Old 04-14-2005, 05:49 AM   #1
feiron
Member#: 62327
2005 WRB STI
[S600BY]
Default utec gurus, please check my map :)
I've been happy with the performance so far, but I never could find the right crossover point for me... so I did this to my timing map to avoid the hic cup when driving at/near the crossover point (currently at 25% for both timing and fueling)
I just need to know whether I'm on the right track or no... thanks for the inputs
WRX stage 2
Code:
Timing Map
250    [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]
500    [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]
750    [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]
1000   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]
1250   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]
1500   [-100]   [-100]   [-100]   [-100]     [29]     [27]     [26]     [26]     [26]     [26]     [26]
1750   [-100]   [-100]   [-100]   [-100]     [28]     [26]     [24]     [24]     [24]     [24]     [24]
2000   [-100]   [-100]   [-100]   [-100]     [26]     [24]     [22]     [22]     [22]     [22]     [22]
2250   [-100]   [-100]   [-100]   [-100]     [24]     [22]     [20]     [20]     [20]     [20]     [20]
2500   [-100]   [-100]   [-100]   [-100]     [22]     [20]     [19]     [18]     [18]     [18]     [18]
2750   [-100]   [-100]   [-100]   [-100]     [20]     [19]     [17]     [16]     [16]     [16]     [16]
3000   [-100]   [-100]   [-100]   [-100]     [18]     [17]     [16]     [16]     [15]     [15]     [15]
3250   [-100]   [-100]   [-100]   [-100]     [18]     [17]     [16]     [16]     [15]     [15]     [15]
3500   [-100]   [-100]   [-100]   [-100]     [18]     [17]     [16]     [16]     [15]     [15]     [15]
3750   [-100]   [-100]   [-100]   [-100]     [18]     [17]     [16]     [16]     [16]     [15]     [15]
4000   [-100]   [-100]   [-100]   [-100]     [18]     [18]     [17]     [17]     [17]     [16]     [16]
4250   [-100]     [20]     [20]     [20]     [19]     [19]     [18]     [18]     [18]     [17]     [16]
4500     [20]     [20]     [20]     [20]     [20]     [20]     [19]     [19]     [19]     [18]     [17]
4750     [20]     [20]     [20]     [20]     [20]     [20]     [20]     [20]     [20]     [19]     [18]
5000     [20]     [20]     [21]     [21]     [21]     [21]     [21]     [21]     [21]     [20]     [19]
5250     [20]     [20]     [21]     [21]     [22]     [22]     [22]     [21]     [21]     [20]     [20]
5500     [20]     [20]     [21]     [21]     [22]     [22]     [22]     [22]     [22]     [21]     [21]
5750     [20]     [20]     [21]     [21]     [22]     [22]     [22]     [22]     [22]     [21]     [21]
6000     [20]     [20]     [21]     [22]     [23]     [23]     [23]     [23]     [23]     [22]     [22]
6250     [20]     [21]     [22]     [22]     [23]     [23]     [23]     [23]     [23]     [22]     [22]
6500     [21]     [22]     [22]     [22]     [23]     [23]     [23]     [23]     [23]     [23]     [22]
6750     [21]     [22]     [23]     [23]     [23]     [23]     [23]     [23]     [23]     [23]     [22]
7000     [21]     [22]     [23]     [23]     [23]     [23]     [23]     [23]     [23]     [23]     [23]
7250     [21]     [22]     [23]     [23]     [23]     [23]     [23]     [23]     [23]     [23]     [23]
7500     [18]     [18]     [18]     [18]     [18]     [18]     [18]     [18]     [18]     [18]     [18]
7750     [18]     [18]     [18]     [18]     [18]     [18]     [18]     [18]     [18]     [18]     [18]
8000     [18]     [18]     [18]     [18]     [18]     [18]     [18]     [18]     [18]     [18]     [18]
8250     [18]     [18]     [18]     [18]     [18]     [18]     [18]     [18]     [18]     [18]     [18]
8500     [18]     [18]     [18]     [18]     [18]     [18]     [18]     [18]     [18]     [18]     [18]
8750     [18]     [18]     [18]     [18]     [18]     [18]     [18]     [18]     [18]     [18]     [18]
9000     [18]     [18]     [18]     [18]     [18]     [18]     [18]     [18]     [18]     [18]     [18]
feiron is offline   Reply With Quote
Old 04-14-2005, 08:20 AM   #2
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
Post a log.
rjrutzky is offline   Reply With Quote
Old 04-14-2005, 11:04 AM   #3
SlideWRX
Member#: 3803
07 Mustang GT
Ford Crappy Paint White
I was under the impression that the biggest part of the hiccup is due to Air/fuel changes.
Side note: why are you transitioning at 25%? I've seen this a lot lately and I haven't seen a good reason for it. I've been doing 60% for the last two years without problems.
Tom
SlideWRX is offline   Reply With Quote
Old 04-14-2005, 12:27 PM   #4
hippy
Member#: 36528
2002 Impreza Wrx
Like slide said, upping the crossover to something like 40 50 or 60% might help the hicky problem. If ya do it, make sure to try and keep the boost low below the crossover point.
peace
Old 04-14-2005, 01:15 PM   #5
feiron
Member#: 62327
2005 WRB STI
[S600BY]
I'm talking about the hic cup when you're driving through the crossover point and back... I tuned my fuel map up to 30% column using my stock sensor..
