Old 04-09-2005, 10:03 PM   #1
zigger
Member#: 79674
Default HELP my Sti won't start?
I am freeking out here.. my 04 Sti all of a sudden has no power. The oem car opener lights up but no beep beep so I opend it manually for the 1st time ever..I put the key in and tried to start the car and there was no pwer nothing not even a beep or lights?? What the hell happend over nite? Can anyone please help me out here and what should I do?
Car is dead.. 04 Sti with a Tbe and ecutek 27k miles on it
zigger is offline   Reply With Quote
Old 04-09-2005, 10:05 PM   #2
jaypride
Member#: 33424
2004 STI
Blue/Gold
Sounds like a dead battery. Maybe you left something powered on overnight.
jaypride is offline   Reply With Quote
Old 04-09-2005, 10:09 PM   #3
zigger
Member#: 79674
Default I didn't leave anything on over nite.
Will a boost hel me at all or do I need a new battery? It's a year old car how can I need a new battery??
Old 04-09-2005, 10:18 PM   #4
jetfan2207
Member#: 61950
2008 Outback
big blue wagon
Try to jump start it, if that fails, then take the battery out and bring it to a local shop to be tested out. Like stated above, you probably left a small light on or something that can be simply overlooked.
jetfan2207 is offline   Reply With Quote
Old 04-09-2005, 10:18 PM   #5
G3Red04WRX
Member#: 66611
2007 Trailblazer AWD
3LT Sandstone Metallic
Did you bump your parking lights on accidentally? That little switch on the top of your steering column...
Im pretty sure a jump start will work for you enough to get the car started and taken to a tire and battery type shop so they can test your electical system and tell you if its your battery, or possible a defective alternator (making enough charge to keep the car running, but not enough to recharge the battery)...
G3Red04WRX is offline   Reply With Quote
Old 04-09-2005, 10:24 PM   #6
ktm
Member#: 36003
2006 WRX Ltd Wagon
WRB, Stg 2
Your battery is most likely dead. If you can not open the car with the remote, then you car has no electrical power whatsoever. When the car is off the only source of power is from the battery.
If you can not find someone to jump you, just get a buddy to push you and pop the clutch. You'll fire 'er up after a couple tries and just let the car idle for a bit to recharge the battery.
ktm is offline   Reply With Quote
Old 04-09-2005, 10:27 PM   #7
zigger
Member#: 79674
Default will do!
Thanks guys..
Old 04-10-2005, 01:05 AM   #8
subawang
Member#: 17515
2007 Legacy GT
Brilliant Silver Metallic
I was under the assumption that this doesn't work on "newer" cars anymore as most every engine function is controlled by the ECU. Can anyone verify this to acutally work on later model cars (not bikes)?
subawang is offline   Reply With Quote
Old 04-10-2005, 10:45 AM   #9
edaniele1212
Member#: 71013
2004 WRX STi
Java Black/Goldies
I have pop started my STi a couple times...it works
edaniele1212 is offline   Reply With Quote
Old 04-10-2005, 12:06 PM   #10
fastsubie
Member#: 21999
2012 Wrx
Yes it will work, what will not work is if you disconnect the battery and then try to "pop start" it.
Fess
fastsubie is offline   Reply With Quote
Old 04-10-2005, 03:36 PM   #11
wrxsubaru
Member#: 65133
Yeah you still need to have a little, battery power to make it work, so if any light will illuminate at all you still should have enough.
wrxsubaru is offline   Reply With Quote
Old 04-10-2005, 03:46 PM   #12
sk8artafact
Member#: 49105
If the alternator is dead then the car will run on the battery until its drained out completely. Then you wont even be able to jumpstart it.
sk8artafact is offline   Reply With Quote
Old 04-10-2005, 04:28 PM   #13
CatchMyDrift
Member#: 54523
Update?
CatchMyDrift is offline   Reply With Quote
Old 04-10-2005, 05:16 PM   #14
awilson529
RIP
Member#: 38867
11 Mazda
HAHA... That's what I thought too, at 8 months... Got a Braille and no problems ever since (~1 year later)
awilson529 is offline   Reply With Quote
Old 04-10-2005, 06:31 PM   #15
sdogg3kgt
Member#: 38397
2002 Lovemachine
I got an '04 and the battery has never given me any problems in 22k miles. Jump starting it should work. A new battery never hurts since ours are pretty weak anyways.
sdogg3kgt is offline   Reply With Quote
Old 04-10-2005, 07:50 PM   #16
Supraru
Member#: 23313
99' 2.5Rs
black
Does anyone know how to do anything for themselfs anymore? Even my little sister could figure out, car doesn't have any power then most likely the battery is dead so try to jump start it. What is this world comming to? If I posted something everytime something happened to my car and it's an easy answer then people would definatly know me as someone who can't do anything themselfs.
Sorry for the rant but this is just a little rediculous and a waste of space.
Supraru is offline   Reply With Quote
Old 04-10-2005, 07:54 PM   #17
sdogg3kgt
Member#: 38397
2002 Lovemachine
Yeah because everybody who posts on a car forum is an expert like yourself. I'm not saying that a dead battery wouldn't have been my first guess. But for gods sake give the guy a break. You don't know him. This might be his first new car purchase and he might be worried something is wrong.
This thread is less of a waste of space than your dumbass reply.
Old 04-10-2005, 11:03 PM   #18
dubrXSti
Member#: 49541
Trapped in a
glass box of emotion
Check the battery connections as well, get the battery tested and make sure nobody got in your bay and jacked somthing pretty.
dubrXSti is offline   Reply With Quote
Old 04-11-2005, 12:23 AM   #19
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
my friend just had this happen yesteray too i think its the connection at the terminal
99subi is offline   Reply With Quote
Old 04-11-2005, 12:42 AM   #20
gjhsu
Member#: 12329
2o15 WRX
Ice Silver
my battery pooped out after a year and a half. 8000 miles. So I got a Sears special, and now it's going on 3 and a half years.
gjhsu is offline   Reply With Quote
Old 04-11-2005, 07:51 AM   #21
lowendfrequency
Member#: 69139
2004 WRX STi
How the hell do you own an STi and not have the knowledge to realize you have a dead battery?
lowendfrequency is offline   Reply With Quote
Old 04-11-2005, 07:58 AM   #22
Vacca Rabite
Member#: 55491
WRX, 1968 Jeep m715,
1976 VW Porsche 914
Newsflash - most of the people that buy an STi are getting it cause its fast and looks kinda furious. Buying a car, even a subaru, does not instantly make you an automotive god. If you have got the cash, then you have got the car. There is no test involved....
Zach
Vacca Rabite is offline   Reply With Quote
Old 04-11-2005, 08:05 AM   #23
2fst4u2c
Member#: 57589
2011 WRX
A Blu Hue
It's a 2004. .. .. . . he might have been confused as to how new it is. This would have alot of people baffled. Relax. . .don't post if you can't help but by being a pp.
2fst4u2c is offline   Reply With Quote
HELP!!! My swap won't start... Clicking starter? NicFunkadelic Subaru Conversions 27 04-24-2010 01:43 AM
HELP!!! my car won't start... snthorne Service & Maintenance 8 04-04-2006 02:06 AM
HELP!!! My car won't start! snthorne Engine Management & Tuning 0 04-03-2006 09:47 PM
HELP!! My car won't start??? awdlifestyles Vancouver Impreza Club Forum -- VIC 26 09-07-2005 06:47 PM
