Old 04-10-2005, 12:03 AM   #1
jefersun
Member#: 37716
2002 ej257 Black WRX
Default Compression test yields disturbing results...(pics)
mods:
vf22
utec w/ tuna
Gt spec genII header and uppipe
TBE
So i thought i blew my motor, but now i'm having different thoughts. I kept getting this loud ticking sound that seemed to be coming from the middle of the motor, so i look under the car. It seems to be louder near the center, like where the oil pan is. I was thinking rod knock of some sort, or my crank, but i don't know.... I didn't think i could drive it, but i gave it a shot, and drove it for 30 min. I took off the belts that go on the alternator and a/c to see if it had anything to do with the idler pulley, but the car ran the same with both belts off. I floored it in 1st and 3rd, and got up to 18 psi and it was fine. The CEL was ticking occasionaly, giving me 01 counts of knock occording to the Utec. I scanned it after i cleared the codes and got p0304, 02, 03.... all misfires in those respective cylinders.
Now the car doesn't tick at all. I can drive it around town, as i am doing, and it is fine. The only thing is, is that after i floor it, i get a slowly ticking CEL, meaning misfires. I just came back from doing a compression test, here are the results:
145 ------------ 60
140 -------------- 145
I don't know which # each cylinder is, but thats the compressions in those respective cylinders. Obviously the cylinder with 60 psi is blown. While doing the test, i found oil on all of my plugs, with varying degrees, but plug that was in the 60 psi socket had an IMMENSE amount of oil. Here are some pictures:
Going from bottom left clockwise:
(140 psi cylinder)
(145 psi cylinder)
(60 psi cylinder)
(145 psi cylinder)
Some other interesting pics i found:
downpipe area
left heads (look from front of the car)
right heads
Behind intercooler
Any thoughts on what it most likely is?
jefersun is offline   Reply With Quote
Old 04-10-2005, 12:28 AM   #2
Blitz04
Member#: 28099
05 CLK320
blown ring? try wet compression test 60psi cyl
Blitz04 is offline   Reply With Quote
Old 04-10-2005, 12:45 AM   #3
jefersun
Member#: 37716
pics are up (sorry for the troubles), what you mean wet compression test? Why do you recommend that?
Old 04-11-2005, 09:58 AM   #4
mistaboosta
Member#: 68722
look at that plug, that knocks
mistaboosta is offline   Reply With Quote
Old 04-11-2005, 10:17 AM   #5
KGreb
Member#: 13463
2005 LGT
2004 FXT
Wet compression test means add about a teaspoon of oil to the cylinder and re-check. The oil helps rings seal. If the wet compression results go up, you typically have ring problems. If it doesn't, you typically have valve problems.
KGreb is offline   Reply With Quote
Old 04-11-2005, 08:33 PM   #6
HIREN
Member#: 51633
2013 GT-R
HIREN is offline   Reply With Quote
Compression test yields disturbing results... jefersun Factory 2.0L Turbo Powertrain 17 04-12-2005 02:15 AM
Compression test yields disturbing results...(pics) jefersun Texas Impreza Club Forum -- TXIC 21 04-12-2005 01:22 AM
EJ25 Compression Test Results at 50,000 miles latinskllz Normally Aspirated Powertrain 4 11-11-2002 02:46 PM
Compression Test Results- 3 Motors dug-e-fresh Factory 2.0L Turbo Powertrain 15 10-31-2002 11:32 PM
Compression test results numbers Imprezer Factory 2.0L Turbo Powertrain 12 09-12-2001 01:08 AM
Message Board Statistics All times are GMT -4. The time now is 06:53 AM.