I used to have it at 20 but I keep driving on the borderline.. I logged my daily driving and found out that I usually drive either under 23tps or wot
I'll see how this new map work for a few days... I was hicup free last night
Old 04-14-2005, 01:34 PM   #6
x99percent
Member#: 27108
2004 STi
2004 A4
If you have much-larger-than-stock injectors, taking control earlier will help you avoid knock that results from sending the factory ECU an artifically low MAF signal.
With OLF, I ran mine at 30% with no driveability issues on 810cc injectors. I think most of what you "feel" is timing related, unless your AFRs at the crossover are *way* out of wack.
x99percent is offline   Reply With Quote
Old 04-14-2005, 02:46 PM   #7
hippy
Member#: 36528
2002 Impreza Wrx
He's stage 2 though.... Feiron. Imagine that you get the hesitation from running hard throttle fueling and going back to part throttle fueling while you're just cruising around. With the 25% tps threashold it happens a lot because you go to something like 30% tps, then when the boost starts kickin in and the car starts accelerating faster ya try to let off the gas a little so maintain the same acceleration. If ya change the tps threashold to something like 50%, you won't go to hard throttle fueling while cruising around and the hesitation will at the least happen a lot less often. Chances are that you will never even notice it at something like 50% tps because when you're going down through that tps range, you're usually trying to slow down and not just trying not to accelerate faster.
peace
Old 04-14-2005, 02:47 PM   #8
happasaiyan
Member#: 37731
FWIW, i transition at 20%
happasaiyan is online now   Reply With Quote
Old 04-14-2005, 02:51 PM   #9
hippy
Member#: 36528
2002 Impreza Wrx
That doesn't say much. With wrx's that have stock turbos, it's easier to have higher crossover points because the turbo can actually hold low boost. When ya have something like a stock sti turbo(ihi) or bigger that can't hold boost as low as a stock wrx turbo, it's more necessary to have a lower tps threashold to try and avoid ptfb.
peace
Old 04-14-2005, 03:07 PM   #10
feiron
Member#: 62327
2005 WRB STI
[S600BY]
the hesitation I've had was timing related... seemed like I had shaky feet ... my tps would go up to 21 and drop to 20 and 19 and 21 and 20 when I had the crossover at 20%
here's my log of today's daily driving
Code:
     DATA1
                    Load Knock                     Mod   Mod         Mod
 RPM   MAP  MAF TPS Site Count  AFR  Ign#1  Inj#1  Ign   Fuel Boost  MAF
       psia  V   %                    deg   duty   deg    %   (CL)    V
 2350  -6.7 2.1   7  00    00   13.5 +36.7    9.6 ECU.   +0.0 ECU.   2.1
 3214  -7.3 2.3  10  00    00   13.4 +35.3   11.1 ECU.   +0.0 ECU.   2.4
 3300  -7.1 2.4  11  00    00   13.6 +35.3   10.9 ECU.   +0.0 ECU.   2.4
 3436  -6.5 2.4  11  00    00   13.6 +35.2   11.4 ECU.   +0.0 ECU.   2.4
 3580  -6.5 2.5  12  00    00   13.3 +34.8   14.6 ECU.   +0.0 ECU.   2.5
 3762  -6.1 2.6  13  00    00   13.3 +35.8   16.7 ECU.   +0.0 ECU.   2.6
 3963  -5.9 2.6  14  00    00   13.4 +35.3   19.3 ECU.   +0.0 ECU.   2.7
 4171  -5.3 2.8  16  00    00   13.6 +31.2   21.4 ECU.   +0.0 ECU.   2.9
 4357  -4.5 2.9  17  00    00   14.6 +32.0   22.2 ECU.   +0.3 ECU.   3.0
 4559  -3.8 3.0  17  00    00   12.3 +31.7   28.9 +20.0  +0.6 ECU.   2.7
