Old 04-13-2005, 08:14 AM   #1
Davenow
Member#: 23676
Default 2.2+wrx heads need cams as badly as 2.5+wrx heads?
So I am doing my motor like next week. I was going to go with a full V7 motor azcs and all, but apparently it wont pass emissions with that ecu, and since the usdm ecu will throw CELs from no TGV's, the V7 is just not going to happen.
Which leaves me with 2 choices
Choice 1
USDM STI shortblock+crawford pistons+crower cams- about 4400 installed
Choice 2
2.2 turbo shortblock+crawford pistons -- maybe 3700 installed? around there anyway.
In any case, I would like to go up inn displacement, I will be running a VF22 for the time being, and going to probably a green later, and RA gears.
I know with the 2.5, you have the powerband of a truck without cams, and I could do cams, but I REALLY need to keep this under 4k if at all possible, which means the 2.5 is something I need to avoid if at all possible. Which brings me back to the 2.2t block. Both of these are brand new shortblocks.
My question is this, do I NEED the cams on the 2.2 like the 2.5, or will it be ok? Basically I have heard the 2.5 +stock cams=un fun powerband because it falls off SO hard up top.
And are there any downsides durability wise to the 2.2? Isnt it the strongest block subaru ever made? Wont the oil squirters make it even better?
Old 04-13-2005, 09:32 AM   #2
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Hmm sounds like a tough choice man. I would go with cams just for the simple fact they are better than the stockers and they are going to give you the power you are looking for.
DuoMaxwell is offline   Reply With Quote
Old 04-13-2005, 09:37 AM   #3
SBW
Member#: 38469
07 LGT spec-b
Crystal Grey Metallic
that is my setup 2.2t cp pistons, eagle rods, worked wrx heads, and usdm sti cams. basically erik's old motor, but Im putting forged aftermarket rods instead of the stock ej22t. fp green + ra gears, should be sick, but I would look into going shimless design of the new wrx heads and raise that rev limit.
(i'd tell you how it is, but my motors in the machine shop getting built now) should have it tuned shortly.)
other things to think about in addition to your project, sti water pump, new cam and crank sensors, piston rings, cometic head gaskets, better headstuds, big maf, etc...
or, just go for the gusto and get some real cams.
4k motor alone? or is that including the gears?
SBW is offline   Reply With Quote
Old 04-13-2005, 10:28 AM   #4
Davenow
Member#: 23676
that 4400ish includes
2.5 sti shorty
Crawford forged pistons
Crower cams
New oil pump
new water pump
new timing belt
all gaskets
installed, running, out the door waiting for my tuning
Old 04-13-2005, 05:00 PM   #5
cronic
Member#: 9749
Why cant you pass with V7?
cronic is offline   Reply With Quote
Old 04-13-2005, 07:40 PM   #6
Davenow
Member#: 23676
ecu doesnt communicate with the inspection machine from what I am hearing...
Old 04-13-2005, 08:13 PM   #7
cronic
Member#: 9749
I know for a fact people have passed with wrx swapped v7's..
The problem i am having i this MAY be due to the jdm harness, but i am not totally sure honestly..
I went in again today and had the same problem, but the guy doing this one was much better, and told me the problem is the machine connects fine, but then when he starts my car the machine doesn't realize it is running, and that is when it times out and fails.. I am not sure what is causeing this.. Obd2 port works fine so i am out of ideas..
Either way i got my inspection sticker
Old 04-13-2005, 10:14 PM   #8
Davenow
Member#: 23676
will PM you tomorrow, VERY interested to discuss this further...
But since I have your attention now, who has passed the OBD2 inspection with teh V7 ECU? And what state?
Old 04-13-2005, 10:52 PM   #9
cronic
Member#: 9749
George(sonicyellow) has passed in either Ma, or NH or where ever he lives Downshift1 has passed in Il, Fastnoypi has passed in Ct and AZ..
JDM V8 2.0 Spec C Heads, NEED cam gears or Specs on them, and hardware Suby888 Private 'Wanted' Classifieds 1 02-19-2011 04:38 PM
Winter 2004-5. Has there ever been a snow year as bad as this? RightyTighty North West Impreza Club Forum -- NWIC 30 01-24-2005 09:47 AM
as bad as i HATE to, my windhield banner is coming off today (question) SuBaRu-ImPrEzA_RS Interior & Exterior Modification 6 05-30-2001 11:43 AM
its not as bad as i thought juggalo Interior & Exterior Modification 0 03-10-2001 04:16 PM
