Old 04-13-2005, 07:24 PM   #1
sregger
Member#: 82725
2001 Impreza RS
Default sti exhaust on an RS
i think the answer is yes, but i just wanna double check before i go and spend money on one.....will an 04 or an 05 STI stock exhaust fit on a 2001 RS? I have seen people mention it so i would assume that it is the diameter that i am looking for at 2.25 inches. Is there any customization that would have to be done to fit one on?
Thanks in advance for the feedback.
-Sean
sregger is offline   Reply With Quote
Old 04-13-2005, 07:48 PM   #2
jasonpham
Member#: 84530
2004 Impreza 2.5RS
Platinum Silver Metallic
It will not fit without some welding that needs to be done on the midpipe. The WRX and STi exhausts are signigicantly longer than that of the RS's so you would need to have a shop reweld the exhaust to fit. It would be more cost effecient to buy a used catback exhaust designed specifically for the RS.
Shoulda done a search.
jasonpham is offline   Reply With Quote
Old 04-13-2005, 07:48 PM   #3
goNads
Member#: 61888
2003 Outback Sport
Midnight Black Pearl
i have a 04 sti axle-back on a modified wrx midpipe on my 03 OBS... sounds better and performs better (butt dyno) than the wrx axle-back.
i know for a fact, that, an sti axle-back will mate (direct fit) to a wrx mid-pipe... not exactly the questions you asked, but it's what i know.
btw, as i understand it (lots of call/visits to exhust shops), the OD (not ID) of the sti axle-back is 2.5, so figure just a bit over 2.25 (a 2.25 OD pipe is useually [in my experiance] 2.12 ID)
assuming pipe thinkness is similar you're looking at ~2.37 ID on a sti axle-back.
goNads is offline   Reply With Quote
Old 04-13-2005, 09:52 PM   #4
JUstaszewski
Member#: 79123
i can tell you the sti muffler needs its flange cut off and repositioned or some carefull drilling to fit it on a 98rs's stock exhaust... but it does fit
JUstaszewski is offline   Reply With Quote
Old 04-13-2005, 11:00 PM   #5
ej25power
Member#: 14771
02 RS
All Silver!
I have one on my 02RS. I also had a wrx midpipe modified to fit my car, and a borla header.
http://www.wsu.edu/~johnson/MVI_1144.AVI vid of start up and idle and a little reving. Don't mind the condensation. Sounds TONS better than the WRX muffler. When I started it up after bolting it up, my buddy and I were like whoa ****
ej25power is offline   Reply With Quote
Sti exhaust on an 06 RS naku Newbies & FAQs 8 07-15-2008 11:41 AM
Can you put an 06 STi Exhaust on an 06 WRX Wagon? INDY_06_STI Interior & Exterior Modification 3 06-20-2006 09:51 AM
STi parts on an RS? AlpoRS Warranty Issues & SOA Problems 1 06-22-2005 09:39 PM
Exhaust On An RS? RSCaptain Normally Aspirated Powertrain 24 07-22-2003 09:27 PM
WRX exhaust on an RS? DoctorNick Normally Aspirated Powertrain 5 10-14-2002 11:33 AM
