Old 04-10-2005, 12:46 PM   #1
Mancini
Member#: 20726
Default UTEC and road course tuning
I did a lapping day yesterday, first time with the UTEC and TBE on and I have a question about the 0% timing load site.
I had the timing in the 0% load site locked down from 4750-7250 to prevent shift knock. I noticed that my EGTs were skyrocketing to over 900C when maintaining light throttle accel during certain sections of the track...my thought was that it was the locked down timing causing this.
So, between sessions I edited the map and put the ECU in charge of timing in the 0 load sites. EGTs were fine but on a few sections I noticed I was getting shift knock when I lifted off throttle. So I'm kinda stuck between a rock and a hard place when it comes to the 0% column. Any suggestions?
Thanks,
Brian
Mancini is offline   Reply With Quote
Old 04-10-2005, 01:17 PM   #2
jstbstn
Member#: 35020
2002 WRX - stage WTF
1992 JDM WRX Satan Black
you could try lowering your TPS crossover point if you have it set higher so that it goes into OLF and into the 10% column quicker. If necessary you could probably edit the timing in the 0% to be a slightly higher value closer to what the ECU would want to run... just my 0.02
jstbstn is offline   Reply With Quote
Old 04-10-2005, 07:17 PM   #3
hippy
Member#: 36528
2002 Impreza Wrx
You could try adding fuel above 5000rpm.
peace
Road Coursing and Star Spec Tread purduephigam Tire & Wheel 17 06-18-2009 06:18 PM
FL:4/21/09 PBIR test and tune on the road course DoctorNick South East Region Forum 18 04-23-2009 03:16 PM
Track Day Road Trip HARRIS HILL ROAD COURSE Andres van der Dys Texas Impreza Club Forum -- TXIC 27 12-13-2008 02:53 AM
on road course, any success with HPS on rears and Panther Plus on fronts? homiusang Brakes, Steering & Suspension 1 04-11-2006 12:44 AM
Which road course has the Arch? Porter Motorsports 9 05-09-2001 07:40 PM
Message Board Statistics All times are GMT -4. The time now is 10:47 AM.