 4177  -4.7 2.9   0  00    00   13.1  +8.9   20.7 ECU.   +0.0 ECU.   2.8
 3926  -6.7 2.6   0  00    00   rich  +9.0   21.4 ECU.   +0.0 ECU.   2.6
 3561  -8.9 2.4   0  00    00   23.4  +9.0   21.4 ECU.   +0.0 ECU.   2.4
 3293 -11.2 2.2   0  00    00   23.7 +11.5   21.4 ECU.   +0.0 ECU.   2.1
 3022 -11.8 2.3   9  00    00   23.7 +19.6   12.6 ECU.   +0.0 ECU.   2.3
 3186 -11.0 2.3   9  00    00   rich +26.2    9.2 ECU.   +0.0 ECU.   2.3
 2944 -10.0 2.3   9  00    00   14.3 +35.4   10.0 ECU.   +0.0 ECU.   2.3
 2973  -8.7 2.3   9  00    00   13.8 +34.9   11.9 ECU.   +0.0 ECU.   2.3
 3030  -7.7 2.3  11  00    00   13.5 +34.5   11.9 ECU.   +0.0 ECU.   2.4
 3072  -7.1 2.5  15  00    00   13.5 +32.8   14.9 ECU.   +0.0 ECU.   2.6
 3186  -5.9 2.7  18  00    00   13.9 +31.7   16.2 ECU.   +0.0 ECU.   2.7
 3280  -4.3 2.8  19  00    00   14.1 +31.3   18.4 ECU.   +0.0 ECU.   2.8
 3394  -2.6 2.9  20  00    00   14.3 +30.6   18.4 ECU.   +0.0 ECU.   2.9
 3519  -1.0 3.0  20  00    00   14.8 +28.6   22.9 ECU.   +0.0 ECU.   3.0
 3642  +0.0 3.1  22  00    00   14.6 +26.7   24.8 ECU.   +0.0 ECU.   3.1
 3766  +1.1 3.1  22  00    00   14.8 +26.0   27.4 ECU.   +0.0 ECU.   3.2
 3885  +2.1 3.2  22  00    00   14.4 +26.0   25.8 ECU.   +0.0 ECU.   3.2
 4045  +2.7 3.2  22  00    00   14.8 +26.0   28.7 ECU.   +0.0 ECU.   3.2
 4125  +3.1 3.2  23  00    00   14.5 +25.3   29.1 ECU.   +0.0 ECU.   3.3
 4268  +3.1 3.3  22  00    00   14.6 +23.4   30.6 ECU.   +0.0 ECU.   3.3
 4450  +2.9 3.3  23  00    00   rich +22.1   38.7 ECU.   +0.4 ECU.   3.4
 4547  +2.5 3.3  23  00    00   rich +20.9   44.2 +20.0  +0.6 ECU.   3.4
 4668  +2.3 3.4  24  00    00   rich +20.7   44.7 +20.0  +0.6 ECU.   3.4
 4830  +2.1 3.4  24  00    00   rich +21.5   50.8 +20.0  +0.6 ECU.   3.5
 4901  +1.7 3.3   9  00    00   rich +36.8    9.0 +20.0  +0.6 ECU.   3.1
 4559  -1.2 3.0   0  00    00   13.3  +8.7   27.3 ECU.   +0.6 ECU.   2.9
 4198  -4.0 2.7   0  00    00   rich  +8.8   17.7 ECU.   +0.0 ECU.   2.6
 3903  -7.3 2.5   0  00    00   20.1  +8.9   17.7 ECU.   +0.0 ECU.   2.4
 3588 -10.0 2.3   0  00    00   23.7  +9.0   17.7 ECU.   +0.0 ECU.   2.3
 3584 -10.0 2.4  10  00    00   22.7 +26.3   12.8 ECU.   +0.0 ECU.   2.4
 3454  -9.4 2.4  11  00    00   14.9 +35.4   14.0 ECU.   +0.0 ECU.   2.4
 3457  -7.9 2.7  17  00    00   14.7 +32.9   17.4 ECU.   +0.0 ECU.   2.7
 3531  -5.9 2.8  17  00    00   12.7 +31.8   18.1 ECU.   +0.0 ECU.   2.8
 3527  -3.8 2.8  17  00    00   13.2 +31.5   19.9 ECU.   +0.0 ECU.   2.8
 3572  -2.6 2.9  17  00    00   13.3 +31.4   20.0 ECU.   +0.0 ECU.   2.9
 3611  -1.6 2.9  17  00    00   13.9 +31.3   20.6 ECU.   +0.0 ECU.   2.9
 3703  -1.2 2.9  17  00    00   14.7 +29.6   22.5 ECU.   +0.0 ECU.   3.0
 3728  -0.8 3.0  18  00    00   14.4 +29.2   21.7 ECU.   +0.0 ECU.   3.0
 3728  -0.2 3.0  18  00    00   14.6 +29.2   24.3 ECU.   +0.0 ECU.   3.0
 3792  +0.4 3.0  18  00    00   14.7 +29.1   22.4 ECU.   +0.0 ECU.   3.0
 3844  +0.8 3.0  17  00    00   14.4 +29.5   24.7 ECU.   +0.0 ECU.   3.0
 3858  +1.1 3.0  17  00    00   14.5 +29.6   22.7 ECU.   +0.0 ECU.   3.0
 3898  +0.8 2.8   7  00    00   14.0 +32.5   17.8 ECU.   +0.0 ECU.   2.6
 3968  -2.0 2.8   0  00    00   rich +23.8   14.8 ECU.   +0.0 ECU.   2.7
 3930  -5.3 2.6   0  00    00   20.6 +17.6   14.8 ECU.   +0.0 ECU.   2.5
 3885  -8.5 2.4   0  00    00   23.7  +8.9   14.8 ECU.   +0.0 ECU.   2.3
