Old 04-15-2005, 08:24 AM   #1
txjunglist
Member#: 11926
2011 Outback Limited
Dark Grey
Default Utec and Check Sums
Alright here is the bane of my existance.
I keep getting check sum error map corrupt .. I reloaded firmware and reentered all my params. Still the same problem. My tuner says he calculated the checksums and they were right. What am I missing here.I got a car in my garage I can't drive. .
the scenerio I just installed a new AVCR
I installed it wrong because the info I had to install it was inaccurate.The car went into flash mode I guess. (check engine flashes real fast and the fans go on and off). Could this have affected my utec?
Jake
txjunglist is offline   Reply With Quote
Old 04-15-2005, 08:45 AM   #2
Bolster
Member#: 22290
2002 WRB WRX Wagon
Jake, I haven't had UTEC now for almost a year, so bear with me. I think when I had this problem I just had to rename the map file, i.e. "VF2218psi.txt" to "VF2218psi1.txt". Then reloading the maps would go without a hitch. It doesn't matter what you change the name to, just that the name is changed. Take care.
Bolster is offline   Reply With Quote
Old 04-15-2005, 08:59 AM   #3
txjunglist
Member#: 11926
Dark Grey
Hrmm ok I'll try that. I did however get the maps reloaded on the utec via my brother in law laptop. so It is a problem with my new laptop.
Old 04-15-2005, 09:01 AM   #4
Bolster
Member#: 22290
2002 WRB WRX Wagon
So with your brother's laptop the car runs- no problems? I think the actual problem isn't with hardware, it's a hyperterminal bug. Anyone else wanna chime in?
Old 04-15-2005, 02:03 PM   #5
Gethin
Member#: 2998
I had strange gremlins with a Sony Vaio PCG-745 now and again, could not work it out or put my finger on the cause. I got errors trying to flash to 4.2c as well as sometimes loading a map. With a newer Athlon Vaio brick laptop it works fine all the time. Both with exactly the same OS (XP Pro) and cables, settings etc etc. Some gremlin between Hyperterminal and the motherboard chipset I guess....both laptops using same UART too.
Gethin is offline   Reply With Quote
Old 04-15-2005, 02:16 PM   #6
agterlik
Member#: 41626
SPB We make people
quit teh internet
I had alot of problems the first time I was trying to hyperterminal into mine as well...and like you one I did get a actual connection with the utec I kept having paramater failure. I had to log out of the utec and turn off the car and re download the map several times....since I was using the turboxs stage 4 map and parameters for the time being. I tried re-naming the file and that did not help me. Just try connecting to the utec several times is my suggetion.
agterlik is offline   Reply With Quote
Old 04-16-2005, 12:50 PM   #7
T-WRX
Member#: 2468
08 RS4
05 STi - Gone
Try using the UTECedit software (free download at wrxhackers), which will enter the correct checksum for you.
T-WRX is offline   Reply With Quote
Check sum when loading maps nomorepoison UTEC 9 12-14-2009 07:36 PM
help! utec delta, check sum failed! map corrupt cruxwrx04 UTEC 3 10-11-2009 06:07 PM
ROFL - the difference between men and women summed up quite nicely -=C=- Off-Topic 15 09-21-2006 03:32 PM
Utec check sum error map corrupt!! UTEC help bluesube2000 Engine Management & Tuning 18 07-28-2005 04:45 PM
UTEC and LM-1 Users! Check it out! jmussetter Engine Management & Tuning 68 06-03-2005 03:56 AM
