Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 04-12-2005, 08:16 PM   #1
samwY
Member#: 31816
Default Which water injection kit do you recommend?
I have a Stage 4 WRX + FMIC UTEC tuned by TXS
Any good recommendations for which kit I should buy?
I searched but found a bunch of different info.
I need a reliable kit that performs...
samwY is offline   Reply With Quote
Old 04-12-2005, 08:37 PM   #2
thetikler1
Member#: 24096
2011 Outback/WRX
Info Here
Aquamist System is pretty good [click here]
and there is coolingmist which is another company that makes water injection kits.
i have no personal experience with these setups, but i'm sure if you search you ccan find tons of people who have used them. Apparently they are the way to go for us stage 4 guys.
-christian
thetikler1 is offline   Reply With Quote
Old 04-12-2005, 10:51 PM   #3
samwY
Member#: 31816
Yea, thanks for the info.
I saw those links already. Still not sure what to get. The Aquamist 2d goes for like $800 or something, but I have seen many other links that have $250-300 water injection kits. Not sure what to buy...
Old 04-13-2005, 12:18 AM   #4
testes1010
Member#: 47145
2012 Gas Saver
for Alky injection I'm going with this...
http://smcenterprises.com/subaru.htm
testes1010 is offline   Reply With Quote
Old 04-13-2005, 12:26 AM   #5
WRXskeet
Member#: 69435
2005 Aspen STi,rip02
Bugeye mafia 02 :(
im interested in this too, what the differance between all the kits?
WRXskeet is offline   Reply With Quote
Old 04-13-2005, 12:43 AM   #6
zaxrex
Member#: 9898
Water Injected Blue
If you want to compare apples to apples, the Aquamist 1s kit is more comperable to the other boost switched kits. It is still more expensive, but I trust in it and the pump is fairly small compared to some of the others. It is also easy to build up on that kit to make the 2c, 2d, and 2s kits for when you are going nuts with power.
zaxrex is offline   Reply With Quote
Old 04-13-2005, 12:56 AM   #7
testes1010
Member#: 47145
2012 Gas Saver
the smc kit is progressive...not switched...maybe I misread your post...
more boost, more alky...
Old 04-13-2005, 01:30 AM   #8
zaxrex
Member#: 9898
Water Injected Blue
You are correct, the SMC is progressive. There are a lot of "kits" based around the Snow Performance RV pump that are just run off of a pressure switch. I didn't refresh the page before I wrote, so I didn't see the SMC reference.
Old 04-13-2005, 12:59 PM   #9
samwY
Member#: 31816
Which version of the Aquamist waterinjection kits would I need?
I'm on a Stage 4 18g WRX + FMIC + UTEC (306whp pump, 348whp c16)
I plan on keeping the UTEC and heading to TXS for another tune.
Old 04-13-2005, 02:26 PM   #10
KCRex
Member#: 33804
03 WRX wagon
WR Blue
I have about the identical setup as you. I use the aquamist 2d system, made 329 whp, 314wtq on a mustang dyno, 92 octane pump gas. I recently installed the coolingmist kit on a buddies STI...works great, the pump is a little bit big though
KCRex is offline   Reply With Quote
Old 04-13-2005, 04:33 PM   #11
samwY
Member#: 31816
nice #'s...I never knew water injection would give such good results...
i saw someone with a 32whp increase
Sign on sometime, I'd like to talk to you `bout this stuff
FS : Meth / water injection kit NEW! defi gauges boost, egt JT's06sti Engine/Power/Exhaust 7 06-17-2010 11:45 PM
Which gearbox oil/mixture do you recommend for WRX? Rexer06 Transmission (AT/MT) & Driveline 57 05-18-2010 05:45 PM
Which sway bar set do you recommend? Jerry Xu Normally Aspirated Powertrain 8 07-20-2007 01:57 AM
How do I order an SMC water injection kit? wrxraaca Water/Methanol Injection, Nitrous & Intercooler Cooling 5 02-27-2006 06:57 AM
Do-it-yourself water injection kit AntonioS Normally Aspirated with bolt-on Forced Induction Powertrain 11 01-23-2004 09:48 AM
