Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 04-10-2005, 10:24 PM   #1
Oldalfaguy
Member#: 45091
2004 STI
Silver (Stealth)
Default How to Remove those Ugly Cone Scrapes?
I've developed a few nasty little cone scrapes from AutoXing (yeah, I know your not supposed to hit them...) and was wondering if anyone had any suggestions on how to get them out. Most are on the left and right sides of the front spoiler.
Thanks,
John
Oldalfaguy is offline   Reply With Quote
Old 04-10-2005, 10:28 PM   #2
ranger5oh
Member#: 77752
5Sti 2005 Sti
Did you try rubbing compound and an orbital buffer? Ive gotten some scuffs off that way.
ranger5oh is offline   Reply With Quote
Old 04-11-2005, 03:16 AM   #3
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
try using a lacquer thinner and light rubbing to get off any foreign substances (rubber from the cone, etc.) then if the scratches aren't too deep, use something like meguiars scratch-x or 3M swirl remover, it will work even better with an orbital buffer. if that does it, just wax over and you are good to go. If not, you might consider getting the panels repainted or maybe wetsanded by a body shop.
boost junkie is offline   Reply With Quote
Old 04-11-2005, 09:16 AM   #4
Oldalfaguy
Member#: 45091
2004 STI
Silver (Stealth)
I was considering that but wary b/c of the thin Subie paint. I'll get some today and give it a try.
Thanks,
J
Old 04-11-2005, 10:56 AM   #5
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
Most cone marks are just a small deposit of cone rubber on the paint rather than any sort of paint scuff or damage. Sometimes i can just rub the rubber off with my hand, other times i do need take the random orbital to it. Random orbits (like the porter cable 7336) are very friendly to operate and with a light polishing compound such as 3M SMR (Swirl Mark Remover), it's difficult to really do any damage. I would stay away from using any chemicals though since even with simple stuff such as goo gone or rubbing alcohol, you'll need to be careful not to haze the paint (which will require buffing to correct).
Cosworth is offline   Reply With Quote
Old 04-11-2005, 02:54 PM   #6
JnJassociates
Member#: 69539
2004 wrx wagon
red
Start with a clay bar, that should remove most of it. If there are an stubborn rubber deposits, use a mild rubbing compound or polish. That should do the trick...
JnJassociates is offline   Reply With Quote
Old 04-11-2005, 10:23 PM   #7
Oldalfaguy
Member#: 45091
2004 STI
Silver (Stealth)
Thanks all, I used Mcguire's Rubbing Compound and worked beautifully.
Thanks,
John
Old 04-11-2005, 11:35 PM   #8
ranger5oh
Member#: 77752
5Sti 2005 Sti
no prob... glad to see it worked!
How to get ex. ugly now and smokes? zombiefeedingtime Off-Topic 26 09-23-2009 06:35 AM
How to remove those black spots on the inside of the rim? iNfEk Tire & Wheel 11 08-25-2005 10:09 PM
How to remove cone bashing scrapes? Oldalfaguy Interior & Exterior Modification 12 03-13-2005 02:12 AM
How to make a snow cone (STAC STYLE) ERaab212 Tri-State Area Forum 32 02-23-2005 06:32 AM
How to make a snow cone (STAC STYLE) ERaab212 Off-Topic 6 02-21-2005 01:53 AM