 1151  -8.5 1.5   1  00    00   14.7 +25.3    3.0 ECU.   +0.0 ECU.   1.5
 1151  -8.5 1.5   1  00    00   14.7 +25.4    3.0 ECU.   +0.0 ECU.   1.6
 1143  -8.3 1.9   7  00    00   14.4 +25.3    5.9 ECU.   +0.0 ECU.   1.9
 1334  -7.5 1.9   7  00    00   rich +19.3    4.9 ECU.   +0.0 ECU.   1.9
 1538  -6.5 2.0   7  00    00   14.5 +25.9    6.4 ECU.   +0.0 ECU.   2.0
 1665  -5.7 2.0   6  00    00   14.1 +29.8    6.4 ECU.   +0.0 ECU.   2.0
 1657  -5.1 2.0   8  00    00   14.1 +29.9    7.4 ECU.   +0.0 ECU.   2.0
 1586  -5.1 2.0   7  00    00   13.5 +29.2    6.0 ECU.   +0.0 ECU.   2.0
 1526  -5.1 2.0   8  00    00   13.7 +27.9    6.3 ECU.   +0.0 ECU.   2.0
 1675  -4.9 2.0   7  00    00   13.3 +28.0    6.7 ECU.   +0.0 ECU.   2.1
 1812  -4.7 2.1  10  00    00   13.8 +30.1    7.4 ECU.   +0.0 ECU.   2.1
 2021  -4.3 2.3  12  00    00   13.5 +32.5   10.2 ECU.   +0.0 ECU.   2.3
 2222  -3.8 2.3  13  00    00   13.3 +32.3   11.5 ECU.   +0.0 ECU.   2.3
 2427  -3.4 2.4  13  00    00   13.4 +32.5   12.4 ECU.   +0.0 ECU.   2.4
 2630  -3.0 2.5  14  00    00   13.5 +32.5   13.0 ECU.   +0.0 ECU.   2.5
 2824  -3.0 2.6  16  00    00   13.5 +32.7   15.8 ECU.   +0.0 ECU.   2.6
 3092  -2.6 2.7  17  00    00   12.9 +31.6   18.4 ECU.   +0.0 ECU.   2.7
 3303  -2.0 2.8  19  00    00   13.1 +30.5   19.2 ECU.   +0.0 ECU.   2.9
 3615  -1.4 3.0  21  00    00   13.5 +28.9   22.6 ECU.   +0.0 ECU.   3.0
 3858  -0.4 3.1  22  00    00   13.6 +27.1   28.0 ECU.   +0.0 ECU.   3.1
 4219  +0.6 3.2  22  00    00   13.8 +25.6   29.6 ECU.   +0.0 ECU.   3.2
 4504  +1.5 3.3  22  00    00   13.8 +22.9   39.9 +20.0  +0.6 ECU.   3.3
 4161  +0.2 2.9   0  00    00   12.9  +8.8   20.6 ECU.   +0.0 ECU.   2.9
 3813  -2.4 2.7   0  00    00   12.9  +8.9   16.8 ECU.   +0.0 ECU.   2.6
 3568  -5.7 2.5   0  00    00   12.9  +9.1   16.8 ECU.   +0.0 ECU.   2.4
 3306  -8.9 2.3   0  00    00   23.7  +9.2   16.8 ECU.   +0.0 ECU.   2.2
 3016 -10.6 2.1   0  00    00   23.4 +13.3   19.9 ECU.   +0.0 ECU.   2.2
 3055 -10.6 2.3  11  00    00   rich +19.6   10.3 ECU.   +0.0 ECU.   2.3
 2949  -9.6 2.4  13  00    00   14.6 +33.6   11.3 ECU.   +0.0 ECU.   2.4
 2662  -7.9 2.5  14  00    00   13.3 +33.5   12.2 ECU.   +0.0 ECU.   2.5
 2796  -5.9 2.6  17  00    00   14.2 +32.5   15.1 ECU.   +0.0 ECU.   2.6
 2876  -3.8 2.8  22  00    00   13.9 +29.4   19.7 ECU.   +0.0 ECU.   2.8
 2981  -2.4 2.8  22  00    00   13.4 +26.9   20.2 ECU.   +0.0 ECU.   2.9
 3080  -0.8 2.9  24  00    00   13.4 +24.7   22.2 ECU.   +0.0 ECU.   3.0
 3236  +0.8 3.1  26  20    00   13.3 +22.9   28.3 ECU.   -1.3 ECU.   3.0
 3360  +2.3 3.2  28  30    00   rich +21.7   32.5 ECU.   -1.2 ECU.   3.1
 3494  +3.7 3.2  29  30    00   rich +22.5   33.4 ECU.   -1.2 ECU.   3.1
 3658  +4.7 3.2  29  30    00   rich +22.9   35.1 ECU.   -1.2 ECU.   3.2
 3783  +5.5 3.3  31  30    00   rich +21.0   41.1 ECU.   -1.0 ECU.   3.3
 3987  +6.4 3.5  42  40    00   rich +17.5   52.7 +18.0  +0.4 223.00 3.6
 4198  +7.6 3.6  42  50    00   rich +15.1   59.3 +18.4  +0.8 227.00 3.6
 4329  +9.0 3.6  42  60    00   rich +14.5   65.9 +18.1  +1.5 227.00 3.8
 4450 +10.0 3.7  42  60    00   rich +14.3   69.7 +18.8  +1.5 227.00 3.8
 4610 +10.4 3.8  42  60    00   rich +15.7   74.6 +19.8  +1.2 227.00 3.8
 4844 +10.0 3.8  42  50    00   rich +17.9   78.0 +20.2  +0.5 226.00 3.8
 4830  +9.4 3.7  13  00    00   rich +28.0   36.8 +20.0  +0.6 226.00 3.3
