Welcome to the North American Subaru Impreza Owners Club Thursday January 29, 2015
Old 04-13-2005, 07:25 PM   #1
CBRDSpeedfactory
Vendor
Member#: 68255
ALL lots of fast 1s
mostly silver!
Default what is good cylinder compression on the sti?
doing a test now, leakdown is fine...compression seems low, but we dont know what it should be
chad b
CBRDSpeedfactory is offline   Reply With Quote
Old 04-13-2005, 07:43 PM   #2
Visceral
Member#: 16367
2006 Subaru WRX STi
Visceral is offline   Reply With Quote
Old 04-13-2005, 08:00 PM   #3
kool168
Member#: 61006
let me copy and paste it here...
Compression (350 rpm and fully open throttle):
Standard
981 1,177 kPa (10 12 kgf/cm2, 142
171 psi)
Limit
882 kPa (9.0 kgf/cm2, 128 psi)
Difference between cylinders
Less than 49 kPa (0.5 kgf/cm2, 7 psi)
kool168 is offline   Reply With Quote
Old 04-13-2005, 10:26 PM   #4
WRXout
Member#: 52908
2005 WRX STI FTI 20G
ASPEN WHITE
chad b
05 sti is already down?
WRXout is offline   Reply With Quote
Old 04-13-2005, 11:01 PM   #5
CBRDSpeedfactory
Vendor
Member#: 68255
ALL lots of fast 1s
mostly silver!
its a test, i am installing forged pistons... i want to test before after...
cb
Old 04-13-2005, 11:39 PM   #6
happasaiyan
Member#: 37731
the 120 range seems most common
happasaiyan is online now   Reply With Quote
Old 04-13-2005, 11:47 PM   #7
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Really depends if you are doing it cold or not. If all the cylinders are relatively the same you are fine. If you have a bad piston it'll usually be at least 50psi lower than the rest. Mine tested out at like 145, 140, 142, 60.
Old 04-14-2005, 12:05 AM   #8
CBRDSpeedfactory
Vendor
Member#: 68255
ALL lots of fast 1s
mostly silver!
mine were all in the mid 120's...
just want to have a baseline..
thanks guys
cb
chadblock.com
Old 04-14-2005, 08:43 PM   #9
bboy
Member#: 56468
04 Improved STI
Dirty White
I've only seen 145-150 psi with one gauge. It this guage "accurate", no way to know. Is it "relatively accurate", yes it seems precise. Relative to one another, good cylinders are within 5 psi of each other.
Are you still working with the SBR turbo?
Old 04-14-2005, 08:50 PM   #10
CBRDSpeedfactory
Vendor
Member#: 68255
ALL lots of fast 1s
mostly silver!
switching to our own rotated setup, the beginning of may...
i found really that its sooo much easier to work on..
u figure u spend 2-300 for the inlet pipe... 200-250 on a big MAF conversion.... downpipe. 200-300..... and 1300-2000 for a turbo...
youve spent about 2100-2800 bucks...
we are going to supply a rotated option just above that...
ballbearing ceramic, with 4" inlet..
cb
Anyone get any good financing deals on the STi? 63Alpine New England Impreza Club Forum -- NESIC 13 12-24-2003 01:56 PM
What is this white stuff on the power seteering reservoir SubaruImpreza_power Newbies & FAQs 0 05-28-2003 02:10 PM
ok what is that stupid horn on the strut bar?? ScreaminFast Newbies & FAQs 14 02-21-2003 10:18 PM
Whats is it with idiots on the road? LinuxGuy New England Impreza Club Forum -- NESIC 14 12-23-2002 08:57 PM
What is that larger section on the mid-pipe? Arnie Normally Aspirated Powertrain 5 07-24-2001 11:47 PM
