Old 04-13-2005, 04:15 PM   #1
anthonyrb98
Member#: 48307
02 bugeye
hbspeed tuned 18g sleeper
Default high flow cat placement question
just got a magnaflow high flow cat and was wondering if i can put it post downpipe? i have a full helix and i don't want to have the cat welded onto it. would it be ok the have it welded just right after my helix downpipe with the catback?
anthonyrb98 is offline   Reply With Quote
Old 04-13-2005, 04:51 PM   #2
snvin
Member#: 50578
2009 2.5i. Bleh.
-=Forza Azzurri=-
If it fits in that location, you COULD do it, and the farther back you put it the less of a restriction it becomes - BUT the farther back you put it the longer it takes to "light off" the catalyst, so puting it closer to the turbo means the catalyst can do its environmental job better.
Does that make sense?
snvin is offline   Reply With Quote
Old 04-13-2005, 05:51 PM   #3
anthonyrb98
Member#: 48307
02 bugeye
i don't really care about the environmental aspect (HA HA), I just need it to pass my yearly smog test.
Old 04-13-2005, 05:55 PM   #4
Focus4
Member#: 20107
2004 STi
well if you want it to pass shouldn't it be able to do its job?
Focus4 is offline   Reply With Quote
Old 04-13-2005, 05:55 PM   #5
Gethin
Member#: 2998
Let me know the results if u get it soon as i'm planning a similar setup later this year. I've got a metal substrate 3" cat going into the midpipe right after the Helix.
Gethin is offline   Reply With Quote
Old 04-13-2005, 06:05 PM   #6
stircas
Member#: 53886
put it where the stock 3rd cat was you will be fine for the test.i know from experience and before the o2 sensor and no cel's. if there not all ready taken care of.
stircas is offline   Reply With Quote
Old 04-13-2005, 06:10 PM   #7
Gethin
Member#: 2998
The Helix replaces the third stock cat too....it's full length.
Old 04-13-2005, 06:15 PM   #8
anthonyrb98
Member#: 48307
02 bugeye
yeah, i really don't want to hack up my helix. i'd rather have the cat welded into my catback just right after where the dp and catback bolt up.
Old 04-13-2005, 09:22 PM   #9
Jimbo
Member#: 28809
2003 WRX Wagon
Platinum Silver Metallic
Not sure how the helix is, but the scoobysport is similar to stock with two mid-pipes, so I had my Magnaflow welded in the front mid-pipe which is same as the stock location.
Jim
Jimbo is offline   Reply With Quote
Old 04-17-2005, 04:01 PM   #10
anthonyrb98
Member#: 48307
02 bugeye
bumppp
Old 04-17-2005, 04:06 PM   #11
silvscorp
Member#: 28480
put it where the stock 3rd cat is, right before your midpipe.
silvscorp is offline   Reply With Quote
Old 04-17-2005, 05:19 PM   #12
GoRacerXGo
Member#: 41605
2003 STG 4 WRX Sedan
Sonic Yellow
I have a random tech setup. It has no cat in the downpipe, and a cat in the 3rd pipe (before the catback). I got it for this same reason, I wanted there to be less turbulence going into the cat, and it being less restrictive. But I can see how the theory of the cat not "lighting up" could be possible. You should check it out. It's a great product.
GoRacerXGo is offline   Reply With Quote
Old 04-17-2005, 05:25 PM   #13
anthonyrb98
Member#: 48307
02 bugeye
well, my real question is whether or not there will be a big difference in terms of performance and the whole smog issue if i weld it into my helix dp where the 3rd cat would be or just right after in my catback piping. the main reason is that it would just be easier to take off the catback and have the cat welded into it than having to take off the downpipe to get the cat welded in.
Old 04-17-2005, 06:30 PM   #14
vitaminwrx
Member#: 46978
High flow cat, no matter where you place it, wont have a very big impact on overall performance.
vitaminwrx is offline   Reply With Quote
High Flow cat pipe questions ScubaruImpreza05 Normally Aspirated Powertrain 20 05-20-2009 10:41 PM
question about txs dp and high flow cat subbie_rs2.5 Factory 2.0L Turbo Powertrain 5 09-25-2003 11:32 AM
Looking for Universal High Flow Cat part # and specs, or suggest a 3 inch High Flow ciper Factory 2.0L Turbo Powertrain 4 07-17-2003 02:16 PM
Twister muffler and high-flow cat questions trhoppe Factory 2.0L Turbo Powertrain 1 11-07-2002 03:49 PM
Header and high flow Cat questions rhdude Mid Atlantic Impreza Club -- MAIC 19 03-04-2002 01:14 PM
Message Board Statistics All times are GMT -4. The time now is 12:00 AM.
