarderferg
Member#: 45108
2002 subaru WRX
yea i talked to dan this morning. I just wanted to see if it was something else on my car causing the knock before I brought it all the way back in. Thanks though I appreciate it.
04 UTEC Knocking! GMTarkin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-03-2003 03:22 AM
04 Utec knocking!! GMTarkin Engine Management & Tuning 7 08-02-2003 05:16 PM
UTEC Knock Sensitivity Settings AaronC Engine Management & Tuning 1 06-24-2003 06:00 PM
UTEC knock correction Big Turkey Engine Management & Tuning 30 05-15-2003 09:29 AM
Utec knock mikaust Engine Management & Tuning 3 12-01-2002 08:53 PM
