Old 04-09-2005, 12:40 AM   #1
sedeuce
Member#: 84701
2010 Yaris 5dr Hatch
Black Sand Pearl
Lightbulb 2005 WRX WGN + iPod? (pictures)
Hey All-
New Subaru owner (as of 4/6/05); longtime fan. Looking for a solution to bring my iPod into action with the stock 6-disc changer. Hoping there are others of you out there looking to do the same. If you have, please post your findings, info, and resources here.
I dismantled the console and removed the OEM stereo tonight to see what options were on the back. I took pictures of the entire process and have model # info from the stereo.
HU: Model No. 86201FE210
Ref. No. CQ-EF6360A
Matsu****a Electric Industrial Co., Ltd. (made in Japan)
(Matsusheeta)
There is an 8-pin connector on the back. I would like to post a picture but I don't have access to do that yet. Need to post 10 times or something...
Need to figure out what this 8-pin is capable of. Anybody know? How about any manuals of this model HU from Matsu****a?
I would like to include the step by step process with 19 pictures. Especially the picture of the 8-pin connector. Anybody know how I can get past this 10 times post thing?
Thanks,
Sedeuce
sedeuce is offline   Reply With Quote
Old 04-09-2005, 01:16 AM   #2
RodimusPrime
Member#: 82118
2005 GD6 2.5RS
Crystal Gray Metallic
Just post 10 times
J/K
As far as hooking an ipod up - generally that is the easiest to do with an aftermarket deck with a line - in jack on the back.
If you want to keep the stock unit, there are several wiring pin schematics out there. Here is a direct link: http://www.geocities.com/svxdc/WRX-pinout.htm
And here is the thread in which they were discussing this:
http://forums.nasioc.com/forums/show...ht=pin+diagram
If you search for "pin diagram" within the car audio sub forum you should get some good results.
And congratulations on the new car!
RodimusPrime is offline   Reply With Quote
Old 04-09-2005, 11:01 PM   #3
tad_02Wgn
Member#: 66426
Here is a similar thread I started about the 2002 which explains the unused connector.
Unfortunately, I can't find the serial protocol for the comm pin so I'm pretty stuck :-(
Edit: Forgot to post the damn link
http://forums.nasioc.com/forums/showthread.php?t=691652
As you can see, the stock headunit (at least on an '02) DOES have potential for an aux input.
tad_02Wgn is offline   Reply With Quote
Old 04-10-2005, 12:03 PM   #4
TreeSki
Member#: 58626
iPod Index
Click the link above for a wide variety of information regarding installing iPods in Subaru's using both aftermarket and OEM decks...
If you have anything you would like to add to the Index, let me know and I am always happy to add things!
-Tree
TreeSki is offline   Reply With Quote
Old 04-10-2005, 12:36 PM   #5
sedeuce
Member#: 84701
Black Sand Pearl
Default Thanks for replies
I should have pictures up soon - still need to post 8 more times...
Old 05-12-2005, 11:39 PM   #6
sedeuce
Member#: 84701
Black Sand Pearl
Ok, 10 posts are done... Get ready to be bombarded by pictures.
Here is the step by step with pictures. I have 1 important note:
If you do end up removing the shift-knob like I did, put a sock or dish towel over the threaded end of the shifter shaft to prevent possibly scratching any of the nice shiny surfaces of the HU or console bezel pieces! Forunately, mine was very minor.
Started off by removing shift knob - note, you don't actually need to remove the knob from the boot like I did:
Old 05-12-2005, 11:40 PM   #7
sedeuce
Member#: 84701
Black Sand Pearl
Lifted out the boot bezel:
Old 05-12-2005, 11:40 PM   #8
sedeuce
Member#: 84701
Black Sand Pearl
Pulled the bezel/ashtray assembly up to the right (disconnect the plug):
Old 05-12-2005, 11:41 PM   #9
sedeuce
Member#: 84701
Black Sand Pearl
Shot of the lower console internals:
Old 05-12-2005, 11:41 PM   #10
sedeuce
Member#: 84701
Black Sand Pearl
Started the console panel from the bottom right:
Old 05-12-2005, 11:41 PM   #11
sedeuce
Member#: 84701
Black Sand Pearl
Fabric wrapped on screwdriver tip:
Old 05-12-2005, 11:42 PM   #12
sedeuce
Member#: 84701
Black Sand Pearl
Went from right middle to right top left top and then off:
Old 05-12-2005, 11:42 PM   #13
sedeuce
Member#: 84701
Black Sand Pearl
Closeup of HU and 6 screws:
Old 05-12-2005, 11:43 PM   #14
sedeuce
Member#: 84701
Black Sand Pearl
RH side closeup:
Old 05-12-2005, 11:43 PM   #15
sedeuce
Member#: 84701
Black Sand Pearl
Internals under HU
Old 05-12-2005, 11:43 PM   #16
sedeuce
Member#: 84701
Black Sand Pearl
LH side closeup during screw removal:
Old 05-12-2005, 11:44 PM   #17
sedeuce
Member#: 84701
Black Sand Pearl
Sliding out the HU
Old 05-12-2005, 11:44 PM   #18
sedeuce
Member#: 84701
Black Sand Pearl
Rearside Connections:
Old 05-12-2005, 11:44 PM   #19
sedeuce
Member#: 84701
Black Sand Pearl
HU Sticker:
Old 05-12-2005, 11:45 PM   #20
sedeuce
Member#: 84701
Black Sand Pearl
Back of HU:
Old 05-12-2005, 11:45 PM   #21
sedeuce
Member#: 84701
Black Sand Pearl
Bottom left - Talk to SVXdc about this harness (speakers, +, - dimmer):
Old 05-12-2005, 11:46 PM   #22
sedeuce
Member#: 84701
Black Sand Pearl
Bottom right - 8-pin connector and antenna:
Old 05-12-2005, 11:47 PM   #23
sedeuce
Member#: 84701
Black Sand Pearl
Closeup of 8-pin connector (this is the OEM Sub connector):
Old 05-12-2005, 11:47 PM   #24
sedeuce
Member#: 84701
Black Sand Pearl
Looking at the HU harness in the car:
Old 05-13-2005, 12:19 AM   #25
RodimusPrime
Member#: 82118
2005 GD6 2.5RS
Bravo! Nice job on the pictures and write-up.
It is always good to have step by steps like this for people to refer to. Good resolution and good shots of how to take the trim out so you don't scratch it.
So how exactly are you planning on getting an ipod hooked up?
FS : 2006 STi Rear seats theasianeffect Interior/Dressup/Audio & Security 9 06-05-2010 07:59 AM
[SOLD] 2005 WRX Phoenix $9000 boostism Private Vehicle 'For Sale' Classifieds 4 06-02-2010 09:39 PM
Will 2005 WRX seats fit a 93 Legacy Wgn? coolbreeze Interior & Exterior Modification 3 12-24-2008 09:48 AM
FS 2005 WRX WGN SIlver, ABQ, NM steveson Private Vehicle 'For Sale' Classifieds 0 07-14-2008 03:57 PM
Interested in your thoughts of the Legacy GT wgn specifically compare it to WRX wgn. Drew888 Motorsports 25 03-04-2005 01:08 PM
