Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 04-10-2005, 03:13 AM   #1
jamba
Member#: 79759
03 Baja
Question 15" wheel for baja???
Does anyone know if there is a 15 inch wheel that will fit a baja?
jamba is offline   Reply With Quote
Old 04-10-2005, 09:08 PM   #2
Chris N
Member#: 5322
07im +07Leg+00Forest
Scooby wrench turner
The 96-2001 Impreza Outback Sport came with steel 15s. Lots of the later Legacys came with 15s also. Pick one up at the junk yard and see if it will squeeze over the calipers.
you're gonna put 30x9.50s on aren't you!?! or maybe the 29 inchers, even the 27inchers would be sick on a Baja.
Chris N is offline   Reply With Quote
Old 04-10-2005, 10:57 PM   #3
sir_wagon
Member#: 71549
The Impreza '04 TS wagon also came with 15-in wheels. What size are the disc brakes on your Baja?
sir_wagon is offline   Reply With Quote
Old 04-11-2005, 01:51 AM   #4
jamba
Member#: 79759
03 Baja
Chris,
you're on to me I've been found out...
actually the 225/70s have a 28.3 dia
thanks for all the great info guys!!!
Old 04-11-2005, 07:16 AM   #5
holland_patrick
Member#: 72014
05 Baja gone
Winner best wax job 06WBM
it's a tight fit with the front rotors I'm not too sure it would work
holland_patrick is offline   Reply With Quote
Old 04-11-2005, 10:53 PM   #6
kx200
Member#: 52305
2004 Baja Turbo
Monterey Silver
My sister had some stock Outback 15" alloy rims with some winter tires. I mounted them on the rear and they fit fine, only to try the other ones on the front and found out the brake calipers rub on the inside. I should have done the front ones first oh well it good practice.
kx200 is offline   Reply With Quote
Old 04-12-2005, 06:06 AM   #7
Chris N
Member#: 5322
15" steels might work as alloys take up alittle extra space. How bad were they rubbing? Is it worth considering shaving a weee bit off the caliper?
Old 04-19-2011, 10:59 AM   #8
PenguinSub
Member#: 271739
Hey, are there any updates on this? I'm really curious about how this turns out.
PenguinSub is offline   Reply With Quote
Old 04-19-2011, 11:40 AM   #9
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
I just tried to fit standard Subaru 15" wheels on the front of my Baja 2 days ago, they DO NOT FIT. Spacers will not help as it is the diameter of the rotors and calipers that is the problem. You will need to downgrade your front brakes to Impreza (non-WRX) caipers and rotors for them to fit, otherwise you will need to buy expensive rally wheels that fit over the larger WRX/Outback/Baja brakes.
On another note, I am selling those wheels since they do not fit, if anyone is interested. $50 with tires included.
Samirr76 is offline   Reply With Quote
Old 04-19-2011, 12:00 PM   #10
PenguinSub
Member#: 271739
That is definitely good to know. Also, post the wheels for sale on newenglandsubarus.com. you might snag a buyer.
Looking for 17' Wheel for BAJA Turbo Kc2Buk Baja Forum 58 06-08-2005 10:35 AM
15" wheels for sale by any SC folk? IronMonkeyL255 South East Region Forum 1 08-22-2003 06:38 PM
looking for 15" wheels for my snow wheels?? k2snow Brakes, Steering & Suspension 1 08-09-2002 01:36 PM
15" wheels for WRX... (Compomotive MO?) phillyrollin Brakes, Steering & Suspension 0 01-20-2002 09:03 PM
15" wheels for big brakes? peepshow Brakes, Steering & Suspension 2 08-02-2001 04:29 PM
