Old 04-11-2005, 10:05 AM   #1
staticfritz
Member#: 66934
2004 JBP FXT
2002 cammed OBS - RIP
Default 5mt ecu vs 4eat ecu
two ecus from '02 obs's. one is from a 5mt, the other is from a 4eat. are the ecu's the same, or is the tcu a part of the ecu unit?
basically, if i went to send one out for work and then swap it in, will there be any problem?
thanks!
staticfritz is offline   Reply With Quote
Old 04-12-2005, 04:34 PM   #2
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Sedan, White WRX Wagon
Heh - stumbled on this by accident. I'm almost 100% sure (don't you love that phrase?) that auto and mt's use the same ECU - it's the transmission plug that is different, and thus, "tells" the ECU which mode to operate in.
CirrusWRX is offline   Reply With Quote
Old 04-12-2005, 05:09 PM   #3
yobtah
Member#: 48939
That would make sense... it's not really conclusive evidence, but Cobb's Accessport maps don't differ for MT or AT cars. In fact, the "stock" map stored in an Accessport is supposedly based on an AT WRX. Seems reasonable that the ECUs are identical and the presence or absence of an automatic trans determines ECU behavior.
yobtah is offline   Reply With Quote
Old 04-12-2005, 07:02 PM   #4
STiTuner
Member#: 5778
09 135i
Jet Black
if you dyno a car with an MT ecu in it, and then dyno it with an AT ecu in it, you'll find that the AT ecu's make slightly more power
STiTuner is offline   Reply With Quote
United States ECU vs. European ECU fly dutchie AccessPort 1 04-29-2007 11:58 AM
02 ECU vs. 03 ECU jlogan9 Engine Management & Tuning 2 05-02-2005 12:36 AM
USDM ECU VS UKDM ECU, Any differences? Spec C Wannabe Engine Management & Tuning 10 02-19-2005 07:13 PM
Can 1 reflash a 02 5spd ecu to 4eat ecu? thesmokingman Engine Management & Tuning 18 11-07-2003 03:55 PM
DOHC ecu vs SOHC ecu q's? jeffg Normally Aspirated Powertrain 5 01-21-2002 02:27 PM
