Old 04-14-2005, 12:25 AM   #1
EJ22Boom
Member#: 74050
Default idea's for a low budget 2.2L using the stock wrx block?
i currently have a stage 2 ecutech car with everybolt on accept a turbo upgrade, intercooler and fuel mods. i recent just finished another car and i'm thinking of parking the subie for a while and pulling the motor. i was wondering if i got a 2.2L stroker kit and did some headwork plus adding a P&P vf22, fuel mods, new TMIC and another reflash. would this combo pull like the stock turbo set up just a whole hell of alot stronger? i'm not looking for super high HP numbers or crasy boost, just a good set up for down low power and midrange with a little top end. i'm also thinking of throwing in a gearset too. any thoughts? or has anyone does this yet?
EJ22Boom is offline   Reply With Quote
Old 04-15-2005, 12:30 AM   #2
EJ22Boom
Member#: 74050
bump.
Old 04-15-2005, 01:04 AM   #3
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
A Stock 2.5 will be cheaper to do, make more power down low, and make more power up top, and make way more torque everywhere. The STi crank is better than any crank you will find. Well perhaps the JUN 2K crank is as good but the Cobb or Crawford $200 cranks are no where as nice. You can however do a Crawford crank for a few hundred in youy EJ205 and get 2.11L though. That is a chep way to do it.
If you want to pull stonger add a biggwer turbo or 20% more displacement or both. I make 200whp within 1000 rpm. It is 2.0 but the turbo is larger and I have AVCS.
ebeck is offline   Reply With Quote
Old 04-15-2005, 01:57 AM   #4
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
that sounds pretty cool i dont see it on his websight though.
santofontana is offline   Reply With Quote
Old 04-15-2005, 02:14 AM   #5
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
YA it is not. Call him for it. Like $125 too if I remember right. He can confirm.
Old 04-15-2005, 11:44 AM   #6
Crawford Performance
Member#: 42075
Look under the "Products" tab, then "Specials". You will find them listed at $99
Quirt Crawfiord
www.crawfordperformance.com
Crawford Performance is offline   Reply With Quote
Old 04-15-2005, 12:49 PM   #7
EJ22Boom
Member#: 74050
this is the kit i'm talking about. http://cobbtuning.com/wrx/engine-diykits.html
but if anyone knows a better way let me know. i like the fact that it's fully forged all the way.
Old 04-15-2005, 12:49 PM   #8
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
Quirt is the man. Sure wish they would make a fully balanced 8500 rpm 2.2 stroker kit.
Old 04-15-2005, 01:38 PM   #9
BadTrip
Member#: 62211
03 WRX
Sonic Yellow
Let me make sure I'm losing my mind........I can drop in that crank (which costs $100) and go to a 2.11L just like that? Nothing else needs to be changed?
I mean, I'm doing plenty of other mods right now....but I can bump displacement by 100cc simply by dropping in a $100 part?
I'm not a mechanic, as you can tell, but that sounds liek a pretty decent option to increase displacement by 5%. Always helps spooling right?
BadTrip is offline   Reply With Quote
Old 04-15-2005, 02:13 PM   #10
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
I would imagine pistons are required, and bearings. Cobbs price is $18xx.xx. Based on the price for Crawford's crank, plus about $500 for pistons, and say another $500+ for bearings and gaskets and everything else Im not thinking of like machine work, a setup from Crawford would be pretty reasonable. I wonder how much the added stroke hurts the ability to rev high?
Old 04-15-2005, 02:21 PM   #11
BadTrip
Member#: 62211
03 WRX
Sonic Yellow
Yeah, that's what I meant. I was under the impressions that you did a number of things at one time when you increased the displacement.....but....well.....what do you HAVE to do for just a longer stroke? Just rods and the crank?
Someone educate me, I'm a moron.....as if that wasn't evident already.
Old 04-15-2005, 02:25 PM   #12
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
I dont know if you could get away with just the crank, it might f up the quench area, or even make the piston hit a valve or two (maybe a head gasket could fix that), but doing the crank and rods would be pointless since the pistons are the weak point. I would do crank and pistons, and rods if you can afford it.
disclaimer - i am not an expert listen to what quirt and those guys have to say.
Old 04-15-2005, 02:26 PM   #13
SlideWRX
Member#: 3803
07 Mustang GT
Ford Crappy Paint White
What's the compression ratio change for this?
Tom
SlideWRX is offline   Reply With Quote
Old 04-15-2005, 02:42 PM   #14
EJ22Boom
Member#: 74050
bump. for more info on my cheap set up
Old 04-15-2005, 02:51 PM   #15
BadTrip
Member#: 62211
03 WRX
Sonic Yellow
If you're looking for low and mid-range power......and want it, for some strange reason from a 4-cyclinder, the cheapest way to get there is to start with the 2.5L. Find a junked Forester or something.
If you're all about low-end you might want to think big displacement......like V-8.
Old 04-15-2005, 03:04 PM   #16
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
http://www.projectwrx.com/modules.ph...howpage&pid=24 <--- the stroker project worked great, IMO... I'd just swap out the pistons with anything BUT JE's...
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 04-17-2005, 06:23 PM   #17
EJ22Boom
Member#: 74050
well this is what i thought of over the weekend. i could still get the turbo kit for 1125$ from gruppe-s (vf22, sti pinks, and a walbro). then buy the crank from crawford for 99$, and then a set of CP pistons .20 over for 420$. then top it off with some eagle rods for $360. all the work will be done at my school as a project while i'm in my high proformance class at school, so it basicly free . does anyone think this sounds like a good combo?
Old 04-17-2005, 08:03 PM   #18
mantra1
Member#: 23568
'08 Forester STi
Shaggin' Wagon Thrice
subscribed
mantra1 is offline   Reply With Quote
Old 04-18-2005, 01:03 AM   #19
EJ22Boom
Member#: 74050
bump.
Old 04-18-2005, 01:26 AM   #20
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
I would skip the rods and mod your injectors and get a 20g or green. vf22s are for stock motors
Old 04-18-2005, 01:26 AM   #21
blue fish
Member#: 72946
what about management? will the stock cpu work with a 2.2l stroke? will an aftermarket piggyback set up for a 2.0 run a 2.2 stroke well enought to drive it to a tune without damage?
blue fish is offline   Reply With Quote
Old 04-18-2005, 01:28 AM   #22
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
People are running 2.5 swaps with wrx ecus so it will be fine. His em appears to be ecutek.
Old 04-18-2005, 10:13 PM   #23
EJ22Boom
Member#: 74050
see i thought about that too, but i don't want that much lag. i like my set up now with the stock turbo P&P with all my mods and tunning because it's instant power whenever i push the pedal. i want to capture that again with this project, just on a much larger scale.
Old 04-21-2005, 03:29 PM   #24
EJ22Boom
Member#: 74050
bump.
WTB: stock exhaust for 98 impreza L 2.2L - western mass compleckz NESIC Private Classifieds 4 07-10-2010 11:44 AM
how much power will the stock wrx block take? ofay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 04-01-2005 02:56 PM
Can 2.5 rs owners use the stock turbo kit from a 02 wrx? OutkastWRX2 Normally Aspirated with bolt-on Forced Induction Powertrain 7 07-20-2004 11:17 PM
What other cars use the Stock WRX front pad? dahveed Brakes, Steering & Suspension 2 01-16-2003 01:44 PM
00 2.2L vs. 96 2.2L, where'd the power come from? 96Lconversion Normally Aspirated Powertrain 15 01-19-2001 12:32 AM
