Old 04-09-2005, 05:04 PM   #1
BIG GUN
Member#: 49825
2002 WRX WAGON
SILVER
Default COBB AP & FLASHING CEL
I hope that this might save some of you from a bit of frustration.
I had been running Stg.1 - 93 for around 6 mos. w/ a gutted UP. When I added a cat back, and other things, including a Hyperflow TMIC, and tranny oil cooler for my 4eat, I went to Stg.2 -93, w/1.19 map. A couple of mo's. ago
I started getting a flashing cell, when I tried to read it, it showed OBD ????
A friend had a Snap-on reader, and he saw nothing. I fanally went to a mod friendly dealer, and they cleared it, but it came right back. It was driving me nuts. Trey at Cobb gave me a list of possible reasons, that I should check, but they were tedious to do. I had the dealer check again, and they finally pulled a P1301, high temp exhaust. The EGT tapped into #4 header, has never gone over 1400F. I sent this info to Trey, and he got right back, suggesting that if I still had the EGT probe in the UP, [and I did], to do the 1/2 w 2.2k resistor mod. I did, and the CEL went away after I cleared it.
I thought that the AP took care of that cel, but it doesn't. It also took almost a year, after gutting the UP, for it to rear it's ugly head.
This came up shortly after changing my base map to the 1.20 - 93 Rev. so I thought that it might have been that. I changed my base maps so many times, and was about to un-marry the AP, so for a $0.20 resistor, make the mod.
I ended up snipping the cross bars off both those test connectors, so they would not lock in place. They were such a PITA to diconnect, now simple.
Sorry about the rant, but I hope that it helps a few out there
Trey at Cobb, is a true gentleman, and that is worth a lot to me.
Eric
BIG GUN is offline   Reply With Quote
Old 04-09-2005, 09:00 PM   #2
WRXVII
Member#: 15854
VF34'd...
I don't think I will be driving stage 2 WRX when I turn 68...
WRXVII is offline   Reply With Quote
Old 04-10-2005, 07:52 PM   #3
BIG GUN
Member#: 49825
2002 WRX WAGON
SILVER
I only gave up dirt & street bikes, along with atv's, & snowmobiles, a couple years ago, because my wife became a basket case every time I went out for a run. After I lost one leg, she kinda freaked out. I guess she does't think my Rex is a danger. I get my grin's with it.
Your only as old as you want to be. The calendar means nothing. It's a mental thing.
Old 04-11-2005, 09:48 AM   #4
mistaboosta
Member#: 68722
Thanks for the info Eric
I'm sure that will help some people.
mistaboosta is offline   Reply With Quote
Old 04-11-2005, 03:14 PM   #5
MDRex
Member#: 38477
2015 Crosstrek
Orange
A friend of mine had the same issue appear on his Cobb flashed ECU after quite a while, just did the resistor mod and its fine now.
I think what happens is the Cobb flash takes care of the EGT CEL when the probe is working, but after a while it seems that the probe dies and then you get the CEL. That's just my theory anyway.
And props to you Eric, I hope I am as cool and still having as much fun as you are in 40 years. Wonder what the cars are gonna be like then?
MDRex is offline   Reply With Quote
Old 04-11-2005, 04:30 PM   #6
jimmyd
Member#: 38766
2003 WRX Sedan
Originally Posted by BIG GUN
I only gave up dirt & street bikes, along with atv's, & snowmobiles, a couple years ago,........ The calendar means nothing. It's a mental thing.
Dude,
I can only hope to be that active at 68! You are my new hero!
Play hard!
Jimmyd
jimmyd is offline   Reply With Quote
Old 04-11-2005, 05:24 PM   #7
BIG GUN
Member#: 49825
2002 WRX WAGON
SILVER
Think the Jetson's. Levitation, fuel cells, Rocket power, Blast Off!
I'm thinking of an ultralight aircraft now. That should be fun.
Cobb AP won't flash Quackyboy Newbies & FAQs 3 06-12-2009 01:52 PM
Wanted : NY 04 Sti COBB AP & INVIDIA V2 CATLESS DP & MIDPIPE hoonsup2 Private 'Wanted' Classifieds 0 12-08-2006 01:19 AM
WTB: 06 STI COBB AP & COBB CATTED DP FirSTi Private 'Wanted' Classifieds 0 08-13-2006 05:46 PM
Will COBB AP fix the CEL with HELIX DP? BBBsti LTD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-02-2006 11:07 PM
Stage 2 AP and flashing Cel HELP!!! DanBelford Engine Management & Tuning 18 12-08-2005 08:06 PM
