Old 04-14-2005, 10:34 PM   #1
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Default Scan of Headlight Wiring Diagram from '02 Service Manual
Just thought this would help out for many of the headlight/switch/DRL wiring issues.
Old 04-16-2005, 12:52 PM   #2
WRXRgr
Member#: 54942
2004 WRX
Good info!
I'm currently considering trying to put the DRL function over to the fog lites, from the low beams...over in this thread
Some of the switch terminal designators have me stumped...
On Dimmer & Passing Switch, there are four terminals--
HF--Headlamp Flash, I'm guessing...energizes the hi beam relay
HU--Upper, or high beams...completes ground path for hi beams
HL--Low beams? doesn't show any connection on diagram, however.
E---Earth, for ground
On the Lighting Switch, three terminals showing--
HC--energizes the DRL relay (completes path to ground)
TC--?? shows no connection to anything on diagram..
EL--connection to ground
Any idea on the "HL" and "TC" terminals? I don't like assuming they are "unused"...automotive "pictorial" schematics always make me wonder what might have been left out...
WRXRgr is offline   Reply With Quote
Old 04-16-2005, 04:25 PM   #3
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Yes, diagram shows connection goes through the DRL relay to low beams.
Sorry, this is only the Headlight System page. TC handles the parking lights and is covered under the Parking Light pages. There are additional relevant pages under the Power section (where the headlight relays are covered), Fog Light section, etc, but I figured this would cover 95% of the questions.
I will try to post the Fog Light System page below.
Old 04-16-2005, 04:49 PM   #4
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Old 04-16-2005, 04:52 PM   #5
WRXRgr
Member#: 54942
2004 WRX
Holy Kamoley!
You're correct---your diagram does show the "HL" terminal running to #5 on DRL relay! I was looking at my print-out from my MY04 eBay disk...it shows nothing on the "HL" terminal, and it shows #5 on DRL relay as going direct to ground...yipes, looks like there's a difference from your MY02 manual to the MY04...arg!
Old 04-16-2005, 05:04 PM   #6
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
I'm not sure how much I would trust the ebay manual unless you've compared it with known good MY04 manuals.
You might want to spring for the $35/72 hour techinfo.subaru.com download deal and download the MY04 headlight/DRL/fog/etc pages from there, along with any errata.
Need Wiring Diagrams And Pictures From Factory Service Manual!!!! Help!!! WRXINTX General Community 5 10-02-2005 08:37 PM
Seeking Headlight Wiring Diagram for Headlight Timer JackClark Electrical & Lighting 2 03-13-2005 09:32 AM
BG stock headlight wiring diagram needed monovich Legacy Forum 6 09-09-2002 06:16 PM
New Age MY02 RS Headlight Wiring Diagrams Josico Interior & Exterior Modification 6 12-26-2001 04:13 PM
