Old 04-10-2005, 03:05 AM   #1
Really_Soaked
Member#: 4992
2000 Impreza 2.5 RS
Blue Ridge Pearl
Default AEM 2.5RS + WRX Heads
I've got an EJ25 motor with WRX top end. What do I need to do in order to get an AEM EMS to plug into the existing wiring harness? I tried doing a search, but alas it yielded no results.
Really_Soaked is offline   Reply With Quote
Old 04-10-2005, 02:52 PM   #2
SlowerWrX
Member#: 84683
Default Not Fun
Yes you can get it to work but its going to be a pain in the ass. If the plugs on the end of your 2.5rs wiring harness is diffrent from that of a wrx then you are going to have to get the plugs for a wrx. Then you are going to have to get a pin out for both cars and put the wires from the 2.5rs harness in the appropriate holes on the wrx plug.
Best of luck
Matt
SlowerWrX is offline   Reply With Quote
Old 04-10-2005, 05:37 PM   #3
Really_Soaked
Member#: 4992
2000 Impreza 2.5 RS
Blue Ridge Pearl
It's either that or building my own harness. I imagine it's the lesser of the two evils.
What are the differences in sensors between them? I know I have to get a 2 bar MAP sensor to start with...
-Simon
Old 04-10-2005, 06:23 PM   #4
SlowerWrX
Member#: 84683
Default Sensors
There are some sensors you might as well replace anyway, For example
Map Sensor= AEM 3.5 Bar Map
IAT= GM IAT sensor
EGT= AEM EGT
Etc....
Changing the plugs is basically the same as building your own harness, either way its alot of tedious(sp?) work.
Matt
Old 04-11-2005, 01:55 AM   #5
snwman
Member#: 72680
2013 Subaru STi
Satin White Pearl
your gonna need the GM Boost control solenoid also. The only way I can see doing this would be depin your current plug and place the pins into the wrx plug or make and adapter harness that would make it easy to go back to stock ecu if needed.
snwman is offline   Reply With Quote
Old 04-11-2005, 10:06 AM   #6
mistaboosta
Member#: 68722
is it the same precedure for someone that wants to make a 2.5 sti shortblock swap or 2.2 shortblock swap
mistaboosta is offline   Reply With Quote
Old 04-11-2005, 11:42 AM   #7
snwman
Member#: 72680
2013 Subaru STi
Satin White Pearl
as long as you leave the wrx heads when you change the block on a wrx from the 2.0 to 2.2 or 2.5 you should be fine and not have to do anything else. right now no one has the aem setup to run AVCS heads.
Old 04-11-2005, 05:08 PM   #8
SlowerWrX
Member#: 84683
Default no no no
He has a 2.5 rs, he is going to have to repin the harness with the WRX plugs. If you were just swapping a 2.5 or 2.2 block into your wrx then you wouldnt have to change anything. The computer has no idea what displacement engine you are running.
DFW: RBP 2.5RS Spotted Heading South on 35N! Spider Pig Texas Impreza Club Forum -- TXIC 1 08-29-2006 08:36 AM
2.2+wrx heads need cams as badly as 2.5+wrx heads? Davenow Subaru Conversions 8 04-13-2005 10:52 PM
2.5RS DOHC Head Gasket Job Parts List Chuck Normally Aspirated Powertrain 28 12-15-2002 05:06 PM
SRP 2.5RS Sedan Heading onto I84E, Spotted & thumbs up moss Tri-State Area Forum 13 08-20-2002 12:28 AM
