Old 04-13-2005, 05:08 PM   #1
OCrex
Member#: 78696
2005 Wingless STI
Default Idiot on water injection, help me!!!
Ok, i was just introduced to the wonderful work of wi. For someone who know absolutely nothing about it other than it sounds like a great idea, what kit should i buy and exactly what other components do i need? I would like to use the windshield fluid tank for the kit.
Help me out guys, i need websites, kit models and components to get me up and running. I'm going in for tuning next week and would like this set up before then.
Thanks,
OCrex is offline   Reply With Quote
Old 04-13-2005, 05:26 PM   #2
The Deliverator
Member#: 42376
2006 92x Aero
Midnight Black Metallic
Hop over to http://www.aquamist.co.uk/cp/cp.html and take a look at their kits. IMO, the 2d would be a great choice. It's also really expensive.
Then there's a bunch of other kits out there, mostly based around Shurflo pumps. Companies like SMC and Cooling Mist sell these, or you can build your own. IIRC, RiftsWRX here has instructions on how to do a homebrew kit on his web site, and a quick google'ing found this page here: http://members.cox.net/stevemonroe/AlcoholInjMod.html that's still one more version of the same idea.
Proportional control is a required feature for me, so I'm going to keep using Torco for my octane-enhancement needs until I either find a sweet deal on a 2d or make the time to build my own programable injection controller (to go with a custom shurflo-based kit).
Google is your friend. There's a water injection forum link off the Aquamist page, and I've heard the coolingmist.com dude is also super helpful.
The Deliverator is offline   Reply With Quote
Old 04-13-2005, 05:30 PM   #3
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Snowperformance.net has a "proportional" MAF kit.
wcbjr is offline   Reply With Quote
Old 04-13-2005, 06:28 PM   #4
hotrod
Member#: 14141
2002 Impreza WRX
e85forum.net
Delete contents because board does not give me the option to delete the multiple posts it generated.
hotrod is offline   Reply With Quote
Old 04-13-2005, 06:28 PM   #5
hotrod
Member#: 14141
2002 Impreza WRX
e85forum.net
Default Wi
Old 04-13-2005, 06:29 PM   #6
hotrod
Member#: 14141
2002 Impreza WRX
e85forum.net
Default Wi
Old 04-13-2005, 06:29 PM   #7
hotrod
Member#: 14141
2002 Impreza WRX
e85forum.net
A water injection setup is really not something to be slapped on in a couple of days. You need to take a bit of time to understand the concepts behind it and the many options out there. In addition to the above Aquamist has an open water injection forum at :
http://www.aquamist.co.uk/phpBB2/index.php
It encourages input from any WI user. There is a couple weeks of reading available on that site alone.
There are also MANY WI threads right here and on the other subaru forums only a search away, We've been seeing maybe 1 a week now for quite a while.
Take a couple of days to get up to speed on what WI and alcohol injection are all about then make your choices with an informed base of understanding. You'll be much happier with your setup in the long run if you do.
Larry
Old 04-13-2005, 07:38 PM   #8
boardertj
Member#: 64014
2004 WRX sedan
JBP fosho
ok does anyone have experience with water/alky injection on an 04? i read something somewhere that you will need the 2 stage setup like the aqumist 2d setup. i just wanted to know if this is true.
boardertj is offline   Reply With Quote
water injection help 25rsESP Normally Aspirated with bolt-on Forced Induction Powertrain 13 10-09-2005 05:23 PM
Water Injection Help beefyib123 Engine Management & Tuning 31 03-25-2005 10:08 PM
Water Injection...tell me what I need to know Porkchop-WRX Water/Methanol Injection, Nitrous & Intercooler Cooling 77 09-01-2003 11:41 AM
Thoughts on water injection DJWRX Water/Methanol Injection, Nitrous & Intercooler Cooling 29 11-30-2001 06:30 PM
What's the skinny on water injection in a turbo engine? Digital_Boy Technical Forum Archive 5 08-26-2000 12:08 AM
Message Board Statistics All times are GMT -4. The time now is 04:34 PM.
