Old 09-15-2009, 04:15 PM   #2451
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
Jigga- from fine Retailers Through luck, we have one on the shelf ready to ship today. 100% new, with all of the great features you are reading about as well. More info can be found here, click photo:
We are running a special for the month on this 1 unit, FREE SHIPPING 48 states. $939.75 would be the final price. Yes, I contributed nothing of value to this thread Actually, we have the photo from Aquamist posted (probably posted in a previous page)...that has to be worth something
[email protected]
IA Performance is offline   Reply With Quote
Old 09-16-2009, 10:34 AM   #2452
down2earthsubie
Member#: 171448
2003 wrx
psm
Originally Posted by Aquamist View Post
Ahead of our scheduled diagnostic session, can you let me know your car model again, I wil post a wiring diagram up here for you to do a pre-diagnostic check. I have yet to know the DDS3 version number. I need that too.
Under no circumstances should the system come on at the "ACC" position.
i rewired my power and ground straight from the ecu where your 03 wrx diagram shows and it still has glitch problems on start up and shut off.
also do you have a diagram or can you tell me how to wire up my boost cut for my v10? i know which wire to cut from the ecu. im just confused on what 2 ports to use in teh controler box bc it looks like there is 3 to choose from.
down2earthsubie is offline   Reply With Quote
Old 09-17-2009, 07:23 PM   #2453
Aquamist
NASIOC Manufacturer
Member#: 110029
2004 Citroen Picasso
Aquamist is offline   Reply With Quote
Old 09-26-2009, 09:04 AM   #2454
RR-racing
Member#: 41632
2004 Spec C
WRC blue
Question regarding HFS-5:
Is there simple way to manually activate the HFS-5 to spray 100% IDC?
I would like take a short drive and steam clean the engine.
thanks.
RR-racing is offline   Reply With Quote
Old 09-26-2009, 04:17 PM   #2455
Aquamist
NASIOC Manufacturer
Member#: 110029
On version 8, 8a or 9, you just need to disconnect the green wire from the fuel injector and ground it.
You can make a 2 way toggle switch:
- common = DDS3
- Normally opened = ground
- Normally closed = fuel injector
Flip the switch to ground the HFS-5 will run 100%
Version 10, use the "test" jumper link.
Old 09-27-2009, 06:22 PM   #2456
nhsilversti
Member#: 50895
. www.48hrs.info
donation chairman
richard, sent you a pm
nhsilversti is offline   Reply With Quote
Old 09-30-2009, 04:00 PM   #2457
Aquamist
NASIOC Manufacturer
Member#: 110029
Default Mounting the DDS3 gauge
Just saw an innovative way to mount the DDS3 gauge...
Old 09-30-2009, 08:59 PM   #2458
aqmist
Member#: 137265
2004 SRT4
BLACK
Interested in more info on this I might want to do this on my car
aqmist is offline   Reply With Quote
Old 10-01-2009, 04:47 AM   #2459
Aquamist
NASIOC Manufacturer
Member#: 110029
Here is the link, costing about $15.00
http://www.frsport.com/Blitz-19290-D...d_p_13280.html
Old 10-01-2009, 07:44 PM   #2460
STiAlain
Member#: 134565
Chapter/Region: HIIC
2006 STi
Richard can you please provide me with a wiring install guide for the hfs6 kit for a 06 sti?
STiAlain is offline   Reply With Quote
Old 10-01-2009, 08:35 PM   #2461
Aquamist
NASIOC Manufacturer
Member#: 110029
Old 10-04-2009, 03:55 PM   #2462
Dr B
Member#: 150270
I have the HFS-6 kit .Richard do u have the wiring diagram for the JDM V7 EJ207 , this is the bugeye model 2001-2. Apparently I need to use 2 nozzles for water/meth injection , I am using a TurboXS FMIC where would be the best place to put the nozzles for best efficiency . Thanks .
If u dont have the diagram for the ECU , can anyone else help . Thanks
Dr B is offline   Reply With Quote
Old 10-04-2009, 04:21 PM   #2463
Aquamist
NASIOC Manufacturer
Member#: 110029
This not an easy one to find.
If all else fails, trace the fuel injection signal from the fuel injector. Subaru normally uses a pink wire with a trace of a second colour (at the ECU). You can also pick out the ignition switch wire from the fuel injection (+). It is usually yellow on the older model? The HFS-6 draws no more than 30mA on the Yellow harness.
Old 10-05-2009, 08:16 PM   #2464
Dr B
Member#: 150270
Thanks richard , what about the meth inj nozzles , any advice for best palcement .Thanks
Old 10-06-2009, 05:43 AM   #2465
Aquamist
NASIOC Manufacturer
Member#: 110029
I often think pre-TB will cause pooling as soon as the water droplet hit the throttle plate, similar to a rain hitting your windscreen.
