Welcome to the North American Subaru Impreza Owners Club Saturday November 21, 2009
Go Back   NASIOC > NASIOC Subaru Models > Impreza Forum > Impreza (1993 - 2001)
Old 05-26-2001, 02:00 AM   #1
SubaTubaru
Member#: 5343
97 Legacy GT
4 tone red
Unhappy Overheating Problem.... Help! (kinda long) but important
ok everyone, i got a 97 GT sedan 5 spd with 98,000 on it. I have been having this intermittant overheating problem, where my car will randomly think it is overheating, dump all the coolant into the reserve tank and start overflowing from it. I went to a dealer and they started "diagnostics". they replaced my thermostat and told me that was the problem, and that they fixed it and nothing was wrong anymore. well i drove home fine, but later that night i noticed my temp gague go up real fast, pulled over and saw the same darn thing. well the next morning i brought it to the dealer, told them it was not fixed, and they needed to gimme my money back blah blah... they refused, but said they would run tests on it for free to find out whats wrong.... anywahs... they said they could nto get it to over heat. and they noticed nothing wrong with it. HMMmmmmm... they also told me i was 2.5 quarts of oil low with no external leaks after 3,100 miles after last oil change. well they told me nothing was wrong and ot just drive it. that night i packed up for home from college, with my car filled to the tippy top of stuff! trunk full back seat full and passanger seat full! drove hom on Mtn roads just fine! went to go to airport next morning and WHAM overheat :-( I dont know what to do!!! anyone got any ideas?! please help :-( if anyone would like to pull my engine apart with me, i give full permission for anyone to do this with me! LOL.. i have no money, but this might be a fun project... please... anyone?! :-(
Mike
SubaTubaru is offline   Reply With Quote
Old 05-26-2001, 04:20 AM   #2
efoo
Member#: 80
Post
unfortunately, i suspect you have a blown head gasket. others have experienced the same symptoms you are describing and found that to be the case.
if you are still under warranty, you should go back to the dealer and insist that they ride with you until they see the problem happening firsthand, then fix it for you under warranty.
if you are not under warranty, email me - i have some options for you in the MA area.
-Edwin
efoo is offline   Reply With Quote
Old 05-26-2001, 05:26 AM   #3
kevinsUBARU
Member#: 2263
Arrow
Good Luck! Unfortunately, I cant call you this time and tell you how to rip that crap apart I would say a headgasget sounds very likley...but give your waterpump a looksie also (its much cheaper to replace than headgasgets).
Good Luck!
Kevin
kevinsUBARU is offline   Reply With Quote
Old 05-26-2001, 05:31 AM   #4
Jan Shim
Member#: 6366
1998 JDM Impreza WRX
Post
Mike,
The WRX water temp needle usually doesnt move unless there is serious overheating, which you no doubt have discovered (but unfortunately your dealer failed to take you seriously )
From your description "dump all the coolant into the reserve tank and start overflowing from it" I would have to agree with Edwin that the possibility of blown gaskets is very high. If you check your coolant level (on a cool engine, of course!) and find that it has lost a lot of water then I'll say it's definite blown gaskets. A friend's STi was drinking 1 litre of water every morning until a month later when the engine could take no more, the pistons seized. The damage was quite severe resulting in new engine block and pistons
Jan Shim is offline   Reply With Quote
Old 05-26-2001, 06:45 AM   #5
Fitz
Member#: 1426
2003 Evo, 2007 zx6r,
2000 SV650 Race Bike
Post
Hmm... it's displacing the water... possibly with air. 3 quarts low?? I'd say that the oil is going into the coolant. Did you happen to see any contamination in the coolant? Other things to try before pulling the motor apart.. compression test and a leakdown test. It would help you get a better idea of what's going on.
Fitz
Fitz is offline   Reply With Quote
Old 05-26-2001, 07:14 AM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Post
Exactly the same symtoms I had on my '97 GT a few months back, and it was, in fact, two blown head gaskets. I replaced the thermostat and radiator cap myself when it overheated the first time, but it overheated a couple more times over the next few days. I had the dealer do the compression and leakdown tests, and they confirmed that both gaskets were bad. Fortunately for me, I was about 300mi within my 60k factory warranty, so I was covered.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 05-26-2001, 07:47 AM   #7
uncreative
Member#: 6627
2003 wrx wagon
Post
A friend's 97 Outback just had the exact same thing happen. The dealer took 2 weeks to diagnose the problem, which turned out to be a blown head gasket. Good luck. -Dan
uncreative is offline   Reply With Quote
Old 05-26-2001, 10:11 AM   #8
jmott
Member#: 6713
2000 MR2 Spyder
RED
Post
I had exactly this problem on my 96GT..MUSTANG.
seriously.
its getting looked at now.
jmott is offline   Reply With Quote
Old 05-26-2001, 10:24 AM   #9
pottsie350
Member#: 6110
98 Impreza L
Red
Post
I'd agree with the majority of posters, it sounds like a head gasket. At worst a cracked or warped head or block. But most likely a head gasket. One easy way to check, is fire up the car with the radiator cap off. As the car warms up you will see tiny bubbles in the coolant as it flows past the hole where the radiator cap goes. The only way for air bubbles to get in the coolant like that is from a tiny pressure leak at the cylinder. It's an easy check that a lot of mechanics don't bother with.
