Old 04-14-2005, 10:28 AM   #1
d00f
Member#: 6000
2000 GC8 STi V4 swap
BRP
Default UTEC STi Boost control...
I've got someone with a UTEC/STi and it has horrible boost control. The UTEC's boost control is not installed and instead there is a 2 stage MBC. Anything past 1/2 throttle results in full boost and obviously poor throttle response.
I tried to download the documentation on this version of the utec from turboxs but the link goes to their updated map.
I've been told the boost control in the utec is really poorly implemented and the few cars I've driven seemed to reflect this. I'm still willing to try it out myself and see before recommending an EBC.
-Michael
d00f is offline   Reply With Quote
Old 04-14-2005, 10:53 AM   #2
SlideWRX
Member#: 3803
07 Mustang GT
285 is a wide tire!
So what's the question;How to tune the UTEC Boost control?
1. Put the stock system back in
2. make sure you are in closed loop boost control (one of the parameters listings; 0 or 1 )
3. The boost map is based on throttle position. put 200 in the 90 & 100 sections all the way down.
4. Log a 4th gear run.
5. Add 50 to the boost map and re-log.
6. add until you are happy with boost. IIRC, boost will fall off with high rpm with a stock turbo.
7. If the boost spikes more than you want, increase the gain in the parameters section. go in 5 point jumps up at first.
8. boost tends to spike more when punching it from 4000 or 5000 versus 2000, so try that and see if the spikes bother you.
9. The GM solenoid (http://forums.nasioc.com/forums/show...light=solenoid) might work better than the factory FBC. I use it with the UTEC and like it.
Tom
SlideWRX is offline   Reply With Quote
Old 04-14-2005, 10:55 AM   #3
SlideWRX
Member#: 3803
07 Mustang GT
285 is a wide tire!
Er, forgot:
10. Once full throttle boost is set, start dropping the values as you move down the throttle % columns. Below 70% I've basically got wastegate boost. Adjust to personal preference.
Tom
Old 04-14-2005, 11:14 AM   #4
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
There is your problem. Put the stock boost control back in, with the supplied ABC.
mbiker97 is offline   Reply With Quote
Old 04-14-2005, 12:37 PM   #5
hippy
Member#: 36528
2002 Impreza Wrx
So you're trying to make the car slower? I don't hear that much around here. Not to question what's goin on, but does it really matter if you get full boost past 50% throttle? At 50% throttle the car will obviously accelerate slower then at 100% throttle even if you're gettin full boost(cause the throttle body is limiting the air going into the engine). If ya wanna go slower, don't press the pedal past 50%. I don't see the problem other then maybe a lead foot.
peace
Old 04-14-2005, 02:27 PM   #6
AaronWRX
Member#: 7194
2011 997.2 Turbo
Do you have a sti? If you did, I don't think you would be telling people to use the ABC.
In fact, the default 375 values overboosted me 1-2psi.
DON'T use the ABC for a stage 1-2 STI. The manual is outdated.
AaronWRX is offline   Reply With Quote
TurboXS UTEC 06+ WRX and STI, Boost Controller, and Oil Pressure Gauge For Sale RedefinedTR MWSOC Private Classifieds 2 03-27-2008 02:46 PM
STI UTEC with boost control valve, box, manual and map switch syoung0298 Engine/Power/Exhaust 3 12-08-2007 12:52 AM
STi Utec with Boost Controller $700 shipped DangerousWRX Private 'For Sale' Classifieds 0 11-13-2005 02:34 PM
utec & boost controller Thehumandecoder Newbies & FAQs 1 07-19-2003 08:26 PM
UTEC - Auxilary Boost Controller ITWRX4ME Engine Management & Tuning 6 05-06-2003 01:50 PM
Message Board Statistics All times are GMT -4. The time now is 03:52 AM.
