Old 04-13-2005, 12:53 PM   #1
jond8
Member#: 62379
72 240z
Orange
Default OT Enginerds
How vast is OT's knowledge???
Anyone had any luck bonding carbon fiber tube to polypropylene rod? And if so, what type of epoxy did you use?
Everyone else should post there engineering questions here too... It will be so awesome!!!
IBDieInAFireYouF'nNerd
jond8 is offline   Reply With Quote
Old 04-13-2005, 12:54 PM   #2
DrDRum
Member#: 41589
Suff erer Club
Founder (RGSSC)
I have, but I won't tell how.
DrDRum is offline   Reply With Quote
Old 04-13-2005, 01:02 PM   #3
Mapplex
Member#: 20315
1997 Impreza L
hunter green
I have polypropelene underwear. It bonds my rod quite well.
Mapplex is offline   Reply With Quote
Old 04-13-2005, 01:03 PM   #4
Undepelo
Member#: 34960
What would baby
Jesus say of OT?
Whats the application?
Undepelo is offline   Reply With Quote
Old 04-13-2005, 01:08 PM   #5
jond8
Member#: 62379
72 240z
Orange
Marine Iridium/GPS antenna mast/base for an autonomous oceanography profiling float.
Old 04-13-2005, 01:10 PM   #6
Grap
Member#: 6590
In layman's terms, a flag for his rowboat.
Grap is offline   Reply With Quote
Old 04-13-2005, 01:16 PM   #7
Undepelo
Member#: 34960
What would baby
Jesus say of OT?
Well wouldn't this info make a hell of a difference?
My guess would be you probably want to look for epoxies for marine applications and do really good surface prep. instead of being to concerned with the bond to the cf/poly combo.
Old 04-13-2005, 01:19 PM   #8
jond8
Member#: 62379
72 240z
Orange
Certain plastics can not be bonded to, for example: Delrin and Teflon and (me thinks) Polypro...
Old 04-13-2005, 01:19 PM   #9
tardypizza
Member#: 20122
RSV4 , KTM9fiddy
RSVR, '69 Vespa
Ah yes, the MIGPSAMBfaAOPF. I dealt with this exact issue last month. You wanna use JB weld.
Perhaps duct tape.
Would you believe.....chewing gum?
tardypizza is offline   Reply With Quote
Old 04-13-2005, 01:22 PM   #10
Undepelo
Member#: 34960
What would baby
Jesus say of OT?
No chance of a mechanical bond (screws, bolts, clips..bla bla..)?
I'd be worried about the bond in your case without more info/testing if you cant find a specific epoxy/glue for your materials that also has enough bond strength fatigue properties AND is resistant to salt water environment. If your base comes off, the signal will be lost and the equipment lost at sea? Is the bond surface big in proportion to the forces the antenna exerts?
Old 04-13-2005, 01:25 PM   #11
jond8
Member#: 62379
72 240z
Orange
God, I wish...
Not in this case. I think I'm just going to spec out ABS and then do some polypro bonding test to see if we can use it at a later date. ABS isn't a tough as polypro though and this base will be seeing some substantial bending moments....
Old 04-13-2005, 01:50 PM   #12
orbit03
Member#: 2300
2002 Impreza WRX
Banana Pudding
Go to mcmaster.com and order up some Scotch Weld DP8005. It should stick quite well. It is designed for polyolefins (Polypropylene, Polyethylene, TPO, etc). You'll need to order the gun, 10:1 ratio piston thing, and a bag of disposable mixing tubes. The stuff works great. We used it on a bunch of things. Good luck
<--- Plastics engineer
orbit03 is offline   Reply With Quote
Old 04-13-2005, 02:03 PM   #13
jond8
Member#: 62379
72 240z
Orange
Awesome thanks! I'll give it a shot. Have you had any experience bonding polyolefins with Loctite 380? This was recommended by a peer...
Old 04-13-2005, 02:22 PM   #14
orbit03
Member#: 2300
2002 Impreza WRX
Banana Pudding
Haven't tried the Loctite. I have to say that with any of these, you should test the bond (if possible). Also, try to rough up the surfaces a bit, this will help a lot (you know, that old maximizing the surface area thing). Also, make sure the surfaces are CLEAN. Isopropyl alcohol is a good, (relatively) safe solvent. Just remember that surface prep is everything in bonding. Good luck!
OT Credit Guru's: Possible "cheat" to improve credit. BhamRoadrunner Off-Topic 32 06-02-2010 03:46 PM
OT, why put OT in the title when you're in OT & everything is OT so no need to say OT Brad Pittiful Off-Topic 56 10-26-2009 03:30 PM
Fund to Send Teh OT GIRLZ to OT Drinkathon on 4/19? Subi Chicky Off-Topic 199 03-22-2003 11:49 AM
Daytime OT vs. Nighttime OT -=C=- Off-Topic 18 03-13-2003 11:11 AM
OT Today: is the stupidest OT day in a while GooseMan Off-Topic 26 01-21-2003 04:39 PM