 4420  +4.7 3.1   0  00    00   rich  +8.8   32.4 ECU.   +0.3 ECU.   3.0
 4130  +0.0 2.8   0  00    00   14.9  +8.9   32.4 ECU.   +0.0 ECU.   2.7
 3858  -4.7 2.5   0  00    00   24.0  +9.0   32.4 ECU.   +0.0 ECU.   2.4
 3538  -9.1 2.3   0  00    00   24.0  +9.2   32.4 ECU.   +0.0 ECU.   2.3
 3631  -8.9 2.6  15  00    00   23.7  +6.9   13.6 ECU.   +0.0 ECU.   2.8
 3465  -7.3 2.8  15  00    00   15.0 +31.8   19.8 ECU.   +0.0 ECU.   2.8
 3531  -5.1 2.9  20  00    00   14.4 +31.0   22.7 ECU.   +0.0 ECU.   3.0
 3627  -2.4 3.0  23  00    00   13.6 +27.5   26.3 ECU.   +0.0 ECU.   3.1
 3615  +0.2 3.3  32  20    00   12.7 +22.9   36.9 ECU.   -1.3 ECU.   3.2
 3724  +2.9 3.4  34  30    00   rich +18.2   43.8 ECU.   -1.2 219.00 3.4
 3762  +5.3 3.5  34  50    00   rich +15.3   48.6 +17.2  +1.2 219.00 3.5
 3894  +7.8 3.5  34  60    00   rich +15.6   50.2 +16.4  +2.1 219.00 3.6
 3958  +9.0 3.5  34  50    00   rich +16.5   49.0 +17.8  +0.9 219.00 3.5
 4006  +9.4 3.5  33  50    00   rich +16.5   54.0 +18.2  +0.8 219.00 3.5
 4030  +7.0 3.1   0  00    00   rich +21.2   11.1 ECU.   +0.0 ECU.   3.0
 3954  +2.5 2.9   0  00    00   13.8 +16.2   11.1 ECU.   +0.0 ECU.   2.8
 3615  -2.0 2.6   0  00    00   lean  +9.1   11.1 ECU.   +0.0 ECU.   2.5
 3373  -6.3 2.3   0  00    00   24.0  +9.2   11.1 ECU.   +0.0 ECU.   2.2
 3115  -8.7 2.1   0  00    00   24.2 +11.5   11.1 ECU.   +0.0 ECU.   2.1
 2856  -8.9 2.0   0  00    00   24.0 +11.6   11.1 ECU.   +0.0 ECU.   2.0
 2748  -9.4 2.0   0  00    00   23.7 +11.6   11.1 ECU.   +0.0 ECU.   1.9
 3033 -11.6 2.0   0  00    00   rich +11.6    8.0 ECU.   +0.0 ECU.   2.0
 3024 -12.0 2.0   0  00    00   rich +11.4    8.0 ECU.   +0.0 ECU.   2.0
 3011 -12.6 2.0   0  00    00   17.3 +11.4    8.0 ECU.   +0.0 ECU.   2.0
 3072 -12.6 2.1   6  00    00   24.5 +27.8    9.5 ECU.   +0.0 ECU.   2.2
 3063 -11.2 2.5  15  00    00   13.8 +17.9    4.0 ECU.   +0.0 ECU.   2.6
 3115  -8.5 2.7  22  00    00   13.5 +31.7   17.4 ECU.   +0.0 ECU.   2.7
 3089  -5.5 2.8  23  00    00   13.7 +29.4   19.1 ECU.   +0.0 ECU.   2.9
 3177  -2.2 3.0  26  10    00   13.5 +25.4   28.4 ECU.   -1.3 ECU.   3.0
 3220  +0.4 3.1  30  20    00   rich +22.7   30.6 ECU.   -1.3 ECU.   3.1
 3284  +2.7 3.2  30  30    00   rich +19.0   34.9 ECU.   -1.2 215.00 3.3
 3360  +5.3 3.3  30  50    00   rich +15.4   43.0 +17.0  +1.3 215.00 3.4
 3408  +7.6 3.3  32  60    00   rich +14.8   41.3 +16.0  +2.2 217.00 3.4
 3461  +9.2 3.4  33  60    00   rich +14.9   45.8 +16.0  +2.2 218.00 3.4
 3599  +9.8 3.4  33  50    00   rich +14.9   49.6 +17.0  +1.3 217.00 3.4
 3658  +9.8 3.4  34  50    00   rich +14.9   47.4 +17.0  +1.3 218.00 3.5
 3757  +9.4 3.5  34  50    00   rich +14.6   49.9 +17.0  +1.2 219.00 3.5
 3822  +9.4 3.5  36  60    00   rich +15.2   50.2 +16.3  +2.1 220.00 3.6
 3889  +9.8 3.5  36  60    00   rich +15.0   53.5 +16.6  +2.1 220.00 3.6
 3968 +10.2 3.5  36  60    00   rich +15.6   54.0 +17.0  +1.7 221.00 3.6
 4040 +10.0 3.6  36  50    00   rich +16.0   57.2 +18.1  +0.8 221.00 3.6
 4110 +10.0 3.6  36  50    00   rich +15.9   59.0 +18.6  +0.8 221.00 3.6
 4224  +9.8 3.6  36  60    00   rich +16.3   61.7 +17.8  +1.7 221.00 3.7
 4295 +10.0 3.7  36  60    00   rich +15.3   66.0 +18.1  +1.6 221.00 3.7
 4380 +10.0 3.7  36  60    00   rich +15.2   67.5 +18.4  +1.5 220.00 3.7
 4432 +10.0 3.7  36  50    00   rich +15.8   65.5 +19.7  +0.8 220.00 3.7
