Old 07-25-2001, 11:57 AM   #1
CHACHI
Member#: 5527
2000 impreza rs
blue ridge pearl
Default highest amount of boost for stock 2.5
just wondering how much boost you could use on a stock 2.5 thanks!
CHACHI is offline   Reply With Quote
Old 07-25-2001, 02:05 PM   #2
zaidallas
Member#: 4106
its hard to tell , you'll have to be more specific. running intercooled , with proper fuel managment and tuned right , I think no more than 12-14 psi .
zaidoun
zaidallas is offline   Reply With Quote
Old 07-25-2001, 02:23 PM   #3
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
...and it depends on the year... the 98-99 could probably run an extra couple of pounds over the 00-01 because it had a slightly lower(9.7:1 vs 10.1:1, I think) compression ratio. But amount of boost doesn't really determine power. 10lbs of boost, properly done could very well be more powerful(and almost definitely more drivable) than 15-20lbs of ragged boost. Not to mention how you apply the boost has alot to do w/ how fast it makes the car...
mrbell is offline   Reply With Quote
Old 07-25-2001, 02:50 PM   #4
d00f
Member#: 6000
2000 GC8 STi V4 swap
BRP
Let's assume that tuning and fuelling are not issues. The maximum boost you can use before your engine blows apart is really dependant upon the pistons. If your pistons happen to have some slight casting imperfections they might blow at 9lbs boost. I've certainly seen a few do this. It would seem that the maximum safe boost on a stock engine is in the 5-7 lbs range. Beyond that I'd suggest going to stonger rods and low compression forged turbo pistons. You might get away with a higher boost but then again you may not. If your piston fails you're looking at a lot of dammage inside that engine.
-Michael
d00f is offline   Reply With Quote
Old 07-25-2001, 02:56 PM   #5
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
Agreed...
I was just saying I don't think boost is a very good way to target performance...
Old 07-26-2001, 04:28 PM   #6
DaveK
Member#: 2338
1988 323 GTX
black
I thought that there were plenty of people using the TEC-II who were running 10-12 psi with good reliablity (not including the drivetrain)
Anybody care to elaborate, esp. those running high boost?
Thanks!
DaveK is offline   Reply With Quote
Old 07-26-2001, 04:47 PM   #7
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
There are some people running around 10 psi... shiv I think is running 10 w/ a 2000 block and 99 head, so I'm not sure what the compression is. I think it's the same as the 2000 engine, and he doesn't want to go any higher on 92 octane. There are some other people claiming to run more than 10psi, but I wouldn't count on that lasting too long. 12 is probably the absolute maximum for a reliable MY98-99 on 92 octane, 10 for a 2000. I'm just speculating, tho...
Old 07-26-2001, 05:00 PM   #8
DaveK
Member#: 2338
1988 323 GTX
black
Once I get the TEC installed, I'm hoping to do two setups, one at 5psi for every day driving, then another one that starts at 6 psi and ramps up to 10, then drops back down a bit at reline...but I'm sure it'll be a while before I feel comfortable with tuning at 5psi, nevermind 10.
Old 07-26-2001, 05:10 PM   #9
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
I'm planning on the same thing... I've got my TEC-II in... now I'm waiting on the turbo kit... uhg... one lousy pipe...
Old 07-26-2001, 05:21 PM   #10
DaveK
Member#: 2338
1988 323 GTX
black
Is or has anyone run the TEC-II at high altitude for racing or otherwise?
WTT 02 wrx motor or ej20h For stock 2.5 rs motor sti=heaven Private 'Wanted' Classifieds 0 07-29-2009 01:51 AM
FS or WTT: v5 STi Wing for Stock 2.5 RS Spoiler bendavi007 New England Impreza Club Forum -- NESIC 2 04-12-2005 05:02 PM
Whats safe boost for Stage 2.5? samwY Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-24-2004 11:48 AM
Looking for stock 2.5 L dyno results.... anybody know where I can find 'em? JSiwek Normally Aspirated Powertrain 4 06-02-2002 01:09 PM
Maximum Amount of Boost with Stock Internals??? Xscreamer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-28-2001 10:58 AM
