Welcome to the North American Subaru Impreza Owners Club Thursday October 23, 2014
Old 04-12-2005, 06:22 PM   #1
con40
Member#: 71078
2002 Wrx Sedan
Wr Blue Pearl
Default Anyone using Perrin Ebcs with Accessport
Just wondering if it is good or bad too do. I know a few Sti's with Ecutek that recommend me getting a Perrin Ebcs.
con40 is offline   Reply With Quote
Old 04-12-2005, 06:52 PM   #2
coolcougar
Member#: 19674
2006 Baja Turbo 4EAT
Brilliant Silver Metallic
I had a nice long answer worked up but my computer ate it!
Anyway the short answer is no it is not worth it with AP because:
A) If you hook up the EBCS in interrupt mode you would get some increase in spool (how much I don't know) but you would need to be able to modify your waste gate duty cycle (WGDC) maps in order to compensate for the additional air volumes the Perrin EBCS can move at a given WGDC compared to the stock WRX BCS. According to the Perrin EBCS thread running their EBCS at the 'Stage 2' WGDC values will result in boost spiking and fluctuation (and I will personally attest to this fact)
B) You can run the EBCS in bleed mode but if you're on the stock turbo there would be little to no benefit from doing this as the stock BCS is adequate for the stock TD04 turbo and you would get little to no increase in spool.
For more info look here: Perrin EBCS thread
And Here: GM Part #... Different make but it does the same thing.
Now with ST the answer would be different.
coolcougar is offline   Reply With Quote
Old 11-14-2005, 02:09 AM   #3
dElKwOn
Member#: 71184
Chapter/Region: HIIC
2002 ewg'd vf-34'd
GDA AMS Tuned !
i'm running the streetTUNER,and i have been looking @ picking up the perrin ebcs.my question is will the ebcs be benifical for my set-up.btw i'm running a vf-34 , sti pinks & walboro fuel pump.
dElKwOn is offline   Reply With Quote
Old 11-14-2005, 10:39 AM   #4
hondaeater69
Member#: 60324
IA) If you hook up the EBCS in interrupt mode you would get some increase in spool (how much I don't know) but you would need to be able to modify your waste gate duty cycle (WGDC) maps in order to compensate for the additional air volumes the Perrin EBCS can move at a given WGDC compared to the stock WRX BCS.
maybe i'm missing something here, but if you hook up a aftermarket BC, aren't you bypassing the stock BCS and rendering the WGDC maps useless? (from how i understand it, the stock ECU uses the BCS to control the WG).
Old 11-14-2005, 11:40 AM   #5
coolcougar
Member#: 19674
The Perrin EBCS is still controlled by the ECU's WGDC maps... that is unless you are running another form of engine management that over-rides or replaces the ECU. The Perrin EBCS is just a solenoid; it has no processing or control abilities what-so-ever, it just does what it is told.
Other 'programmable' BCS (such as the Apexi AVC-R) include their own dedicated ECUs just for the BCS... Perrin is NOT one of these.
Old 11-14-2005, 12:53 PM   #6
Barge
Member#: 62941
2004 WRX
Rally Blue
I'm using the Perrin EBCS w/ ST.
The biggest difference was using a lot lower wastegate duty cycles to get a lot higher boost. I only used it in interrupt mode.
With a bigger turbo I would think it would only be a better upgrade.
With the boost levels I was running I would notice some very slow boost onset but it was all due to tuning. The boost would shoot up to like 9 psi and then slowly climb so I made some pretty drastic changes to the boost dynamic maps.
It's been so long since i've drive a car w/ the stock solenoid I can't remember what it's like so I can't do a direct comparison and now I have headers and an external wastegate so my setup is super oddball.
Barge is offline   Reply With Quote
perrin ebcs with cobb ap scooby1320 Newbies & FAQs 2 11-07-2008 06:57 AM
FS: Used Perrin EBCS $55.00 Shipped everglow Engine/Power/Exhaust 4 10-25-2006 12:43 PM
is anyone useing kartboy endlinks with thier perrin or progress sway bars? EJ22Boom Brakes, Steering & Suspension 7 02-08-2006 02:26 PM
Anyone using Perrin EBCS w/ UTEC on WRX stock 2 litre? overdose Engine Management & Tuning 3 04-22-2005 12:33 PM
Anyone using an EBC with Turbo-XS Stage II rdrandal Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-08-2002 09:42 AM