If you or they determine that it is a gasket or crack, make sure you have the heads and block checked for warping or cracks. If the Temperature guage gets pegged, and there are air pockets in the heads from a pressurized air leak, some overheating damage may have occured.
pottsie350 is offline   Reply With Quote
Old 05-26-2001, 12:28 PM   #10
SteveS
Member#: 6
2007 BMW 335i
Montego Blue
Post
Head gasket(s) no doubt. Classic symptoms.
Steve<br> http://www.forcefed4.com/
SteveS is offline   Reply With Quote
Old 05-26-2001, 12:54 PM   #11
popnGEAR
Member#: 4616
2002 S2000
New Formula Red
Post
actually i had those exact same symptoms, but when i brought it in to get checked they just topped up the coolant and it was fine, no problems since.
but i doubt that it's the same case here.
popnGEAR is offline   Reply With Quote
Old 05-26-2001, 09:23 PM   #12
SubaTubaru
Member#: 5343
97 Legacy GT
4 tone red
Post
hey guys thanks for the replies, any more would be appreciated! maybe timing belt? anyones timing belt go? what happens? umm, there was no oil going into my radiator fluid. this is aggrivating! anyone own a shop and want to make some money? My car is covered by an aftermarket warranty CO. they will pay to do engine repairs at a certified shop. transmission work must be done at a dealer. but this is not transmission. And if anyone wants to do this at their shop, take a look at other things in engine... if they are worn and causing performance decrease, the warranty Co will pay for replacements and labor. so maybe if anything is worn, they should be replaced (aftermarket lol) anything at all. If someone wants to help me, please PM me!
Mike
Old 05-26-2001, 11:51 PM   #13
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Post
Timing belt? Not sure where that came from. But, just to put your mind at ease, no, these types of problems would not be caused by a bad timing belt. A bad timing belt would cause little things like the engine not running at all because the cams aren't spinning.
Trust us, man, it is almost certainly a blown head gasket.
You may not see oil in the coolant or coolant in the oil. Those are both "classic" blown head gasket indicators, but they often don't seem to work with the Subaru engines. I don't know what it is about the way the gaskets/water jackets/oil passages are set up, but I know I didn't have either problem when my gaskets went.
I also tried what pottsie350 suggested - checking for bubbles by removing the radiator cap (while the engine is cold, of course!). That was how I confirmed the gaskets on my Mustang were bad a couple years ago, but it didn't work on the Subaru. Again, I'm not sure why.
Go get the compression and leakdown tests done.
Pat
Old 05-27-2001, 12:04 AM   #14
SubaTubaru
Member#: 5343
97 Legacy GT
4 tone red
Post
Hehehe ok ok! Thanks everyone!
Old 05-27-2001, 01:00 AM   #15
Mikey B
Member#: 5160
1995 Jeep Cherokee
1975 Grady White 20' Boat
Post
I just got the same problem fixed on my car, not a Subie but it sounds like what happened to me. What is happening is the head gasket is blown and when the engine is nice and warmed up you are passing Exhaust gasses through the water Jacket, due to the heater core being the highest point of the cooling system the air, read Exhaust, is entering there and you are losing you internal heat. The exhaust then goes to the radiator and pushes the coolant to the overflow...
Good Luck man this really sucks cause I compression checked my engine a few times and the head seemed fine, but I talked to a few mechanics in the area and they ALL pointed to the head gasket, after I replaced it I have heat again and the car is nice and Cool.
Mikey B
Mikey B is offline   Reply With Quote
Old 05-27-2001, 04:34 AM   #16
Jan Shim
Member#: 6366
Post
Pat,
On the WRX, it is perfectly normal to see bubbling coolant tank so this is not an indication of blown gaskets, at least not on the Subaru. Perhaps it's due to the water pump design that encourages pump cavitation, perhaps it's due to the horizontally opposing layout of the engine block, perhaps .. I have made several observations of this bubbling phenomenon on a number of WRX and concluded that it is normal.
Jan
[This message has been edited by Jan Shim (edited May 27, 2001).]
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 05:39 AM.
