Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum
Old 07-25-2001, 12:10 PM   #1
Yrabus
Member#: 2695
02 WRX Sedan
Default Suspension help in Ottawa
I have a MY00 RS2.5 & live in Ottawa. I am looking for recommendations on shops to install anti sway bar (18mm SPD)and springs (SPD Eibach Pro-kit) , plus do a good alignment.
Yrabus is offline   Reply With Quote
Old 07-25-2001, 12:44 PM   #2
mturmel
Member#: 2473
World Rally Blue
Default Subaru-Lachute...
Ok everybody, all together:
"LACHUTE SUBARU!!!"
check them out: www.lac-ss.com
Matt
mturmel is offline   Reply With Quote
Old 07-25-2001, 12:59 PM   #3
Skeandhu
Member#: 1056
I'll second that!
Skeandhu is offline   Reply With Quote
Old 07-25-2001, 01:18 PM   #4
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
The sway bar is pretty easy... It takes about 15minutes to make the change... For the springs, that's a bit more time....
If that's a bit too far, call the local dealers (Gatineau, Ogilvie or Westboro)....
Robin
www.ottawasubaru.com
BTW, are you on the NCSC mailing list?
Robin2 is offline   Reply With Quote
Old 07-25-2001, 01:22 PM   #5
mturmel
Member#: 2473
World Rally Blue
Default Gatineau Subaru...
I bought my car at Subaru Gatineau, they're very good. However I don't think they're equipped to do alignment on site.
Matt
Old 07-25-2001, 01:32 PM   #6
Yrabus
Member#: 2695
02 WRX Sedan
I bought the car at Westboro Motors, they said they would rather not install someone else's aftermarket parts.
Any experience with Robson?
Old 07-25-2001, 02:28 PM   #7
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
Dont go to Robson!!! They're expensive!
I think they charge $70 per hour.... call them and find out......
I highly recommend Subaru Lachute... I had my KYB/AGX struts, sway bar (20mm), and whiteline end links installed there.....
Robin
Old 07-25-2001, 11:02 PM   #8
FengShui
Member#: 6300
Here is some specs of alignment. I have 5 zigen springs with stock strut & using Cobb tuning. It works well.
Speed USA -0.75 Degrees 1/16" Out 0.0 0.0
Rallispec -1.25 Degrees 0 0 3/32" Out
Cobb Tuning -1.0 Degrees 0 0 1/8" In
Nativo Performance -1.5 Degrees 1/8" Out 0 1/8" In
Other -1.5 Degrees 1/16" Out 0 1/16" In
Peace out<
Mykael
FengShui is offline   Reply With Quote
Old 07-26-2001, 10:12 AM   #9
Yrabus
Member#: 2695
02 WRX Sedan
Thanks all!! I will for sure give Lachute a try. At worst, it looks like a day off work and a nice drive.
Fengshui - I know just enough to suspect your post contains important information, but not enough so that I understand it. Pls. help!
Old 07-26-2001, 09:28 PM   #10
FengShui
Member#: 6300
Sorry!
Check this site..
http://www.northursalia.com/
Alignment specs. Hope that helps.
Cheers,
Mykael
Looking for help in 951 area halfelite Southern California Impreza Club Forum -- SCIC 2 06-01-2010 03:05 PM
Help stuck in Ottawa, need ride. MadMax Canada Region Forum 14 05-07-2002 02:32 PM
Anyone in Ottawa interested in car shopping? linsavy Canada Region Forum 2 04-18-2002 09:10 PM
Will a stiffer (and lower) suspension HELP in winter, or make things worse?? GooseMan Brakes, Steering & Suspension 7 12-01-2001 12:08 PM
('93-'01) Anyone bought a 2001 Legacy L wagon in Ottawa recently? JunkMale Impreza Forum 0 06-01-2001 03:46 AM
