Old 04-11-2005, 03:27 PM   #1
LatentWagen
Member#: 50315
0806 LGTspecB & Saab
9-2xAero5MT DGM & MBP
Default utec tuning - went from vf22 + tmic, to vf22 + fmic + intake
ballpark, what kind of changes should i make? more timing down low to help spool? less up top? more fuel because of the intake? i have egt and boost, but no wideband o2 sensor. this will be temporary, as i have plans to get re-tuned before the summer.
also, does anybody have a map for this setup that i could work with?
02 wrx, vf22, perrin fmic, utec, avc-r, modded stock injectors, txs catless tbe, mrt unifilter intake, avo inlet hose.
thanks,
ed
LatentWagen is offline   Reply With Quote
Old 04-11-2005, 06:32 PM   #2
hippy
Member#: 36528
2002 Impreza Wrx
Most likely less timing from the change in intercoolers. If you're not knocking, I wouldn't worry about it. The mrt intake is a little bigger diameter then stock. Ya might wanna add .4 to the whole fuel map. If ya start knocking, ya might wanna start by adding .2 fuel in the knock prone areas.
peace
Old 04-11-2005, 08:21 PM   #3
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
what was your afr's like with tmic?
was it tuned?
Old 04-11-2005, 10:26 PM   #4
LatentWagen
Member#: 50315
yea it was tuned to 280/270 by junior... afr's were dialed in, i forget to what. 11:1 probably...
Would like opinions from people that went from Sedan STi to Hatch STI.... Box This General Community 53 01-15-2010 11:24 PM
Going from Perrin TMIC to FMIC, tune needed? lateralus1082 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 06-02-2009 10:29 PM
Looking for the UTEC tuning guru from garage days Davenow New England Impreza Club Forum -- NESIC 2 03-23-2003 08:18 PM
('93-'01) Went from 15.9 to 15.6 with MRT header back system and.... scootr Impreza Forum 2 06-13-2001 08:53 PM
I went from 92 Octane to 87 and... ivbdn Normally Aspirated Powertrain 24 01-15-2001 02:30 AM
