Welcome to the North American Subaru Impreza Owners Club Sunday January 25, 2015
Old 04-14-2005, 05:17 PM   #1
MF-DIF
Member#: 62197
GTO /WRX/SV650
Default Cobb STG2 w/ uppipe worth it?
Would a Stg 2 with Uppipe be virtually equal to a TBE Stg 2? Would I gain anymore performance other than slightly lower spool?
MF-DIF is offline   Reply With Quote
Old 04-14-2005, 05:28 PM   #2
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
its worth it.
jared nelson is offline   Reply With Quote
Old 04-14-2005, 05:48 PM   #3
REDrum
Member#: 61536
WRX' 04Road02gravel
www.ToltecRally.com
Yes, you get much better spool. But, more importantly, you get rid of that cat. W/ STG2 you are running more boost. More boost increases likelihood of busting that cat loose and trashing your turbo. IMO, everones engine mod-path w/ a 2.0L WRX should be remove/swap-ot up pipe cat, then EM, then high flow air filter, then TB. Then dyno tune...
REDrum is offline   Reply With Quote
Old 04-14-2005, 06:16 PM   #4
Paulie V
Member#: 10260
2002 WRX Sedan
PSM- Knock, knock :-(
Are you talking about adding the Uppipe INSTEAD OF the TBE or in addition to it?
Paulie V is offline   Reply With Quote
Old 04-14-2005, 08:14 PM   #5
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
getting a better uppipe is good period no matter what else you do.
Old 04-14-2005, 11:35 PM   #6
REDrum
Member#: 61536
WRX' 04Road02gravel
www.ToltecRally.com
First catless up pipe then EM then TBE. Time between the three depends on how much $ ya got. UP for spool, DP/TBE for power. Highly recomend some (more) search on UPs for more rational behind the mod.
And... Cobb stg2 requires a TBE. (or at least a good DP). Anything less it and it ain't stg 2
Old 04-15-2005, 11:31 AM   #7
MF-DIF
Member#: 62197
GTO /WRX/SV650
I'm talking about adding the UP. I've been running Stg. 2 for a few months now...and have had an uppipe sitting in my living room for just about as long. Time to get to work.
Old 04-15-2005, 11:34 AM   #8
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
do it. uppipe will do so much, plus, it wont blow up and fragment into your turbine like it did mine. believe me thats alittle more work than just changing the uppipe.
Old 04-15-2005, 05:45 PM   #9
Paulie V
Member#: 10260
2002 WRX Sedan
Yeah, I know, I was just making sure he wasn't trying to go stage 2 by substituting the UP instead of the TBE.
MF-DIF, from what everyone says, swapping out the UP supposedly makes a nice difference with spool-up, plus you don't have that pre-cat waiting to meet your turbo! Been thinking about it myself...but then I'd be tempted to do the DP while I was at it and go stage 2 as well and then my wife might get word of it and she'll want to hurt me!
Old 04-15-2005, 07:33 PM   #10
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
gotcha, yeah,
hey a tip on how to do the stage 2 without your wife knowing, is to do the TXS stealth back which is a 4 inch DP to 3 inch MP to another section that blends down to 2.5 or something like that, and then you keep your stock muffler. youll have all the power with the same muffler, then when she asks if your car seems louder, you can say somthing stupid like, "yeah i just turned off the sphetzer valve restriction, i can always turn it back on", and with any luck shell be ok with it. mean while you are running 13s and your wife is still happy.
Old 04-15-2005, 09:21 PM   #11
Zumble
Member#: 34860
2005 Forester CGM
You should never turn off the sphetzer valve restrictor, it's in the FAQ.
[quote=jared nelsonlouder, you can say somthing stupid like, "yeah i just turned off the sphetzer valve restriction, i can always turn it back on", and with any luck shell be ok with it. mean while you are running 13s and your wife is still happy.[/QUOTE]
Zumble is offline   Reply With Quote
Old 04-16-2005, 01:08 AM   #12
NWWagon
Member#: 66769
05 Focus "ST"
'80 Honda CM400T
Originally Posted by jared nelson
gotcha, yeah,
Or get a wife that asks "So when you going to install that exhuast system on your car?"
Man I love my wife....
NWWagon is offline   Reply With Quote
Old 04-16-2005, 09:54 AM   #13
Paulie V
Member#: 10260
2002 WRX Sedan
gotcha, yeah,
Yeah, but it'll be kinda difficult to explain a couple of large boxes showing up and then me spending some more time under the car (of course I could say it was a difficult oil change or something!)! I'll get the infamous "How much did it cost??!!" Or the "So, after the wheels, and springs, you're done... RIGHT??!!" Uh, yeah, sure, oh wait, I want to get... ha ha! Done- is that actually possible?
Old 04-16-2005, 03:47 PM   #14
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
that sux, are you sure this lady is keeping you happy? JK i think ladies do that in a little bit to us all.
Old 04-16-2005, 04:04 PM   #15
salem
Member#: 56143
Fit is Go
definitely not worth it.....you'll just want more power afterwards
seriously, though, it is a significant improvement.
salem is offline   Reply With Quote
Old 04-17-2005, 07:58 PM   #16
the2rz
Member#: 46033
2008 BMW 335i
Silver/Black
now the question becomes WHAT upipe
I'm in the same boat with a TXS TBE and am Cobb 2. Considering either the TXS or STi upipe.
the2rz is offline   Reply With Quote
Old 04-17-2005, 08:08 PM   #17
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
large diameter ones are good,
GrimmSpeed Headers/ uppipe worth it $$ tfields04 Newbies & FAQs 15 05-21-2009 10:01 AM
headers and uppipe worth it? GrassyKnoll Newbies & FAQs 12 05-18-2007 03:42 AM
Cobb stg2 before uppipe and after dyno results Lordhowe Engine Management & Tuning 18 02-07-2006 12:11 AM
uppipe...worth it?? hard to install?? daphunkie12 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 46 12-03-2004 10:23 PM
Cobb Stage 1 suspension: worth it ? FloridaWRX Brakes, Steering & Suspension 11 08-27-2002 04:48 PM
