Old 04-11-2005, 11:26 PM   #1
oregonsixteen
Member#: 84932
1991 Legacy L AWD
Some kind of gold
Default ECM / ECU Compatibility
Hi,
I have a 1991 EJ22 body style B10 AWD L wagon. The ECM in the car has these markings : EE in huge letter followed by 31711 AA911. A64-000 822 1381 seems like the serial number.
I found a 1993 ECM at my auto wrecker with these markings: HS in huge letter followed by 31711 AC031. JA64000 RL6 2710 seems to be the serial number.
Are they compatible? Interchangeable? I looked at the PCB inside and they look different. Thank you!
oregonsixteen is offline   Reply With Quote
Old 04-12-2005, 09:41 AM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
First off, is your legacy manual or auto? The 90-91 manual & auto's have different ECU's, and match the specific type of sensors in the engine. So depending on what you have you need to find an ECU from a 90-91 with the same transmission type.
The 92-94 ECU's aren't really compatible either. There's some things you could do to make it work if you have an automatic, but it would involve snipping some wires, and possibly dealing with rich/lean a/f issues due to the injectors being different between the 90-91 & 92-94 models. So I wouldn't recommend it.
Legacy777 is offline   Reply With Quote
Old 07-21-2005, 04:55 PM   #3
oregonsixteen
Member#: 84932
1991 Legacy L AWD
Some kind of gold
Hi,
It's an auto. Your reply pretty much answered my question, thank you! I guess I won't be mucking around with no 92-94 ECU. BTW, what "improvements" were made to the 92-94 models?
Old 07-21-2005, 06:06 PM   #4
Legacy777
Member#: 4800
There were slight things here and there. headlights, styling, minor stuff. Check out www.bbs.legacycentral.org for info.
WTB: 97 Legacy 2.5GT Manual ECM/ECU 97LEGGT Private 'Wanted' Classifieds 3 02-08-2008 01:18 PM
XT6 wiring harness and ecm/ecu richarddstanley Private 'Wanted' Classifieds 1 09-12-2006 05:03 PM
ECU compatability jpmarotta Engine Management & Tuning 1 05-21-2004 02:38 PM
ECU compatibility ambzod Engine Management & Tuning 5 04-22-2004 07:43 AM
ECU Compatability? Bobby321 Normally Aspirated with bolt-on Forced Induction Powertrain 8 07-12-2002 03:22 PM
