Old 04-14-2005, 08:04 PM   #1
sammydafish
Member#: 77523
95 Legacy Wagon
Question Clutch options for EJ22, will this work?
ok, so I got bored last weekend and slapped a turbo on my 90 EJ22 wagon. The thing moves like a bat outta hell now, and unfortunatly, the stock clutch gives way after the boost comes on regularly. Pics and more info on the turbo are on Legacy central if you want. I just joined here so I can't post links yet.
Anyway, searching the forums here and at legacy central give me the idea that all EJ series N/A engines run the same clutch. The only performance clutch I can find for a non tubo EJ engine lists only for the EJ25 though. Exedy makes a clutch part number 15801 for the 2.5 RS Impreza that's 29% stronger than the stocker. This would be great if it fits.... so.... does it?
Thanks
sammydafish is offline   Reply With Quote
Old 04-14-2005, 08:13 PM   #2
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Yes, you can use a 2.5 RS clutch w/ the EJ22.
jamesfacts is offline   Reply With Quote
Old 04-14-2005, 08:21 PM   #3
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
Yes, it will fit, but it isn't much stronger than your 2.2 clutch,stock for stock. If you run an ACT, Clutchmasters, etc, be warned that with the stock cable setup, you need legs like Lance armstrong to shift.
yamarocket630 is offline   Reply With Quote
Dealer sold me the wrong nuts for endlink bolts, will this work OK? SubieSubie Brakes, Steering & Suspension 2 07-31-2008 07:40 PM
Will this work, or what will?? mathroch UTEC 1 10-01-2006 08:32 PM
Will This Work for balancing Coilovers Sausage Brakes, Steering & Suspension 3 08-17-2006 07:07 AM
will this work for 05 wrx (cel fix) Wookie768 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-19-2006 05:08 PM
will this work for my STi - OBDII rich728 Engine Management & Tuning 7 04-24-2004 07:04 PM
