Old 04-13-2005, 11:30 AM   #1
Padge
Member#: 74412
'05 Impreza WRX STi
Obsidian Black Pearl
Default Stupid COBB AP question...
I am almost positive that the answer is no, but I need to clarify. If I uploaded map2 as my base map, can I drive around with the AP not plugged in and still be running the base map, or does the AP always need to be wired into the ECU?
Thanks :ashamed:
Padge is offline   Reply With Quote
Old 04-13-2005, 11:34 AM   #2
phantomsr
Member#: 69071
2002 Stg2-WRX Wagon
WRB & Dust
Once you load the map from the AP onto the ECU you can disconnect the AP and the init connectors under your dash. The only time you need to reconnect the AP is to change real times maps, and check CEL's. The only time you have to reconnect the green connectors and plug in the init clip is to reflash a new base map.
phantomsr is offline   Reply With Quote
Old 04-13-2005, 11:37 AM   #3
Padge
Member#: 74412
'05 Impreza WRX STi
thank you!
On a side note, I am only hitting 16.5 psi on stage 2, do you think this is because I only have a DP and stock catback... or should I try the HWG map to hit target boost?
Old 04-13-2005, 11:55 AM   #4
phantomsr
Member#: 69071
2002 Stg2-WRX Wagon
WRB & Dust
How long have you been running the AP? It will take a while to learn up to full boost. Give it a few days and do a few 3rd gear pulls at WOT to redline when you get the change. I wouldn't run the HWG maps unless absolutely everything else has been eliminated.
Old 04-13-2005, 12:21 PM   #5
Padge
Member#: 74412
'05 Impreza WRX STi
I have had it running for almost 1 week.
Old 04-13-2005, 12:31 PM   #6
Chigliakus
Member#: 77525
'02 GDA, '09 GR
'93 FD
Originally Posted by Padge
thank you!
16.5 is target boost for stage2, in fact it's a little over target which iirc (too lazy to go to cobb's site and look it up) is 15.7 +/-0.5. 16.5 psi is also exactly what I hit in 3rd-5th running the stg2 map.
Chigliakus is offline   Reply With Quote
Old 04-13-2005, 12:39 PM   #7
timmah
Member#: 54203
2011 WRX
Thanks :ashamed:
READ THE MANUAL PEOPLE
timmah is offline   Reply With Quote
Old 04-13-2005, 01:06 PM   #8
Padge
Member#: 74412
'05 Impreza WRX STi
"Target boost pressure is 17.5psi +/- 0.5psi depending on vehicle and conditions"
Got that from the *.map text
Old 04-13-2005, 01:09 PM   #9
BlackSnake
Member#: 42850
WTB 04-07 STI
Roller/Blown Engine
He has an STi so his boost is higher then the WRX stage 2. Give it about 200 more miles, and see if it changes, if not then do the HWG map.
BlackSnake is offline   Reply With Quote
Old 04-13-2005, 01:13 PM   #10
GRNMTNRS
Member#: 7607
04 forester
red granite
I have a rex, but it took about 2 tanks of gas before it was hitting target boost.
Test: get it into 3rd, hold the brake w/ light pressure and nail the gas and see what psi you hit. Or have a friend come along and use the psi read out from the AP.
Good luck, and happy motoring
GRNMTNRS is offline   Reply With Quote
Old 04-13-2005, 03:41 PM   #11
Chigliakus
Member#: 77525
'02 GDA, '09 GR
'93 FD
Oops, too often I miss the "STi" in people's sigs for some reason, oh well. These guys offer good advice, also don't be afraid to call Cobb, they're friendly and knowledgeable.
stupid newbie AP question nation1979 AccessPort 3 02-18-2009 09:41 AM
Cobb AP Question SKitlerz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-26-2005 11:16 AM
05 cobb ap question Surgical22 Engine Management & Tuning 5 05-17-2005 01:52 PM
Cobb AP question WarHawk187 Engine Management & Tuning 15 03-27-2005 11:56 PM
cobb ap question speedyshifter Engine Management & Tuning 1 01-08-2005 08:14 PM
