Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 04-10-2005, 01:34 PM   #1
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
Default Can the hydra pass OBD2 emissions?
If the Hydra can be made to give a pass to OBD2 testing i think i am going to move towads that from my UTEC. I feel this would create a long term solution to emissions testing because that is what it will all be eventualy.
can anyone give me a firm answer?
thanks
-luke
lukeskywrx is offline   Reply With Quote
Old 04-10-2005, 01:41 PM   #2
supermarkus
Member#: 6971
2008 WRX STi
SSM
If you want to retain OBD2 function, you'll need a reflash. You lose it with the Hydra.
supermarkus is offline   Reply With Quote
Old 04-10-2005, 04:23 PM   #3
serendipity
Member#: 54597
08 'Busa, 08 ML63
10 Multistrada, 996 Targa
Or a piggy-back. UTECs for example don't interfere with OBD2 operation.
serendipity is offline   Reply With Quote
Old 04-10-2005, 05:37 PM   #4
bboy
Member#: 56468
04 Improved STI
Dirty White
I would not make any bets on your local government making changes such that OBDII is required for emissions testing. Very few states "require" the OBDII reading to pass emissions. My car with the Hydra installed can pass WA State emissions without OBDII in place. Passing emissions is all about idle and closed loop fueling here in WA State, test are done on a "dyno" of sorts with a sensor up the tail pipe.
Old 04-10-2005, 07:25 PM   #5
supermarkus
Member#: 6971
2008 WRX STi
SSM
OP said he was looking to get away from the UTEC. XEDE is another piggyback that might work well for him.
Old 04-10-2005, 07:34 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
FYI NJ, PA and NY are states that now do OBDII inspections. More are sure to follow.
Old 04-10-2005, 07:43 PM   #7
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
According to the state of WA emissions FAQ, they use OBDII testing on all cars 1996 and newer. I believe every state that does emissions testing now does it first by OBDII and some allow you to take a secondary sniffer test. Most however do not. WI and IL here just recently cut back staff and hours at testing facilities since doing the OBDII scan is so much faster.
Old 04-10-2005, 07:43 PM   #8
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
As of like 2003, there were 20+ states that did OBDII testing.
Old 04-10-2005, 07:55 PM   #9
hondaeater69
Member#: 60324
To say PA as a state does it is false. Only counties that meet certain population requirements have to do emissions testing in PA. My little ol county of pike does not do any
Old 04-11-2005, 01:56 AM   #10
snwman
Member#: 72680
2013 Subaru STi
Satin White Pearl
WA state does OBDII testing on 1996 and newer as stated above, I Just took in my old car 2000 and they did OBDII testing only.
snwman is offline   Reply With Quote
Old 04-11-2005, 09:57 AM   #11
happasaiyan
Member#: 37731
sounds like you might be screwed, bboy
happasaiyan is offline   Reply With Quote
Old 04-11-2005, 07:42 PM   #12
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
So are '95 and older cars (OBD I etc.) exempt from emmissions testing in WA? Sounds like it.
I'd say that you'd be fine in all states except CA as long as you have a cat. Where do you live?
Pete
eastcoastbumps is offline   Reply With Quote
Old 05-03-2005, 09:14 PM   #13
hatchy
Member#: 36852
2004 STI
You aren't even allowed to breathe hard in CA.
hatchy is offline   Reply With Quote
Old 05-03-2005, 09:58 PM   #14
JRJ WRX
Member#: 34409
03 WRX WRB
Delaware checks OBD2. They check to see if all readiness codes are set and for faults(check engine). Oh and to answer your question if the Hydra will pass OBD2. No.
JRJ WRX is offline   Reply With Quote
Old 05-04-2005, 12:13 AM   #15
seattle944t
Member#: 18308
2005 WRX STi
Pete
No, the older cars just get the standard sniffer test.
seattle944t is offline   Reply With Quote
Old 05-04-2005, 12:32 AM   #16
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
You should be able to get an inspector to do a sniffer test rather than an OBDII test in some states.
Old 03-27-2006, 11:20 PM   #17
NorCal11.7
Member#: 55879
2000 Impreza 2.5 rst
Blue Ridge Pearl
now how would someone go about with their car if they have a hydra and need to get their car smogged? what if the car passes the sniffer test? can it then be sent to a ref show that their are no CEL or any other malfunctions? im in CA by the way with a 2k 2.5rs with a hydra...
NorCal11.7 is offline   Reply With Quote
Old 03-28-2006, 09:53 AM   #18
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Let me start off by saying no aftermarket ECU is OBD2 legal. You can get a very stiff fine no matter what ECU you choose to run if you get caught.
With that said the Hydra EMS does not have OBD2 so nothing will show if an OBD2 reader is plugged in. I have heard of some playing stupid and a tail pipe test was substituted. All counties are different in regards to OBD2 testing or emissions. For example I had a car get an exemption because it was too low to drive over the dyno rollers
What I did with my Hydra equipped car to pass the OBD2 test was to reinstall my catalytic converter, stock injectors, and OEM ecu. I drove under 60% TPS on the highway for about 30 seconds above 50 mph, pulled over, turn off the car, and repeated 4 times. This set all my readiness codes except one. In MD you are allowed to have one readiness code "incomplete" and pass. I took it straight to the testing center and voila passed.
I would say this whole process took about 2 hours to install a cat, oem ecu, and oem fuel injectors (STI side feeds are great!). To do this once every two years to ensure I have the best possible ECU for the level of modifications to my car is well worth it.
I have heard from my other customers that they just run a "big MAF" so they don't even need to swap the injectors.
Hope this helps.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 04-07-2006, 02:59 PM   #19
0db
Member#: 33879
2003 WRX Sporkwagon
I'm with Phil... it's not THAT much work on a once-every-two-years basis to bring your car back to a "nearly stock" state for testing. I remember pulling an entire AEM system AND turbo kit off my integra in about 3-4 hours before smog test.
An added benefit to this is that driving your car stock for a week or so really reminds you how far you've come. We all have a way of getting "adapted" to our mods.
0db is offline   Reply With Quote
Old 04-07-2006, 03:19 PM   #20
Chav
Member#: 3269
2001 2.5RS Sedan STM
RSTi
The Georgetown inspection station does not use OBD 2 as of January 06. I know because I passed with a sniffer.
-Chav
Chav is offline   Reply With Quote
How to pass OBD2 Emissions w/ JDM v5 EJ207 engine? deviantek Newbies & FAQs 6 03-27-2008 06:26 PM
OBD2 emissions and the Bugeyed WRX w/minor mods. GTG! gpd323 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 03-14-2007 09:45 PM
stand alone ecu obd2 emissions test passing?!?!?! raydadick Engine Management & Tuning 7 12-10-2003 08:30 AM
stand alone ecu obd2 emissions test passing?!?!?! raydadick Pre-2002 Factory Turbo Powertrain 1 12-09-2003 08:25 PM
Just passed OBD2 emissions in Raleigh with one cat--WOOT! Electronsmurf South East Region Forum 6 08-16-2003 11:26 PM
