Old 04-11-2005, 12:11 PM   #1
jskho
Member#: 11864
Default Cel P0103
The lights came on about a week ago. The book states the problem the problem to be High Air flow output. I need some help interpreting this. does it mean Im running lean?? or does it mean I have clog injectors so not enough gas in the cylinders?? Can someone help. Also I notice a screechy noise coming from my timing belt. I have an 02 WRX and about 68k on it. I thought the timing built is not due for change out til 80K. correct me if I'm wrong.
jskho is offline   Reply With Quote
Old 04-25-2005, 03:23 PM   #2
jskho
Member#: 11864
Does anyone have any suggestion as what to do with my CEL of P0103. The only mod I have is the CAI, and timer and exhaust. but its been in there for a long time now. I do my regular oil change every 5-7k with mobil 1 . Car has 68k on it now. Any suggestion would be great. Thanks
Old 04-25-2005, 04:31 PM   #3
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
Mass air flow circuit, high INPUT.
Probably your MAF sensing too much air?
z is offline   Reply With Quote
Old 05-01-2005, 02:23 PM   #4
jskho
Member#: 11864
Is it the sensor that is located on my Injen CAI???
Old 05-01-2005, 02:40 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
GET RID of the injen POS!!!!! and put the stock airbox back on and I bet the light stays off!!!!
CAI's cause THIS......
Old 05-01-2005, 06:55 PM   #6
jskho
Member#: 11864
I had that CAI a little over 2 yrs now. This is the first time this code came on. These symptoms dont appear immediately? And why so long after I have it on? Im just curious
Old 05-01-2005, 07:47 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
...ya got a leak...or obstructed filter or something....it is an intake leak somewhere.
What did you do to the car right before the light came on???
Old 05-02-2005, 01:30 PM   #8
jskho
Member#: 11864
come to think about it I think its about time to clean the filter. I'll go check for leaks on the system make sure everything is tight. Thanks for all the input guys. I'll post the results of my finding
Old 05-05-2005, 10:47 AM   #9
turbocolin
Member#: 43539
95L 97L 03hedgehog
02 wag 180mph monster
yeah you have a vacuum leak which is causing the car to run a little leaner it is probobly leaking where the mass air flow goes to the intake tbe get rid of the intake or seal it well with gasket sealer or foam gasket
turbocolin is offline   Reply With Quote
cel p0103 and p0113 - input? dehsiung Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-22-2009 03:55 PM
Need opinions about CEL P0103 on an 05 STI Depeche Service & Maintenance 2 06-16-2008 10:15 PM
Solid CEL, Code P0103 IMPREZIV Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 08-07-2007 04:19 AM
cel p0103 what to do? [email protected] Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-16-2006 04:54 PM
CEL P0103 and loose hoses (image heavy) WRXtranceformed Service & Maintenance 13 01-20-2006 11:50 AM