When the jet is far away from the any object directly inline, there is a better chance of the droplet retains its surface area.
As droplet evaporates, the size will also decrease in proportion. The more time you allow this process to take place, the better the inter-cooling effect and smaller droplets. Smaller droplet (lighter) also give you better cylinder distribution. Large droplets tend to fly towards the back end of the manifold/plenum.
There is also a myth about evaporated water displaces valuable space within the linlet tract. This is not very true. Water can only continue to evaporate if the RH (relatively humidity) is below 100%. RH dedictates how much water can evaporate in a given environment, subject to pressure, temperature. Water and methanol have a specific vapour pressure that allows prediction by methematical calculation.
Vapour pressure is closely related to "Van der waals" forces, which holds the individual molecules together. Apply enough energe to the molecule, it will
break loose and separate - basic principle of evaporation. Water on the surface of a container tends to evaporate first because it has only half the "VDW" forces. Water droplet is basically the same surface water suspected in air with all surface exposed to absorb heat energy.
I know most of the water manfacturers advise the opposite, put the jet at the TB. I have yet to hear a valid arguement for this, so far none makes sense.
Old 10-06-2009, 06:13 PM   #2466
STiAlain
Member#: 134565
2006 STi
Thanks Richard!
Old 10-06-2009, 09:00 PM   #2467
Aquamist
NASIOC Manufacturer
Member#: 110029
Did you know the HFS-6 can initiate a "limp home" mode upon a failsafe activation? It wil go to a base map and lower boost to wastegate pressure.
Here is a lnk to that thread:
http://www.iwsti.com/forums/water-me...rd-ecu-ap.html
Old 10-07-2009, 12:28 AM   #2468
WReXd
Member#: 114101
93 Impreza L Swap
There are only a handful of pins that differ between the jdm and usdm ecus (2.0L). The injector pinouts are the same. You can find the usdm pinouts on northursalia.com.
WReXd is offline   Reply With Quote
Old 10-07-2009, 06:28 AM   #2469
Aquamist
NASIOC Manufacturer
Member#: 110029
WReXd,
Thank for your help. I couldn't find any info on it so far. May be not looking into the right place.
Old 10-08-2009, 05:19 AM   #2470
singlefin
Member#: 108379
Default HFS-6 Wiring Diagram for 04 STI
Hi Richard,
Do you have a wiring diagram for 04 STI?
(for HFS-6)
Thanks
singlefin is offline   Reply With Quote
Old 10-08-2009, 05:35 AM   #2471
Aquamist
NASIOC Manufacturer
Member#: 110029
I think this will work.
Old 10-09-2009, 09:41 PM   #2472
Dr B
Member#: 150270
thanks again richard for your advice , just to make sure I have it right , u are saying don't put both meth nozzles at the Throttle body but instead preTB as far as possible before the TB .I often thought it was better to put one just post IC and the other at the TB . DO I have it right ? What have others done with good results ?
Old 10-10-2009, 05:04 AM   #2473
Aquamist
NASIOC Manufacturer
Member#: 110029
I have expressed my reasons for placing the jet as far away from the TB on post #2465. There are occasion such as TMIC where a smaller jet is placed pre IC and larger one after IC.
It will also be depending on your climate. In hotter countries where ambient temperature is high, allow more time for the droplet to perform intercooling by placing the jet as far away from the TB.
I hope others will chime in and help.
Old 10-12-2009, 07:11 PM   #2474
chongl
Member#: 187694
2009 GTX3076 WRX
520whp on E85
Hi Richard,
Are there any plans for a 60mm DDS3 gauge? My Defi's are 60mm and I want them to be the same size across the board.
Thanks!
chongl is offline   Reply With Quote
Old 10-12-2009, 08:34 PM   #2475
Aquamist
NASIOC Manufacturer
Member#: 110029
No plans yet but we can machine a 60mm adaptor for you.
Passing the NEW required OBDII Emissions test in PA Questions and Answers!! mrtrex Mid Atlantic Impreza Club -- MAIC 29 03-10-2013 08:23 PM
Snow Performance questions and answers... Ultimate Collision Center Water/Methanol Injection, Nitrous & Intercooler Cooling 374 09-23-2008 05:36 PM
Motörhead Guidlines, questions and answers here: GO LEMMY!! El Camino Off-Topic 9 01-20-2006 03:39 PM
Roll Center, questions and answers Arnie Brakes, Steering & Suspension 5 12-21-2004 04:26 PM
