Old 04-13-2005, 05:07 PM   #1
EVOBOXR
Member#: 73648
Default LINK 44S + GM Boost Solenoid
Has anyone run this setup? Does anyone here use the LINK 44S??
EVOBOXR is offline   Reply With Quote
Old 04-13-2005, 06:02 PM   #2
Geek Guy
Member#: 8151
2002 WRX Rally Car
NASA Rallysport, yo!
Why not use the stock solenoid?
Geek Guy is offline   Reply With Quote
Old 04-14-2005, 11:29 AM   #3
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
links were some of the very first ecus on the market the had some real proublems .. the newer versions of the 44s are much better hope fully your is one of the newer versions .. (so no not many are still running the link44s)
Old 04-15-2005, 08:49 PM   #4
BALISTC
Member#: 24432
M800, TD06, EJ207
Stock solenoid is just fine, if your not running more than 1.4 bar.
If you want to run an aftermarket solenoid, look for an STi 3 port (not sure which JDM model had these though), or an Autronic or Motec solenoid. The Autronic and Motec solenoid are an Australian item, and are quite expensive (around 180 australian dollars), but they hold boost very nicely.
I've got a PossumLink 44S and I love it. Where I live in Perth, Western Australia, they are the ECU of choice for most WRX owners, the reason being there are 4 or 5 shops who can competently tune the Link within 20 miles of each other (its a small city, just over 1,000,000 people, but with a LOT of shops), and one of the tuners used to work for Possum Bourne Motorsport, IE the "Possum" part in the name PossumLink.
Once they are tuned well, they are capable of being a very smooth, nice running ECU. Just dont use a Walbro fuel pump with the later 44S ECUs...the early Links work well with the Walbros but the later ones dont. Bosch is the fuel pump of choice around here anyway, they are cheaper than the Walbros and flow more
BALISTC is offline   Reply With Quote
What do I need to adjust on my EM to run the GM Boost Solenoid mrtrex Engine Management & Tuning 6 11-14-2005 12:00 PM
When installing the GM Boost Solenoid do you keep plastic restrictor in Vacume Line mrtrex Engine Management & Tuning 3 11-13-2005 12:16 PM
gm boost solenoid? zachary.berrier Factory 2.0L Turbo Powertrain 3 07-07-2005 09:50 PM
gm boost solenoid operation question White 2.5rs Normally Aspirated with bolt-on Forced Induction Powertrain 5 04-03-2005 09:51 PM
Installing a GM boost solenoid today TheMadScientist New England Impreza Club Forum -- NESIC 15 08-01-2004 11:06 AM
Message Board Statistics All times are GMT -4. The time now is 08:18 PM.
