#1 |
Member#: 49328
Vehicle:2004 WRB/Gold STI |
Is there any gadget, software, or otherwise tool that will allow you to plug in to the OBD2 port and pull all the information the port give PLUS hook a aux wideband O2 into to view A/F at the same correlation to the OBD2 inputs? ie 14.2 AF at 3600 rpm, 12 degrees advace, etc etc. Thanks
#2 |
Member#: 29201
NESIC
Vehicle:BMW M3 Honda S2000x2 |
I'd look into the Full Throttle Scan Master and use it with a Palm or a Laptop. They're all over eBay for about $225. They allow for three more 0-5v hookups. I haven't used one yet, but I'll be purchasing one in the near future. BTW, I'm pretty sure it picks up what the ECU is sending out for timing, not what the motor is actually doing, so if you have a UTEC controlling timing it will log ECU timing (false), rather than UTEC/actual timing. Same goes for MAF voltage. You'll be seeing UTEC calibrated MAFv rather than actuall MAFv. You wouldn't have a problem logging both with a laptop because the UTEC uses Hyperterminal and the Scan Master uses Palm emulator software.
Someone might be able to chime in with more info. Like I said, I haven't used it, this is just how I percieve it to be. Pete |
#3 |
Member#: 2998
VIC
Vehicle:2002 WRX WRB |
ECUTEK deltadash.
http://www.ecutek.com/products/ You need something that reads the Subaru codes as OBDII will be too slow to be usefull. IMHO. |
#4 |
Member#: 29201
NESIC
Both use the Subaru specific protocall, not generic OBDII.
Scan master w/two 0-5v inputs $224. Plus the cost of the WB ($275-$450)Usable on an unlimited number of Subarus. Deltadash w/LM-1 WB $329+$349=$678. Limited to three Subaru vehicles. Scan master: http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW Delta dash: http://www.ktrperformance.com/Partners/ecutek_main.htm Last edited by eastcoastbumps; 04-15-2005 at 12:24 PM. |
#5 |
Member#: 82730
Vehicle:2002 WRX 4EAT Silver |
What about the device from zeitronix?
It's installation is discussed on ScoobyMods, but not a great deal about what it does. Just a suggestion, as I have no experience with it. |
#6 |
Member#: 29201
NESIC
Zeitronix makes wideband oxygen sensors and hardware that will also log more info with their sensors. It doesn't look like it will connect to OBDII and it certainly won't connect using the superior Subaru specific protocall.
A kit like that for data logging lacks all the nice little features such as fuel trims and a code reader that DD and SM have. It also requires you to buy more sensors. Deltadash and Scan Master both require you to add your own wideband, such as the basic Zeitronix, LM-1, AEM UEGO, etc, to get everything in a nice little package. |
#7 |
Member#: 27108
Vehicle:2004 STi 2004 A4 |
DeltaDash already has support for the LM-1 built in... no LabJack needed.
#8 | |
Member#: 29201
NESIC
Pete |
| Thread Tools | |
| Display Modes | |
| OBD2 software interfacing | Mr. TRD | Southern California Impreza Club Forum -- SCIC | 2 | 01-08-2004 03:59 AM |
| OBD2 software for laptops | MustGoFast | Mid West Subaru Owners Club Forum -- MWSOC | 1 | 09-29-2003 04:35 PM |
| Auterra obd2 software, anyone using this? | cwingo | Engine Management & Tuning | 9 | 07-22-2003 12:43 PM |
| When using a Palm and obd2 software... | mrtrex | Factory 2.0L Turbo Powertrain | 5 | 07-14-2002 01:20 AM |
| OBD2 Software for your Nextel Phone | rlburg | General Community | 0 | 07-02-2002 09:11 PM |
