Old 04-14-2005, 12:38 AM   #1
blackrexnj
Member#: 73594
Default duplicate
duplicate post
blackrexnj is offline   Reply With Quote
Old 04-14-2005, 02:26 AM   #2
fogdor
Member#: 45726
2007 Mazdaspeed3
Cosmic Blue
Don't run the car that way. The Unichip is an offset device it alters the signals going into an out of the ECU. Cobb mapping actually alters the maps on the ECU itself. You have one engine management lying to the other engine management. Dysfunction Junction.
fogdor is offline   Reply With Quote
Old 04-14-2005, 02:37 AM   #3
Drews_WRX
Member#: 20354
2005 SRT-4
POS Mopar stage 2
lets just say that I tried to run "brand X" piggy back on top of my "stock map".....car didnt make it out of the driveway.
Not the best of ideas....try and learn from the mistakes of others, not your own.**
**that being said, nobody has tried to do what I did.
Drews_WRX is offline   Reply With Quote
Old 04-14-2005, 11:11 AM   #4
BigJ04STi
Member#: 77239
2004 Impreza WRX
None
You probably can keep it like that, but it won't be optimal...
Many people have ECUtek reflashes to change base values, adjust for larger injectors to smooth out the idle, etc, then run a piggyback type system like an Xede or Utec...
There have been some really nice and smooth dynos when doing this. Since the AP is a reflash, it could be ok, however the stage 2 tune migh not be optimal or safe...if you have a custom new base tune, then you'd be ok.
BigJ04STi is offline   Reply With Quote
Old 04-14-2005, 11:21 AM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
NONO BAD bad!!!!
yes it will affect all sorts of things
unmarry the AP immediatly -(return to stock)
remove the unichip/emi or take it to some one that can then reinstall the AP
driving it in its current condition is a REALLLLY REALLLY bad idea.. if you have to stay out of boost
Put a stop to the New Year's Blues with a StopTech Stage 2 Kit or BBK! WorldOne Suspension/Brakes/Handling 21 02-07-2008 04:07 PM
Why does my 5.8 ghz phone interfere with my 2.4 ghz baby monitor? Cjchaps Off-Topic 2 11-27-2006 03:25 PM
does the vishnu unichip = turboxs unichip ants wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-18-2002 10:05 AM
TurboXS Stage 2, what exactly does the remapped unichip do? MrWRXNYC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-16-2002 10:27 PM