 4301  +8.8 3.1   1  00    00   rich +31.0   30.3 ECU.   +0.1 220.00 3.1
 4426  +4.1 3.0   0  00    00   rich  +8.6   28.5 ECU.   +0.2 ECU.   3.0
 2362  -8.3 2.3  12  00    00   14.5 +36.2   10.2 ECU.   +0.0 ECU.   2.3
 2354  -7.3 2.3  12  00    00   13.9 +34.4   11.4 ECU.   +0.0 ECU.   2.3
 2424  -5.7 2.5  17  00    00   13.8 +30.4   13.9 ECU.   +0.0 ECU.   2.5
 2517  -3.8 2.6  21  00    00   13.4 +29.1   15.1 ECU.   +0.0 ECU.   2.7
 2616  -2.2 2.7  23  00    00   13.8 +26.7   16.8 ECU.   +0.0 ECU.   2.7
 2754  -0.8 2.9  28  10    00   14.5 +23.7   21.5 ECU.   -1.3 ECU.   2.8
 2836  +1.1 3.0  28  20    00   rich +21.3   26.5 ECU.   -1.3 ECU.   3.0
 2968  +2.7 3.1  29  30    00   rich +19.5   28.9 ECU.   -1.2 ECU.   3.0
 3095  +4.1 3.1  30  30    00   rich +18.4   30.3 ECU.   -1.2 215.00 3.1
 3258  +5.5 3.3  30  40    00   rich +16.8   36.6 +18.0  +0.4 215.00 3.2
 3422  +6.8 3.3  30  40    00   rich +16.1   40.1 +18.0  +0.4 215.00 3.3
 3568  +7.8 3.3  30  50    00   rich +15.0   46.6 +17.0  +1.3 215.00 3.4
 3720  +8.4 3.4  31  50    00   rich +15.4   47.9 +17.1  +1.2 216.00 3.5
 3907  +9.0 3.5  32  50    00   rich +16.0   48.3 +17.5  +1.0 217.00 3.5
 4035  +9.2 3.5  31  50    00   rich +16.5   56.0 +18.2  +0.8 216.00 3.5
 4208  +9.4 3.6  32  50    00   rich +15.8   57.4 +18.9  +0.8 217.00 3.6
 4351  +9.0 3.6  33  50    00   rich +16.8   63.4 +19.6  +0.8 218.00 3.7
 4559  +9.2 3.7  34  50    00   rich +17.0   66.0 +20.0  +0.7 219.00 3.8
 4755  +8.6 3.8  36  50    00   rich +18.0   70.6 +20.0  +0.6 221.00 3.8
 4945  +8.4 3.8  36  50    00   rich +19.4   72.8 +20.5  +0.2 221.00 3.9
 5042  +8.6 3.8  36  50    00   rich +19.6   74.9 +21.5  +0.1 221.00 3.9
 5232  +8.8 3.9  36  50    00   rich +21.8   77.0 +21.8  -0.2 221.00 3.7
 4816  +5.7 3.2   0  00    00   12.1  +8.7    4.4 +20.0  +0.6 ECU.   3.2
 4510  +1.3 3.0   0  00    00   rich  +8.8    4.4 ECU.   +0.4 ECU.   2.9
 4224  -3.2 2.7   0  00    00   lean  +8.9    4.4 ECU.   +0.0 ECU.   2.6
 3871  -8.3 2.4   0  00    00   24.2  +9.0    4.4 ECU.   +0.0 ECU.   2.4
 4016  -8.7 2.9  20  00    00   12.7 +26.9   19.4 ECU.   +0.0 ECU.   3.0
 3627  -6.9 3.0  21  00    00   14.1 +28.9   23.4 ECU.   +0.0 ECU.   3.0
 3827  -3.8 3.2  26  10    00   12.9 +25.3   34.5 ECU.   -1.1 ECU.   3.2
 3766  -0.2 3.3  30  30    00   rich +22.2   38.6 ECU.   -0.7 ECU.   3.3
 3875  +3.1 3.4  33  30    00   rich +19.7   45.3 ECU.   -0.8 218.00 3.4
 3968  +5.9 3.6  36  50    00   rich +16.0   54.4 +17.9  +0.9 221.00 3.6
 4045  +7.8 3.5  36  60    00   rich +15.8   58.1 +17.0  +1.7 221.00 3.6
 4050  +9.4 3.5  36  60    00   rich +15.3   57.7 +17.2  +1.9 221.00 3.6
 4135 +10.2 3.5  36  60    00   rich +16.1   58.1 +17.5  +1.9 220.00 3.6
 4198 +10.0 3.6  34  50    00   rich +16.4   59.5 +19.0  +0.8 219.00 3.6
 4290  +9.8 3.6  34  50    00   rich +17.0   64.4 +19.3  +0.8 219.00 3.6
 4257  +7.2 3.1   0  00    00   rich  +8.6   25.8 ECU.   +0.2 ECU.   3.1
 4203  +2.7 3.0   0  00    00   rich  +8.8   25.8 ECU.   +0.0 ECU.   2.9
 4203  -1.8 2.7   0  00    00   lean  +8.8   25.8 ECU.   +0.0 ECU.   2.6
my ignition advance multiplier is low, I had knocks last night ... temperature dropped to 2 degrees (celcius)... boost was right at 1.1 at 4th... stage 2 base fuel map.. but the CEL just blinked right after shifting to 4th and going on wot... didnt record a log though...
