#1 |
Member#: 5081
NESIC
Vehicle:2010 STI Dark Grey |
Anybody figure out whether the closed loop boost control was linear? I want to ramp up my boost as I transition from ECU to UTEC control. I would also like to put reasonable values in the parts of the map that are difficult to actually get to on the street. Hopefully, it is something like adding 25 to the map adds another psi of boost. Or at least can you do a ratio of map number to psi and come up with a psi per whatever those map values are?
#2 | |
Member#: 42323
Vehicle:2004 WRX Silver - UTEC, Tuna, TBE |
#3 |
Member#: 36528
Vehicle:2002 Impreza Wrx Silver |
Since the threashold for closed->open loop fueling is throttle position and not boost, you will never know what the boost will be when transitioning, and will not be able to transition the boost smoothly between them. Course, the boost at part throttle and during transition is usually below wastegate pressure, so even if you could determine what the boost would be while transitioning, you probably wouldn't be able to control it.
peace |
#4 | |
Member#: 5081
NESIC
#5 |
Member#: 29201
NESIC
Vehicle:BMW M3 Honda S2000x2 |
The equation (if there even was one) would have far too many variables to be accurate. PM me if you have problems tuning your boost map. I'm local and I might be able to help you out.
Pete |
| Thread Tools | |
| Display Modes | |
| Close Loop Boost vs. Open Loop Boost | chuglobal | Engine Management & Tuning | 35 | 10-27-2004 03:07 PM |
| UTEC Closed loop boost accuracy | DocDetroit | Engine Management & Tuning | 38 | 04-22-2003 12:37 PM |
| UTEC closed loop boost gain setting | mick_the_ginge | Engine Management & Tuning | 6 | 03-19-2003 09:47 AM |
| utec closed loop... | WRX Jim | Engine Management & Tuning | 1 | 03-18-2003 06:01 PM |
| UTEC Closed Loop Boost Maps | peterex | Engine Management & Tuning | 45 | 01-16-2003 12:07 AM |
