Old 04-09-2005, 10:05 PM   #1
Impreza2003
Member#: 67247
2003 2.5RS BRP
SQC 189
Default non loud power mods?
in a goal to get some more power out of my awesome 165hp beast i consult you NASIOC!
i know of 2 mods which I can do but I dont want all the extra loudness which comes from it.
Current power:
Greddy Evo cat back
Autospeed light weight crank pully
Im not going to do
CAI - Unless its Cobb and I can get it for under $150
Headers - its going to make the car too loud
anything i can do to make the car faster but not louder?
i was thinking about an S-AFC but i dont think my mods are enough for me to need one.
Thanks
Allan
Impreza2003 is offline   Reply With Quote
Old 04-09-2005, 10:23 PM   #2
orndog
Member#: 34670
2013 No gears!
Saltine American
Remove weight.
orndog is offline   Reply With Quote
Old 04-09-2005, 10:40 PM   #3
svek
Member#: 82259
1999 impreza 2.2L
Brilliant Red <4EAT Club>
http://www.pdm-racing.com/products/subaru_corner.html
its almost to the bottom. its the shiny intake kit. $70
svek is offline   Reply With Quote
Old 04-09-2005, 10:41 PM   #4
Nicklbrso
Member#: 44887
00 GC6
Fast cars are loud.
Nicklbrso is offline   Reply With Quote
Old 04-09-2005, 10:56 PM   #5
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
light weight flywheel.
springs, struts, anti-roll bars, endlinks, wheels, tires, camber plates, bushings, short shifter, brakes..... etc. etc. etc...
Crash477 is offline   Reply With Quote
Old 04-09-2005, 10:58 PM   #6
svek
Member#: 82259
1999 impreza 2.2L
not power mods...
Old 04-09-2005, 11:09 PM   #7
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
Thanks
Allan
Old 04-10-2005, 02:57 AM   #8
Jesse00
Member#: 78036
02 Impreza 2.5TS
Midnight Blue
Thanks
Allan
Theres 2 ways I can have you to do if you want power without hearing your loud beast screaming in the highway:
Method 1
If you are the one that doesn't want to hear your car screaming, use earmuffs - they work.
Method 2
If you want others not to hear your car yelling at them, make it go even louder and make them all deaf. That way, they will never hear the loudness again. Oh, almost forgot, wear earmuffs so you don't get ur ears hurt in the process.
There are no best of both worlds. You get power or you get sound. If you want to make your car faster without sacrificing the quietness theres only one way: remove useless weight. Only changing your power to weight ratio will help you go faster. For example, dont take a 200lb granny for a car ride. CF hood and trunk. Use lightweight metals (alloys) for your wheels. Remove passenger seat or use Racing seats. These are just things that popped up my head. In summary, CHANGE POWER TO WEIGHT RATIO
Jesse00 is offline   Reply With Quote
Old 04-10-2005, 05:54 AM   #9
silver04rs
Member#: 38825
if u want power on your RS hers what you do.... get the cobb equal lengeth headers,a stock axle-back from a WRX or a STI, K&N filter, and a crank pully which you already have. this will make your car faster but not fast. IMO do your suspension first, at least a rear sway bar.
travis- the gravel crew
www.gcrallyx.com
silver04rs is offline   Reply With Quote
Old 04-10-2005, 01:42 PM   #10
Handsdown
Member#: 29355
if you get equal length headers but keep the stock catpipe, it won't be that much louder.
other than that, nitrous.
or high compression pistons.
or cams.
pretty much, there are no silent and inexpensive ways to make it fast.
Handsdown is offline   Reply With Quote
Old 04-10-2005, 02:16 PM   #11
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
You could swap in a WRX motor and keep the exhaust stock. Thats ganna be the only thing that will really give you a lot more power.
RS_to_WRX_swap is offline   Reply With Quote
Old 04-10-2005, 03:27 PM   #12
Impreza2003
Member#: 67247
2003 2.5RS BRP
SQC 189
well i thought about the weight ratio stuff... i personally lost about 20lbs... so that'll be the equivlent of a CF hood... just kidding
i got 2 years till my lease is over so i'll just keep it this way and i'll just make sure the next car is fast.
Thanks for the responces
Old 04-10-2005, 05:32 PM   #13
allsubaru83
Member#: 60122
1986 911 Turbo
Guards Red
if you put an exhaust on it will be louder! the best way to get more power would be to make the car breath better, ie, exhaust, header (equil length), intake, pulleys are a good idea too, a chip would help a bit too. good luck.
allsubaru83 is offline   Reply With Quote
Old 04-10-2005, 10:44 PM   #14
BoneStockTS
Member#: 80670
Originally Posted by Nicklbrso
Fast cars are loud.
Not necessarily. Someone who's not a brainless prat can design a high-flow low-noise exhaust.
BoneStockTS is offline   Reply With Quote
Old 04-12-2005, 02:40 AM   #15
poormansporsche
Member#: 79798
Fast cars are loud.
BMW M3 thing has like 340 HP and is way quieter than my 2.5RS. Well ok mine isn't the best example but it's damn quiet when you're not gettin on it.
cheers
garrett
poormansporsche is offline   Reply With Quote
Old 04-12-2005, 04:06 PM   #16
Zen
Member#: 12656
There's power to be had with the ECU
Zen is offline   Reply With Quote
Old 04-12-2005, 04:56 PM   #17
Handsdown
Member#: 29355
please explain.
the only ecu reflash i'm aware of is the i-speed reflash, which amounts to about 10-12 hp. this is about enough hp to get you even with a V6 mustang in the quater mile.(open to speculation, what i really mean is that 12 hp isn't much- especially for the exorbenantly high asking price of an i-speed reflash)
it's been said time and time again that piggyback ECUs that regulate the A/F mixture don't work so well due to open/closed loop operation on newer ECUs.
what do you mean there's power to be had?
What non-turbo/ecu mod upgrades exist for more power (STi) XFD Newbies & FAQs 64 09-02-2009 09:13 AM
FS: 04 STi, $26.5K, -power mods, +tech mods tails NWIC Private Classifieds 8 08-04-2006 09:45 PM
FS: 04 STi, $26.5K, -power mods, +tech mods (Seattle) tails Private Vehicle 'For Sale' Classifieds 0 06-30-2006 03:36 AM
*LOUD* DIY mod! semaj Vancouver Impreza Club Forum -- VIC 94 06-28-2006 03:40 PM
want loud powerful cheap exhaust WRX dark knight Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 02-04-2002 10:39 AM
