Old 04-09-2005, 05:08 PM   #1
Caplin 2.5
Member#: 71203
2005 2.5rs
Crystal Gray Metallic
Default 05 RS reflash... So Cal
Can anybody help me find out where i can get my ECU reflashed in So Cal, or how do you reflash it? Do you do what it says to do in this thread:
http://forums.nasioc.com/forums/showthread.php?t=302047
Caplin 2.5 is offline   Reply With Quote
Old 04-09-2005, 05:20 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
there is only one place I have heard that reflashes n/a ecus but dont remember where it is, east coast I think, canada maybe...
ispeed is working on a reflash for n/a ecu's
that trick is for turbo cars with a properly mapped ecu as posted in that thread
jay
Old 04-09-2005, 05:29 PM   #3
Caplin 2.5
Member#: 71203
2005 2.5rs
Oh cause i got the intake n headers on and when i rev up i still hear too much popping.
Old 04-09-2005, 06:44 PM   #4
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
I think he means RESET the ECU, not reflash.
Unplug your battery, let the engine cool down, plug it back in and start the engine.
powerlabs is offline   Reply With Quote
Old 04-12-2005, 11:24 AM   #5
Caplin 2.5
Member#: 71203
2005 2.5rs
Whats the difference between Reset and Reflash? I just want my mods to adapt better.
Old 04-12-2005, 11:41 AM   #6
jasonpham
Member#: 84530
2004 Impreza 2.5RS
Platinum Silver Metallic
The ECU learns adaptively to your mods, your driving, and the conditions. So everytime you put another mod onto your car, your ECU takes a while to learn your mod well enough to adjust itself for maximum potential. By resetting your ECU, you basically erase all the learned memory and force your ECU to relearn all your mods much quicker than it would take to just fly with it.
To reset your ECU,
Turn your car off.
Disconnect the battery terminal.
Depress on the brake pedal several times to move the juices out.
Let your car sit for 20 minutes like this.
Reconnect your battery.
Start your engine and let it idle for around 25 minutes.
Then take it out for a drive going through your entire powerband in 1st and 2nd gear.
Continue driving in varying conditions and in a week or so you ECU should be set.
You should also note that you should fill up with your favorite gas and drive around for 40 or so miles before doing this to help your ECU learn your fuel preference and that for a week or so, your mileage will drop significantly.
A reflash is basically a reprogramming of your stock ECU for the purposes of aftermarket engine management. A reflash is similar to a piggyback or standalone engine management system such as a UTEC, however the reflash maintains a 'set and forget' stock feel.
jasonpham is offline   Reply With Quote
Old 04-12-2005, 11:49 AM   #7
Pat L.I.
Member#: 20498
2006 WRX TR
25 minutes is way to long
disconect the battery for about 4-7 minutes. Depress brake pedal if you wish a few times.
reconect the battery and turn the car on... it may stall instantly. but just try again.
do not give it any gas just let it idle for about 3-4 minutes
turn the car off
start it up again and go for a drive using various driving styles from aggressive to calm.
Pat L.I. is offline   Reply With Quote
Old 04-12-2005, 06:49 PM   #8
Caplin 2.5
Member#: 71203
2005 2.5rs
Wow thanks alot ill go try that right now.
Old 04-12-2005, 07:13 PM   #9
Caplin 2.5
Member#: 71203
2005 2.5rs
I just tried it and it still has alotta poppin goin on.... but it feels a little more smoother as i accelerate.
Old 04-12-2005, 07:52 PM   #10
jasonpham
Member#: 84530
2004 Impreza 2.5RS
Drive around for a bit and your ECU will continue to learn your mods. Hope this helps.
Old 04-13-2005, 12:45 PM   #11
Caplin 2.5
Member#: 71203
2005 2.5rs
actually yea it has helped i dont get as much popping when i rev in neutral anymore... just took some more driving around.
Old 06-07-2005, 09:32 PM   #12
wgb113
Member#: 32478
2004 Forester XT
Bringin' back a dead thread!!! Caplin, how'd you make out with resetting your ECU? Has everything returned to normal?
I'm asking because I'm getting ready to install a CAI and custom cat-back.
Thanks,
Bill
wgb113 is offline   Reply With Quote
wrx or rs trunk and/or 04/05 taillights in SO CAL area yoonjaechung Private 'Wanted' Classifieds 2 10-02-2015 11:43 PM
05 WRX WAGON - So. Cal. dacanev Private Vehicle 'For Sale' Classifieds 0 11-16-2006 05:33 PM
2001 2 door RS in so.cal bnj Private Vehicle 'For Sale' Classifieds 0 04-09-2004 02:10 AM
I want to buy a used 2.5 RS in So Cal! Porsche914boxer4 Southern California Impreza Club Forum -- SCIC 21 12-17-2002 05:31 PM
Anyone with a turbo RS in So Cal? Derres Catalano Southern California Impreza Club Forum -- SCIC 5 04-18-2001 12:12 AM