Old 04-14-2005, 03:28 PM   #11
SlideWRX
Member#: 3803
07 Mustang GT
Sounds like shift knock, I gotta reccomend the guide here:
http://www.wrxhackers.com/forums/showthread.php?t=2498
Tom
Old 04-14-2005, 03:48 PM   #12
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Also I'd do some SERIOUS work on that timing map, overall it's quite poor
Hippy: I make it a general rule to take the time to setup transitions in the 20-25% range. They work fine, even on long term use, just a matter of mapping the transition nuances to the individual driver and their habits.
That way you can run part throttle full boost, and reap the benefits of a fatter, midrange, etc.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 04-14-2005, 04:14 PM   #13
feiron
Member#: 62327
2005 WRB STI
[S600BY]
Tom
I've been through the tuning guide many times ... I was trying to have 21 at 0% ... guess it didnt work ... now I lock it down to 20
Old 04-14-2005, 04:16 PM   #14
feiron
Member#: 62327
2005 WRB STI
[S600BY]
Jorge (RiftsWRX)
www.ProjectWRX.com
please let me know how its poor .... not enough advance? or too advance at the mid rpm range?
Old 04-14-2005, 04:45 PM   #15
hippy
Member#: 36528
2002 Impreza Wrx
It's not normal to have lower timing values in lower load sites compared to higher ones at a given rpm.
peace
Old 04-14-2005, 05:15 PM   #16
feiron
Member#: 62327
2005 WRB STI
[S600BY]
should it be something like this
Code:
Timing Map
   [-100]   [-100]   [-100]   [-100]     [28]     [27]     [26]     [26]     [26]     [26]     [26]
   [-100]   [-100]   [-100]   [-100]     [27]     [26]     [24]     [24]     [24]     [24]     [24]
   [-100]   [-100]   [-100]   [-100]     [20]     [18]     [17]     [16]     [16]     [16]     [16]
   [-100]   [-100]   [-100]   [-100]     [18]     [17]     [17]     [17]     [17]     [16]     [16]
   [-100]     [20]     [20]     [20]     [19]     [18]     [18]     [18]     [18]     [17]     [16]
     [20]     [20]     [20]     [20]     [20]     [19]     [19]     [19]     [19]     [18]     [17]
     [21]     [21]     [21]     [21]     [21]     [21]     [21]     [21]     [21]     [20]     [19]
     [22]     [22]     [22]     [22]     [22]     [22]     [22]     [21]     [21]     [20]     [20]
     [22]     [22]     [22]     [22]     [22]     [22]     [22]     [22]     [22]     [21]     [21]
     [23]     [23]     [23]     [23]     [23]     [23]     [23]     [23]     [23]     [22]     [22]
     [23]     [23]     [23]     [23]     [23]     [23]     [23]     [23]     [23]     [23]     [22]
     [23]     [23]     [23]     [23]     [23]     [23]     [23]     [23]     [23]     [23]     [23]
or this one
Code:
Timing Map
   [-100]     [35]     [35]     [35]     [35]     [34]     [33]     [33]     [33]     [33]     [33]
   [-100]     [35]     [35]     [35]     [34]     [33]     [32]     [32]     [32]     [32]     [32]
   [-100]     [35]     [35]     [34]     [33]     [32]     [31]     [31]     [31]     [31]     [31]
   [-100]     [35]     [34]     [33]     [32]     [31]     [30]     [29]     [29]     [29]     [29]
   [-100]     [35]     [34]     [32]     [31]     [29]     [28]     [27]     [27]     [27]     [27]
   [-100]     [35]     [33]     [32]     [30]     [28]     [26]     [25]     [25]     [25]     [25]
   [-100]     [34]     [32]     [31]     [29]     [27]     [24]     [23]     [23]     [23]     [23]
   [-100]     [33]     [31]     [29]     [27]     [24]     [22]     [20]     [20]     [20]     [20]
   [-100]     [32]     [30]     [27]     [25]     [23]     [21]     [19]     [18]     [18]     [18]
   [-100]     [30]     [28]     [25]     [22]     [20]     [18]     [17]     [16]     [16]     [16]
   [-100]     [28]     [25]     [22]     [20]     [18]     [17]     [16]     [15]     [15]     [15]
   [-100]     [26]     [24]     [22]     [20]     [18]     [17]     [16]     [15]     [15]     [15]
   [-100]     [25]     [23]     [21]     [19]     [18]     [17]     [16]     [15]     [15]     [15]
   [-100]     [24]     [23]     [21]     [19]     [18]     [17]     [16]     [16]     [15]     [15]
   [-100]     [23]     [22]     [21]     [19]     [19]     [18]     [17]     [17]     [16]     [16]
   [-100]     [21]     [21]     [20]     [19]     [19]     [19]     [18]     [18]     [17]     [16]
     [20]     [20]     [20]     [20]     [20]     [20]     [20]     [19]     [19]     [19]     [18]
     [20]     [20]     [20]     [20]     [20]     [20]     [20]     [20]     [20]     [20]     [19]
     [21]     [21]     [21]     [21]     [21]     [21]     [21]     [21]     [21]     [20]     [20]
Old 04-14-2005, 06:20 PM   #17
hippy
Member#: 36528
2002 Impreza Wrx
That might depend on who you ask. I don't think it would be so bad to have the ecu control timing in low rpm low load sites. Course if the ecu detects knock in higher rpm areas, the ecu might retard timing all around(and hurt low end hard throttle performance).
