Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 04-14-2005, 08:50 AM   #1
pgv
Member#: 73808
2003 Baja
Default Baja Headers
Hi all,
Okay, next on the list is headers. But, what should I get? I am interested in getting the best low end improvements I can since I don't travel much over 4K rpms. Also, I want a set of headers that fits up as high and tight as possible in order to preserve ground clearence.
Does anyone have any input on this?
Thanks,
Perry
pgv is offline   Reply With Quote
Old 04-14-2005, 08:56 AM   #2
holland_patrick
Member#: 72014
05 Baja gone
Winner best wax job 06WBM
borlas are cheep and you lose low end
Twe seem to be the way to go but i'm not sure about the clearance isssues
rallitek.com for more info.
holland_patrick is offline   Reply With Quote
Old 04-14-2005, 12:45 PM   #3
bajatuner
Member#: 83774
2010 Legacy GT
Default Borla
I'm running Borla Ceramic Coated...I can't really say how much power I got with them cause I did various mods at the same time. But these look and sound great.
bajatuner is offline   Reply With Quote
Old 04-14-2005, 03:03 PM   #4
Hawk296
Member#: 14555
1995 Impreza L
Baja
hmmm. On my NA EJ25 impreza I had an increase in low end torque. I did Borla headers at the same time as the rest of the exhaust so i never ran the Borlas with a stock system. I did switch back to stock headers and I definatly had a loss of low end torque.
FYI- Ive broken 2 sets of Borlas, so far they have replaced them free of charge, But I am sick of taking them off, sending them back, waiting for the new pair, re-installing them (takes 2 weeks for the whole process). Ive also had the tiny cracks re-welded at least 5 times in between complete header failures where I had to send them back. I personally am done with them, I loved the sound, very small performance increase but not worth the hassle to me.
Hawk296 is offline   Reply With Quote
Old 04-14-2005, 03:36 PM   #5
holland_patrick
Member#: 72014
05 Baja gone
I'm sorry your right it's the loss of high end My bad... BWT if i go I think TWE is the way i'm going.
Old 04-14-2005, 07:24 PM   #6
jamba
Member#: 79759
03 Baja
Hey perry,
So here's the thing; You would probably be really happy with twe cobb, and let's throw invidia equal lenth headers in there too. All great, I've seen dynos for both Cobb and TWE that show increases at low rpm. But they hang down LOWER by more than 1.5 inches than stock (some estamate more than 2 inches).
Take a close look at some of the front end pics of the lifted baja that I posted, I'm pretty sure you can see the headers... Those are borla, and they even hang about an inch (which is one reason why I have to fabricate a skidplate rather than buying off the shelf). the only reason I got borla was because they hung down the least by a lot, and they were so cheap ($222.43) .
Here's the other thing; unless you buy a chip, like perfectpower, you will likely only notice minimal or no gains either way because your air/fuel mixture will be off.
For the about the same price as equal lenth headers, you could probably get (I got) borla headers, cat back, and chip (total cost $942). I've been pretty happy with the performance gains with that set up.
jamba is offline   Reply With Quote
Old 04-14-2005, 11:07 PM   #7
pgv
Member#: 73808
2003 Baja
Jamba,
Don't you mean to say the Borlas DIDN'T hang down as much?
The Cobbs look like thay might fit up tight, but I have no way of knowing.
I like the advice on headers, chip and cat-back. That is the way I was going to go, so, the headers are next. The bank won't let me do it all at once, but I must say that the price you quoted is not bad at all. I would have guessed much higher. The Rallitek folk must have made you an offer you could not refuse. ;-)
Old 04-14-2005, 11:40 PM   #8
Hawk296
Member#: 14555
1995 Impreza L
Baja
Borlas DO hang down further than the stock exhaust manifold. But possibley not as far as the equal length offered by Cobb or TWE.
Old 04-15-2005, 12:39 AM   #9
jamba
Member#: 79759
03 Baja
Hawk is right. sorry, I could have explained better
I was supprised at how low the Borlas did hang since they were suppose to be closest to stock. I think most E.L. headers have about the same dimentions (there's really not too may ways to make them equal length), so regardless of the brand, I would plan on loosing about 2 inches... plus you will probably want to get a skidplate to cover that $1000 investment (you can get one for about $150, definately worth it!! Or you could have one made for about $70- I'll send you the specs if you want)
FS : GTSPEC Gen 2 UEL Header with Uppipe illmatic SCIC Private Classifieds 1 03-25-2011 06:08 PM
FS/FT : Cusco Headers ,SR*S DP, Alpine Sub, Sony amp, cluster, bumper beam, 02-03 airbag SueBaroo SCIC Private Classifieds 113 06-20-2010 12:56 PM
FS/FT : Megan one piece headers EPskate Tri-State Area Private Classifieds 7 06-07-2010 12:54 PM
Will STi TMIC & header require retune on Baja turbo WYSubaru Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 34 06-12-2009 12:44 AM
Baja and OBX headers pgv Baja Forum 1 06-27-2006 03:17 PM
