Old 04-10-2005, 06:48 PM   #1
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Default 97 Impreza 2.2 Cyl 2&4 misfire CEL HELP
Ok, heres some history, the car ran perfectly up until last weekend. I pulled my motor to swap a timing belt and a clutch. The engine was also cleaned and hosed off (not pressure washed) after it was reassembled. Since then I have been getting random CEL's for misfire on CYL 2 and 4. They ALWAYS happen at the same time and only seem to happen while the car is idling. In addition, when I start the car cold and rev it or drive it it sounds like it is missing or something. This starts at around 1.8k RPM if I go anything more than ~15% throttle. This stops and the car runs perfectly approx. 4 or 5 minutes after I start it. The car continues to run perfectly even when the CEL comes on. Sometimes the light flashes and sometimes it just comes on solid.
I suspect the coilpack is behind this but I dont understand why its two cylinders at once. Anybody have any ideas?
dexterous is offline   Reply With Quote
Old 04-10-2005, 09:02 PM   #2
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
usually a coil affects companion cyl., like 1 and 2 at once or 3 and 4 at once. 2 and 4 is both driver cylinders, so either you got water in both plug wells or two bad wires, etc. if the cam was off a tooth it would run pretty bad, all the time, good luck....
00Maddog is offline   Reply With Quote
FS: 97 impreza L 2.2 for sale or parts motorhead1359 NESIC Private Classifieds 22 12-14-2010 04:18 PM
Help me- ? about 97 impreza wagon 2.2l prays4snow Service & Maintenance 5 08-14-2010 11:14 PM
FS: MD 97 Impreza L 2.2L very clean kromHASaWRX Private Vehicle 'For Sale' Classifieds 5 09-15-2008 12:12 AM
FS: 97 impreza L 2.2 coupe beat22 NESIC Private Classifieds 68 12-29-2006 12:20 PM
97 impreza L 2.2 AWD redford Private Vehicle 'For Sale' Classifieds 0 12-27-2006 12:19 PM