peace
Old 04-14-2005, 08:35 PM   #18
feiron
Member#: 62327
2005 WRB STI
[S600BY]
that make sense ... so I guess I'd be best to up my crossover point to 40% (should I up the OLF crossover point too?) and leave the ECU control the 0% only
Old 04-14-2005, 09:51 PM   #19
hippy
Member#: 36528
2002 Impreza Wrx
Or 50, or 60. Make sure to keep the boost low below the crossover to avoid ptfb.
peace
Old 04-14-2005, 09:59 PM   #20
feiron
Member#: 62327
2005 WRB STI
[S600BY]
this leads to another question.. say at a given rpm at 100% tps, my boost map value is 300..at 50% tps should my boost map value be 150?
Old 04-16-2005, 01:05 PM   #21
T-WRX
Member#: 2468
08 RS4
05 STi - Gone
feiron, compare your timing map to the TXS stage 2 map...
You will notice how the timing map is parabolic. High timing at very low rpm (no boost), lowest timing to increase EGT and build boost, increasingly higher timing as rpm's rise.
T-WRX is offline   Reply With Quote
Old 04-25-2005, 11:36 AM   #22
hippy
Member#: 36528
2002 Impreza Wrx
Sorry that I haven't responded to the given question, I've had to move...... Anywhoo, as long as you're above the tps threashold, you wan have the utec target max boost. Below that, it would be good to keep the boost as low as possible. I'd put something like 1 in the map in those areas(below the crossover point) instead of 300. You can leave ecu in the lower rpm ranges(like 500-2000rpm in the 0% column) to avoid having the boost control solenoid from making noise while the car is idling and what not.
peace
Old 04-25-2005, 12:01 PM   #23
SBW
Member#: 38469
07 LGT spec-b
Crystal Grey Metallic
peace
im sorry, but when rpms increase, so must ignition advance to compensate for the quicker burn? Am I wrong about this, doesn't Jorge have a written explanation from Nathan himself saying this?
And FWIW, my OLF transition was easily taken care of by smoothing the timing transition.
I did still have some afr problems where the ECU was fighting the UTEC's value which could be seen on the LM-1, but this was only during Part throttle/idle (i.e. motoring around)
SBW is offline   Reply With Quote
Old 04-25-2005, 01:21 PM   #24
hippy
Member#: 36528
2002 Impreza Wrx
I said nothing about when rpms rise. I said at a given rpm, ya generally have the same or lower timing values as the boost increase, not higher ones. He had low timing values at low boost compared to higher boost in a given rpm range. Also, the timing does not have to increase as the rpms go up even though it's common practice(not that the timing shouldn't be more advanced at higher rpms). There're many things which dictate what the timing should be other then rpm. Fwiw, most peoples olf transition problems have had nothing to do with timing. As always, this is just from what I've experienced and read, and I'm no expert.
peace
Old 04-25-2005, 03:50 PM   #25
SBW
Member#: 38469
07 LGT spec-b
peace
Right...some of what you said I agree with, some I dont. I'll chalk it up to a misunderstanding on my part then.
Please check my logs from today MidRex UTEC 15 04-14-2006 10:38 PM
Conversion Gurus, Double-Check my List? EJ205 -> 98 RS jamesfacts Subaru Conversions 15 04-22-2005 02:54 PM
please check my vacuum line locations PHATsuby Normally Aspirated with bolt-on Forced Induction Powertrain 10 07-29-2003 12:21 PM
UTEC help: Think I made a little boo-boo in my map :). davidm_sh Engine Management & Tuning 7 10-10-2002 04:09 PM
Please check my Mastro review in Dealer review forum Robmat South East Region Forum 3 11-17-2001 09:32 PM
