Old 04-13-2005, 11:45 AM   #1
STi-Spec C
Member#: 75923
2004 18g WRX
Default Would I lose HP if I use STi block?
Like the title says would I lose HP if I switch over to the STi block? I know that it has a lower compression. I'm doing this because the block and gasket set is only 1700 from the dealer and I would get a bullet proof engine pretty much.
My head gasket is leaking coolant so subaru says that I have to replace it. They said it would cost 700 dollars. So I figured if I just spend and extra thousand I would get a brand spanking new block.
STi-Spec C is offline   Reply With Quote
Old 04-13-2005, 12:02 PM   #2
JewPac42
Member#: 23260
Patr ick Willis
for Rookie of the year
Yes, due to the lower compression ration you would lose a good deal of power, unless you went turbo at the same time. That block was designed for boost and without boost it will cost you power.
JewPac42 is offline   Reply With Quote
Old 04-13-2005, 12:06 PM   #3
STi-Spec C
Member#: 75923
2004 18g WRX
thanks. So I guess I'll just stick with the head gaskets.
Old 04-13-2005, 12:19 PM   #4
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Those sti blocks are'nt all that bullet-proof anyway. They are much better than the ej251 though. You'd need to drop in some higher comp pistons.
Tim Sanderson is offline   Reply With Quote
GF8 STI block of the engine Mirone Car Care & Detailing 2 06-02-2010 08:35 AM
how would one test an online server to see if there is anything blocking access? kaisersouse Off-Topic 6 04-15-2008 03:36 PM
what would you do if you had a sti block rexoutofhell Built Motor Discussion 17 08-26-2007 08:46 PM
how many HP can a usdm sti block can handle? veightkiller Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 05-03-2006 11:02 PM
Which would you buy, new WRX or used STI CletusTheDwarf General Community 32 12-23-2004 05:49 PM
