Old 04-09-2005, 11:42 AM   #1
lilsix
Member#: 67185
2007 Audi S4
4.2l V8
Default utec toggle switches
It says in the manual to have the two toggle switches in the normal position but in the picture you cant tell if that is up or down. Which way are they supposed to be? I was told to have them in the down position when hooking up to pc. Should it always be that way?
lilsix is offline   Reply With Quote
Old 04-09-2005, 05:06 PM   #2
lilsix
Member#: 67185
2007 Audi S4
4.2l V8
Does anybody know this answer?
Old 04-09-2005, 07:03 PM   #3
serendipity
Member#: 54597
08 'Busa, 08 ML63
10 Multistrada, 996 Targa
With the turboXS logo facing the proper way, down = toward the harness = off. So down for the fuel cut toggle means fuel cut is still enabled (at a higher level than stock) and down on the flash toggle means normal operation (no flashing). Normally both should be down and off. If you want to run >22psi of boost, flip up the fuel cut toggle. If you want to flash, flip the flash toggle up, flash it, then flip it back.
serendipity is offline   Reply With Quote
Old 04-09-2005, 09:15 PM   #4
lilsix
Member#: 67185
2007 Audi S4
4.2l V8
ok thanks, so down is the proper position. I was hoping that it was my problem. I cant accelerate with any of my maps loaded. Severe bogging with the base stage 2 map.
UTEC toggle switches.. Is towards the plugs B? 03WRXMA Engine Management & Tuning 0 02-20-2004 03:18 PM
where to buy toggle switches? Will98RS Electrical & Lighting 5 03-13-2003 05:14 PM
Lighted toggle switch? oney01 Car Audio, Video & Security 9 10-13-2002 10:06 AM
Whose installed a toggle switch for thier ABS? Corn-Picker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-15-2002 04:28 PM
Toggle Switches (PIC) funscooby Interior & Exterior Modification 5 01-08-2002 09:48 PM
