Old 04-13-2005, 07:59 PM   #1
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
Default JDM Forester Turbo Engine Swap?
Hi,
I tried searching, but to no avail;
Is anyone familiar with the 1998 JDM Subaru Forester Turbo? My stock engine spun a bearing and I was offered the JDM one for $2000 and the seller claims it will push 260HP and be readily compatible with my '99 2.5RS. Is this true? Is it a good engine to swap? I would really appreciate any information on this engine and its suitability for a swap.
powerlabs is offline   Reply With Quote
Old 04-13-2005, 09:38 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
compatable yes
plenty of wireing yes
2000 is a good price if you get the full harness and ecu
no ecu and harness 1000 and a head ache
Old 04-13-2005, 11:50 PM   #3
powerlabs
Member#: 45790
SUPERCHARGED
Thank you for replying!
The package includes:
Engine, fuel pump (walbro), Turbo, IC, Downpipe, front crossmember, ECU, wiring harness... Basically everything I should need, for $2475 shipped to my location. Does that sound like a good deal? Is this a good engine to have?
Old 04-14-2005, 10:54 AM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
its not every thing you should need there is ALWAYS more crap to get ..
you will probably want a usdm WRX dp as the jdm dp is shorter and usdm length exhaust are readily available
make sure its the bulk head harness not just the engine harness you need all the stuff under the dash too
only 3 real questions
how do they do emissions where you live?
where are you going to find the wiring diagrams
will he give you a start up guarantee
Old 04-14-2005, 11:45 AM   #5
turbodiesel
Member#: 84988
a WRX STi engine (2500cc with 300hp) will be sufficient to create Forester STi... JDM use same engine, with 6 spd too ^^
turbodiesel is offline   Reply With Quote
Old 04-14-2005, 02:23 PM   #6
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
The only difference is JDM claims 260 to the wheels and puts 260 to the wheels the USDM claims 300 and puts 240~260 to the wheels!!
DuoMaxwell is offline   Reply With Quote
Old 04-14-2005, 02:31 PM   #7
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
turboD .. did you even read the thread?
Old 04-14-2005, 05:23 PM   #8
powerlabs
Member#: 45790
SUPERCHARGED
No emissions testing what so ever where I live
There is a start up guarantee
I don't know where to find the wiring diagram from. I am trying to find it or get it from them. They have the wiring diagram for the JDM WRX, and they said it should be basically the same. They also said that the downpipe should bolt right up to my RS cat converter and exhaust, but I might look into getting a used WRX downpipe anyways.
Does this engine really make 260HP at the wheels? I find that hard to believe with a T04 turbo.
Old 04-14-2005, 05:50 PM   #9
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
is it a td04
it has higher compression than a usmd motor
no it won't bolt to any thing RS
to start cheep get a used WRX turbo back <$50 (prollably free)
Old 04-14-2005, 07:28 PM   #10
powerlabs
Member#: 45790
SUPERCHARGED
Yeah. As far as I can tell the only difference between the JDM Forester Turbo and the JDM WRX is that the Forester uses a TD04 and the WRX a TD05. There could be more stuff though.
Allright, so I'll get the downpipe. Anything else you can think off besides the mentioned Motor, Crossmember, ECU, Wiring harness and fuel pump?
Who is using non turbo tranny with turbo engine swap? scurabus Subaru Conversions 9 01-02-2010 05:37 PM
JDM EJ20 BG5 twin turbo engine swap for sale!! geo88 Private 'For Sale' Classifieds 0 10-22-2004 06:51 AM
1.8 XT turbo engine swap, Any performance parts for the engine? andyrew Pre-2002 Factory Turbo Powertrain 4 02-22-2004 10:28 PM
Question about swapping in JDM EJ20 turbo engine and gasoline requirements edkwon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-20-2001 11:39 AM
